Old 03-07-2001, 09:46 AM   #1
BobL
BobL is on a distinguished road
Default L Series Headlight Replacement
Read the procedure to remove the fan relay in the 2000 and 2001 owners' manuals. The 2001 says to use a flat blade screwdriver to release a clip so the relay can be lifted out of the way for access to the driver side bulb.
I've got really bad eyes but can't see where to put the screwdriver. On one side of the relay are 2 plastic clips that look like they open the relay box itself. The other side looks like the part that holds the relay but I don't see the clamp Saturn tells you to release.
Don't need to change now but want to be able to do it myself when needed.
Techs, any help in shop manual or have you already changed one?
Asked at dealer but they'd never needed to do one yet.
Thanks,
Bob
Add to BobL's Reputation
Rate the quality of this post and help BobL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BobL is offline
Old 03-08-2001, 11:20 AM   #2
L-man
L-man is on a distinguished road
Default
I had to replace the low beam bulb on the drivers side of our LS-1, the clip is behind the relay and its metal, when I went to release it it bent so now it dosent clip any more,no big deal,the relay fits snug in its brackets so at least next time I wont have to use a screwdriver
Add to L-man's Reputation
Rate the quality of this post and help L-man reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
L-man is offline
Old 03-08-2001, 03:12 PM   #3
BobL
Default
Thanks,
Do you put the screwdriver in the back between the relay box and clip?
BobL is offline
headlight bulb replacement paulff3 Astra Tech 73 02-01-2014 01:27 PM
94 Pop-up headlight replacement rugersc2 S-Series General 0 08-15-2006 11:57 AM
Headlight Replacement ranger2k Vue General 3 03-25-2005 02:36 AM
Replacement Headlight bulbs? LynnF Ion General 19 07-13-2003 11:50 AM
Replacement headlight bulbs SC2fast S-Series Tech 9 05-11-2002 11:35 AM
