Old 07-06-2003, 08:19 PM   #1
David 93 SL2m
David 93 SL2m's Avatar
2004 VUE 2.2L
2007 ION-3 Sedan
Question Changing headlight bulbs on the 2003 L-Series
How do we go about changing the headlight bulbs in the 2003 L-Series? I can see the low beam bulbs but the high beam bulbs are not visible.
The owners manual says to remove the front grill, to remove the screws at the top of the headlight assembly, to move the white lever near the front grill area up, and then to pull the headlight assembly out.
Okay, I did that. I removed the front grill, removed TWO screws, moved the white lever up, but the headlight assembly feels like it is still secured. I can pull but there is resistance and I don't want to brake anything. Are there more than TWO screws? Do we need to twist or rotate while pulling the headlight assembly away from the car? Has anybody done this successfully and have tips to pass on? Thanks.
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
David 93 SL2m is offline
Old 07-06-2003, 09:11 PM   #2
BobL
BobL is on a distinguished road
Default
Good Lord! I thought Saturns were supposed to be easy to maintain.
My 2000 LS manual showed replacement from the back w/o removing parts.
What did they "improve" to make bulb changes this difficult?
Add to BobL's Reputation
Rate the quality of this post and help BobL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BobL is offline
Old 07-06-2003, 11:35 PM   #3
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
Default
Its actually easier since it gives you more room. The assembly should lift slightly upward to disengage from the mounts.
~D.J.~
OhioVueBoy is offline
Old 07-07-2003, 12:44 AM   #4
SilverNickelQC
SilverNickelQC is on a distinguished road
SilverNickelQC's Avatar
2004 ION-3 Quad Coupe
2001 L-Series 3.0L Sedan
Default
I found out that on the 00'-02' L's you HAVE to take the headlight assembly off to get to the hi beam head light it is especially tight on the driver side where the battery is located.
Add to SilverNickelQC's Reputation
Rate the quality of this post and help SilverNickelQC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SilverNickelQC is offline
Old 07-07-2003, 07:16 AM   #5
Kahakeaboi
Kahakeaboi is on a distinguished road
2004 VUE 3.5L
Default
I never removed anything and managed to change my low and high beam bulbs to hyper whites...
it helps to have slender hands helping out...
but i never unscrewed anything and managed...that battery area is quite difficult...However, try changing the bulbs on a new Altima...OMG, I had to have the maintenance guys do it, too difficult...lol
Add to Kahakeaboi's Reputation
Rate the quality of this post and help Kahakeaboi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kahakeaboi is offline
Old 07-07-2003, 02:55 PM   #6
Euphony010
Euphony010 is on a distinguished road
Euphony010's Avatar
Default
Ehh.. a little elbow grease and it's doable without removing the headlight assembly.. I replaced all four bulbs on my 00' with Sylvania Silverstars.. (Great by the way!) ALL it took was a liitle persistence, not worrying about a scratched knuckle or two, and they evetually found their way in.
Thomas
So Long L Series... Hello Mazda 3.
I still miss the polymer.
Add to Euphony010's Reputation
Rate the quality of this post and help Euphony010 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Euphony010 is offline
Old 07-07-2003, 05:18 PM   #7
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Happy
~D.J.~
Thanks, I'll give that a shot.
The high beam bulbs are not accessible on the 2003 L-Series unless the headlight assembly is removed. This may not be the case for the 2000, 2001, and 2002 L-Series, but I have a 2003 L-Series and the headlight assembly is different.
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 07-07-2003, 05:21 PM   #8
Qlara
Qlara's Avatar
Default
Do you still have to pry out a small black box between the battery and front frame, before you can access the driver side bulbs?
Add to Qlara's Reputation
Qlara is offline
Old 07-07-2003, 07:43 PM   #9
dmccreary860
dmccreary860 is on a distinguished road
Default
That small black box is the fan control module (I think). On the '00 through '02's, it IS possible to change the bulbs when this is pried up and pulled out some.
Add to dmccreary860's Reputation
Rate the quality of this post and help dmccreary860 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dmccreary860 is offline
Old 07-07-2003, 09:44 PM   #10
Euphony010
Euphony010's Avatar
Default
Get some skinny teenager with skinny fingers to do it! I did!
Thomas <-- Skinny Teenager with Skinny Fingers
Old 07-15-2003, 09:27 PM   #11
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Red Face
Well, I still can't figure out how to access the high beam bulbs in the 2003 L-Series!
I telephoned Saturn at 1-800-553-6000 and they simply read the owner's manual to me. I called my local Saturn retailer and they didn't know either. Tomorrow I'll stop by my local Saturn retailer with my car. Hopefully they will have the FSM pages for me to read....
