Old 11-25-2003, 01:48 PM   #1
lewis2
lewis2 is on a distinguished road
Default auto headlight problem- L series
Hi. Any professional advice on this problem would be greatly appreciated. I have a 2002 L200 with the auto headlight feature. Intermittently since new the car's auto headlight feature has turned on the headlights at times when it is very bright outside. After a few days it has always reverted to working properly and in the bright daytime the drls would go on and all would be well. At present this problem has reoccurred and is not going away so I wonder if any of you techs out there have seen this problem and if you did what was the fix? Thanks in advance!
Add to lewis2's Reputation
Rate the quality of this post and help lewis2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lewis2 is offline
Old 11-25-2003, 02:37 PM   #2
eljefino
eljefino's Avatar
1995 SW1
Default
http://www.lightsout.org
Add to eljefino's Reputation
eljefino is offline
Old 11-25-2003, 02:44 PM   #3
lewis2
Default
I wish it was just that the drls don't light. When this is bad like now the headlights and tail lights are on no matter how bright it is outside.
lewis2 is offline
Old 11-25-2003, 05:29 PM   #4
Nuke-Em
Nuke-Em is on a distinguished road
Nuke-Em's Avatar
Default
I don't get those anti-DRL people--the exaggeration on that website is laughable.
Matt
If God had intended driving to be boring, he would have given us all Toyota's
Add to Nuke-Em's Reputation
Rate the quality of this post and help Nuke-Em reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nuke-Em is offline
Old 11-25-2003, 06:22 PM   #5
hugh
hugh will become famous soon enough
Default
Matt;
About 25 years ago it was called the seat belt association probably.
Add to hugh's Reputation
Rate the quality of this post and help hugh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hugh is offline
Old 11-25-2003, 08:43 PM   #6
eljefino
eljefino's Avatar
1995 SW1
Default
What lightsout.org also explains is how to disable automatic headlights, the ba$tard sibling of DRLs. Imagine your car flashing your headlights for no good reason driving on the highway on a sunny day. Imagine an 18 wheeler interpreting that as "okay to pull in".
Lightsout.org blames saturns for the worst headlight glare from DRL design; I see other sattys on the road and am not bothered.
eljefino is offline
Old 11-25-2003, 09:44 PM   #7
TedL
TedL is on a distinguished road
Default
Just a wild guess (but quick & free): Where is the sensor located? Could it be getting covered by something, then uncovered?
Add to TedL's Reputation
Rate the quality of this post and help TedL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TedL is offline
Old 11-25-2003, 10:03 PM   #8
silverblueL200
Guest
Posts: n/a
Default
Mine tends to get full of dust & crap, I have to clean it out every now and then to keep the lights from staying on.
Add to silverblueL200's Reputation
Rate the quality of this post and help silverblueL200 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-26-2003, 09:11 AM   #9
lewis2
Default
Thanks Matt- do you just wash the black button or do you have to like stick a pin in the slots? I've tried cleaning it to no availabut maybe there's a spot I'm missing?
Lew
lewis2 is offline
Old 11-26-2003, 12:13 PM   #10
silverblueL200
Guest
Posts: n/a
Default
I just take a dry cloth & wipe the dust off the top, then use some compressed air to blast at it to try and knock the dust out.
Old 11-26-2003, 12:33 PM   #11
lewis2
Default
thanks Matt- I'll try it!
lewis2 is offline
Old 11-26-2003, 01:11 PM   #12
ricksLS1
ricksLS1 has a spectacular aura aboutricksLS1 has a spectacular aura about
ricksLS1's Avatar
Default Re: auto headlight problem- L series
If it is under warranty why not just have the dealer check it out. Maybe the sensor is bad. But you know if they don't see a problem....
Add to ricksLS1's Reputation
Rate the quality of this post and help ricksLS1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ricksLS1 is offline
Old 11-26-2003, 02:08 PM   #13
lewis2
Default
it started working by itself again ......... so i'll probably be annoyed again in about 3 months if it's par for the course.
lewis2 is offline
rain sensor/auto headlight plug in windshield Tom S2 Astra General 28 10-22-2009 06:55 PM
Any s-series headlight fixtures near Phoenix? jonnycube S-Series General 3 09-09-2009 04:40 PM
Auto Headlight On-Off Switch ION Ion General 4 05-27-2003 10:00 AM
Hot headlight switch on L series Emanuel L-Series Tech 5 08-21-2001 10:21 AM
L Series Headlight Replacement BobL Miscellaneous Tech 2 03-08-2001 03:12 PM
