Old 08-14-2001, 04:09 PM   #1
Emanuel
Emanuel is on a distinguished road
Default Hot headlight switch on L series
The left stalk on the steering wheel on my 2000 LS1 was getting rather warm when the headlights were on. Brought it to Saturn Service; they replaced the switch. Service manager said it was visibly 'cooked', and when they see that, they replace the switch.
However, he said the part had not been redesigned.
Two questions:
1. How common is this?
2. is there any fire hazard?
Emanuel is offline
Old 08-14-2001, 04:57 PM   #2
Three Rings
Three Rings is on a distinguished road
Default
It's a common problem with the L series. I had our switch replaced many months ago (2000 LS1).
Have not heard of any fires, I would hope the headlight circuit breaker would open before it got that bad.
Three Rings is offline
Old 08-14-2001, 10:59 PM   #3
Iceman
Guest
Posts: n/a
Default
My 2000 LW2, has had 2 of the headlight stalks replaced in the past 20 months...the last one was put in about 3 months ago.
Old 08-16-2001, 09:14 AM   #4
Tony
Tony is on a distinguished road
Tony's Avatar
Default
The headlight switch on my LS2 blew a 10 amp fuse that also feed the dash lights. It was replaced and no more trouble. However I do not believe that it got hot.
Tony is offline
Old 08-21-2001, 08:33 AM   #5
skijay
skijay will become famous soon enough
Default
My 2001 L100 had this problem develop within 1 week of ownership. The dealer I purchased my car from stated this was normal. While driving at night for three hours the stalk got so hot that it started to smell like melting plastic. I went to a DIFFERENT dealership and they said it was NOT normal and would order a new part. It was a "resistance" problem in the stalk. New part installed, Had no problems. TRY a different dealer.
skijay is offline
Old 08-21-2001, 10:21 AM   #6
tucker92sl2
tucker92sl2 is on a distinguished road
Default
I thought I read in a previous post about the Daytime Running light relay causing this. The post said that he removed the relay and jumpered together the 87/30 posts, keeping his both bright lights w/o having DRL's. But he also noted that the stalk didn't get hot anymore. Could it be the DRL relay? . I know GM use's the bright's with a lower amp for those. I think that car was a L-series also.
tucker92sl2 is offline
light switch is hot, also trac question hiswayne L-Series Tech 6 01-04-2009 06:13 PM
Hot light switch arm on 02 vue? bartt Vue General 19 11-15-2003 08:38 PM
Auto Headlight On-Off Switch ION Ion General 4 05-27-2003 10:00 AM
Headlight Selector Switch Hot Iceman General Saturn Discussion 56 02-15-2001 09:35 AM
Hot Headlight Stalk silverplum General Saturn Discussion 7 01-29-2001 11:19 PM