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 07-17-2003, 07:30 AM   #12
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Mad
Well, the local Saturn place didn't know how to get to the high beam bulbs in the 2003 L-Series either!
Meanwhile I tried to put in SilverStars for the low beams as I've given up on the high beams but the low beams are bulb size H11. Size H11? Yes, H11. So no Silverstars for me...
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 10-27-2003, 08:39 AM   #13
wwonka
wwonka is on a distinguished road
Default H11 Bulbs
http://www.hoen-usa.com/plus.htm
http://nextcollection.com/html/ORD-L...15725-none.cfm
here are some h11 bulbs.
the 2nd link the bulbs are 100w and I would think that they might start to melt something.
peace
billyb
Add to wwonka's Reputation
Rate the quality of this post and help wwonka reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wwonka is offline
Old 11-04-2003, 05:40 PM   #14
Gardenof_E
Gardenof_E is on a distinguished road
Gardenof_E's Avatar
Default
are those hoen H-11 bulbs any good? Has anyone tried them yet?
Add to Gardenof_E's Reputation
Rate the quality of this post and help Gardenof_E reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gardenof_E is offline
Old 11-06-2003, 10:22 AM   #15
wwonka
Default bulbs
just got the hoen H11 bulbs in
will let you know in a few days
it looks like i mispoke the h11 are the high beams though.
peace
wwonka
wwonka is offline
Old 11-06-2003, 11:30 AM   #16
wwonka
Default edit
the h11 are the correct bulbs
I am just an idiot
I will let you know in a few days what I think of the Hoen bulbs.
peace
wwonka
wwonka is offline
Old 11-06-2003, 09:33 PM   #17
swzine
swzine is on a distinguished road
swzine's Avatar
Default
I have an 03 L200 as well and it was a real pain to get the lights off..you just need to pull a little hard. Remove the grill, remove the screws, lift the lever that is behind the grill, then pull really hard! Put the most pressure on the bottome corner where it seems to be secured. You'll see there is a metal pin that goes to the back. That is where it sticks. If you lift up a little from the front, on that spot, while pulling it will slide right off. It feels like it will break, but it doesn't. I was so pissed off when I tried to put my xenon bulbs in.
Then to top it off I had a pair of 9005 for the Low Beams and 9004 for the high beams as sylvania.com and every other manufacturer said the 03 L took. Once I opened it up I also found that it was H11. I bought some on Ebay manufactured by a company called XD5. They work GREAT! Very bright with a nice hint of blue but not too much.
"God Bless America, and no Place Else!"
-Head of State movie
Add to swzine's Reputation
Rate the quality of this post and help swzine reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
swzine is offline
Old 11-07-2003, 08:39 AM   #18
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Cool
Originally posted by swzine
I have an 03 L200 as well and it was a real pain to get the lights off..you just need to pull a little hard. Remove the grill, remove the screws, lift the lever that is behind the grill, then pull really hard! Put the most pressure on the bottom corner where it seems to be secured. You'll see there is a metal pin that goes to the back. That is where it sticks. If you lift up a little from the front, on that spot, while pulling it will slide right off. It feels like it will break, but it doesn't.
Thank you, thank you, thank you! 4 months later and now I know how to get to the high beam bulbs! It looks like I was not pulling hard enough (and lifting a little too).
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 11-07-2003, 07:59 PM   #19
wwonka
Default Hoen H11 Bulbs
I like these bulbs alot they are white
and they seem alittle brighter than the stock bulbs.
peace
wwonka
wwonka is offline
Old 11-08-2003, 01:31 PM   #20
swzine
swzine's Avatar
Default
It's unbelievable how hard it is to change the 03 bulbs. I know exactly how you felt. I didn't want to break anything so I was a little nervous myself. I searched all over the internet and couldn't find anything saying it was special, so I finally just decided if it breaks it breaks cause I'm doing what the manual says. Took me an hour to do the first bulb then less then 2 minutes on the second one Just need to get the hang of it. Maybe this will be on the TSB list one day.
swzine is offline
2003 L200, low beam headlight bulbs indigo L-Series Tech 5 01-12-2012 07:17 PM
headlight bulbs Garrick S-Series Tech 8 03-10-2008 11:55 PM
Headlight bulbs? gordonwd Aura General 6 04-04-2007 09:09 PM
Changing interior bulbs ShinyYellowVue Vue General 0 10-13-2006 04:30 PM
Possible to use 2 in one headlight bulbs? ProDarwin Mods and Performance 5 01-21-2003 07:05 PM
