Old 02-25-2008, 04:16 AM   #1
TIMSPEED
TIMSPEED is on a distinguished road
TIMSPEED's Avatar
1998 SW2
Default How-To: 4Hi Headlight Mod on S-Series with DRL's.
This is an addendum to Wolfman's how to...
His instructions for cars with DRL's is a little...well...vague.
So, I will give credit where credit is due...this wiring diagram was from member "LB_BlueVue".
He wrote this up for his Vue...but this is also the diagram for our S-Series with Daytime Running Lights.
I just did this, and it works perfectly.
The best part about this mod, is if either/both relay(s) fail(s) it will revert back to stock.
Also:
Chassis Ground = I used the nut on the top of the battery hold down.
12v+ = I used the lug on the back of the UHJB.
Materials:
Two 4-pin 30amp Relay's from Radio Shack
Approx. 10' of 16guage multistrand copper wire.
small pack of wire splices
small pack of female spade connectors
Connections:
Relay 1:
87- Connect to terminal #85 on Relay2 & Chassis Ground.
85- Connect to HighBeam ground. (May be pink)
86- Connect to 12v+. (Use Inline Fuse)
30- Connect to terminal #87 on Relay2.
Relay 2:
87- Connect to terminal #30 on Relay1.
85- Connect to terminal #87 on Relay1 & Chassis Ground.
86- Connect to ParkingLamp HOT. (Brown or Tan)
30- Connect to LowBeam ground. (May be blue)
Add to TIMSPEED's Reputation
Rate the quality of this post and help TIMSPEED reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TIMSPEED is offline   Reply With Quote
Old 02-25-2008, 08:57 PM   #2
TIMSPEED
TIMSPEED's Avatar
1998 SW2
Default Re: How-To: 4Hi Headlight Mod on S-Series with DRL's.
Would a mod please edit one line of this post
"Chassis Ground = I used the drivers side upper radiator mount nut"
Is what it SHOULD say for what Chassis Ground I used.
Old 02-25-2008, 09:26 PM   #3
jollyroger1210
jollyroger1210 is on a distinguished road
jollyroger1210's Avatar
You can edit your own posts, can't you?
Edit: I can.
'98 SC2 manual, red - Dads
'95 SL2 manual, green, new engine - sisters, soon to be mine
Add to jollyroger1210's Reputation
Rate the quality of this post and help jollyroger1210 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jollyroger1210 is offline   Reply With Quote
Old 02-25-2008, 11:55 PM   #4
quiksc2
quiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura about
quiksc2's Avatar
2002 L-Series 3.0L Sedan
Here's the instructions I used.
http://www.natwilson.com/stuff/malib...hts/index.html
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
Add to quiksc2's Reputation
Rate the quality of this post and help quiksc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quiksc2 is offline   Reply With Quote
Old 02-29-2008, 09:09 PM   #5
newsaturnguy
newsaturnguy is on a distinguished road
This looks like a great idea. Why not make the trigger for the relay the high beam its self? Would the day time lights not allow that?
Add to newsaturnguy's Reputation
Rate the quality of this post and help newsaturnguy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
newsaturnguy is offline   Reply With Quote
Old 03-02-2008, 07:48 PM   #6
ajs_saturn
ajs_saturn will become famous soon enoughajs_saturn will become famous soon enough
ajs_saturn's Avatar
2001 SC1
i just did this mod like 30 minutes ago. the chevy malibu concept didn't work, it just blew a fuse. TIMSPEED's concept worked however. great mod instructions. this is how mine ended up:
2001 SL1 5spd - DOHC swap and MS in the works
Bought 02/27/14
2000 SL 5spd
Bought 04/05/05
Sold 06/14/10
Add to ajs_saturn's Reputation
Rate the quality of this post and help ajs_saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ajs_saturn is offline   Reply With Quote
Old 03-02-2008, 10:31 PM   #7
TIMSPEED
TIMSPEED's Avatar
1998 SW2
Glad to help. Looks just like how mine is set up.
Old 03-03-2008, 12:31 AM   #8
TwinRevver
TwinRevver is on a distinguished road
I got a better mod which i did 2 days ago on an spare hdlight. I took the bracket for hi beam bulb out and put it in the low beam side. Then i trimmed the guide tab in the bulb socket(where the 2 prongs are at.) so that the connector would fit in properly. Same said for the low beam on the hi beam side. Hell u could get junker hdlt and put both hi beam brackets on so that u have 2 hi beam. I also had to drill an extra hole to get the connector to face downward and grind an alignment tab off. Easy half hour mod.
now with problems and getting a newer car but not a saturn :(
My 95 SL2 white top of the line car Priceless..
Add to TwinRevver's Reputation
Rate the quality of this post and help TwinRevver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TwinRevver is offline   Reply With Quote
Old 03-14-2008, 06:21 AM   #9
Dust
Dust is on a distinguished road
Has anyone done this with a full relay kit for the highs and lows for higher wattage bulbs?
Add to Dust's Reputation
Rate the quality of this post and help Dust reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dust is offline   Reply With Quote
Old 03-14-2008, 10:40 AM   #10
97sleeper
97sleeper is on a distinguished road
97sleeper's Avatar
I'm pretty sure that nothing changes with this mod if you throw on a high output relay harness. I thought about it and your still drawing a signal from the original plugs, therefore, all the relay harness will do is just get a better flow of power to the light bulbs.
A good Saturn is a good sleeper -J. Beanan
97 SL2
-N/A sleeper build, check my profile the list
93 Ford Exploder
-5spd 4WD 4.0L V6
-800W sound system
-4 100W lights
Add to 97sleeper's Reputation
Rate the quality of this post and help 97sleeper reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
97sleeper is offline   Reply With Quote
Old 03-17-2008, 03:13 AM   #11
quiksc2
quiksc2's Avatar
I did mine the Malibu way about a year or 2 afo, plus got rid of the DRLs, and never had a problem. I love it. Fogs stay on, low beams too, when I turn on the highs. I'm about to put on some high output fogs, so when I'm driving those dark country roads I will be able to see everything.
DCS
Old 03-18-2008, 10:38 PM   #12
geartooth94
geartooth94's Avatar
will either of these 2 different ways (Timspeed's or Mailbu) work on a car WITHOUT drls ?
Add to geartooth94's Reputation
Rate the quality of this post and help geartooth94 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geartooth94 is offline   Reply With Quote
Old 03-22-2008, 02:19 AM   #13
TIMSPEED
TIMSPEED's Avatar
1998 SW2
WITHOUT DRL's, you only need one relay.
Wolfman has the wiring diagram for that in How-To
Old 03-11-2009, 08:38 AM   #14
dcc81187
dcc81187 is on a distinguished road
1996 SC1
Great mod and a piece of cake
Add to dcc81187's Reputation
Rate the quality of this post and help dcc81187 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dcc81187 is offline   Reply With Quote
Headlight mod B.S.T. S-Series Mods 16 01-05-2011 10:35 PM
Headlight works with DRL's but not when switched on? -ed- S-Series General 2 07-28-2008 10:00 AM
How to do 4Hi Mod on a DRL Car?? TIMSPEED S-Series Tech 2 02-24-2008 05:57 PM
Disabling DRL's on 1994-2000 S-Series zippy_LiL_sL1 How-To Library 9 03-15-2005 11:06 PM
Another headlight mod KJB Vue General 13 01-30-2004 10:21 AM
