Old 07-14-2005, 10:52 AM   #1
LAD420
LAD420 has a spectacular aura aboutLAD420 has a spectacular aura aboutLAD420 has a spectacular aura about
1997 SC2
Default 144.500 on 97 sc2
Redundent question here...
At 144.500 miles, is a timing belt replacment and valve adj. standard as preventive maint? I am guessing it is as with all 4cyl....
Also, is the chatter at the front of the motor at idle a saturn trait? When at higher rpms it smooths out to a normal 4 cyl. sound. Was wondering have heard stories that it is a little louder motor then some of the other 4cyl. out there......
Thanks !
LAD420.
Add to LAD420's Reputation
Rate the quality of this post and help LAD420 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LAD420 is offline   Reply With Quote
Old 07-14-2005, 11:00 AM   #2
rkuris
rkuris is on a distinguished road
rkuris's Avatar
Default Re: 144.500 on 97 sc2
First off, there's no timing belt, it's a timing chain. If you keep your oil clean and topped off at each fill up, your timing chain will probably last a lot longer.
The chatter is probably the engine mounts, which seem to die every 60k. The engine is usually really quiet with new mounts.
Add to rkuris's Reputation
Rate the quality of this post and help rkuris reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rkuris is offline   Reply With Quote
Old 07-14-2005, 02:38 PM   #3
Bill Murray
Bill Murray will become famous soon enough
1997 SC1
1997 SC1
Congrats on completing the Saturn S-series "break-in" period
Add to Bill Murray's Reputation
Rate the quality of this post and help Bill Murray reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 07-14-2005, 02:53 PM   #4
LAD420
1997 SC2
Ah yes.. Chain.
Regarding the chatter, don't think it's the mounts. Has an internal sound to it. Don't notice much flex at motor when reved under the hood.At least it has no noticable movement. I guess it could be the timing chain. Not sure. However it is coming from the pulley / front end of the motor. And it smooths out under acceleration. I only ask as my Dad (ha ha) was very concerend. Yes I know I am 40 years old.....LOL
BTY, the idiots at the oil change place, slipped me a flush instead of an tranny fluid and filter change. I am quite pissed!! I mean, how else could you state what you want done? "change the tranny fluid and flitler" !!!
Well, hope too many little pieces didn't get dislodged........
Thanks for the help!
LAD420
Old 07-14-2005, 04:00 PM   #5
LowSC2
LowSC2 is on a distinguished road
LowSC2's Avatar
1999 SC1
1991 SL2
No belt. But that timing chain should be replaced. I do that every 100K miles. But others have different opinions. And theres no need for valve adjustment.
Thanks !
LAD420.
Could be anything. Saturns are a little noisy. If the noise corresponds with RPM then it could be the lifters making noise. As long as the noise smooths out with RPM I wouldn't worry about it.
As for the trans. Don't go to one of those oil change places. They never do it right. You can do it yourself. Just drain the fluid and replace the filter on the front. Just as easy as doing the oil.
Jeff Silva ~ 91 SL2 - 11.809 @ 116.488mph
•Chilton & Haynes manuals are junk
•Changing the ECTS doesn't fix everything
Add to LowSC2's Reputation
Rate the quality of this post and help LowSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LowSC2 is offline   Reply With Quote
Old 07-17-2005, 12:57 AM   #6
LAD420
1997 SC2
Thanks for the help !
LAD420
1991 SC2 for $500 Low Saturn S-Series General 9 01-01-2009 01:16 PM
'93 Sc2 For Sale!! $1,500 gnxdreamin S-Series General 2 09-07-2005 08:52 AM
'93 SC2 for sale.....$1,500 gnxdreamin Classifieds 3 09-05-2005 06:57 PM
'96 SC2, 79,500 mi, $2500 (Hoboken, NJ) kevinmmccormick Classifieds 0 08-29-2005 03:09 PM
2000 SC2 53,500 miles calebols Classifieds 0 04-11-2005 02:01 PM
