Old 01-09-2006, 03:21 PM   #1
burnout
burnout's Avatar
Default Clear Headlight Shell (Lens?)
There is dust in my headlights from when I drilled the hole for my strobe lights. (I'm an idiot.)
I fabbed up a coathanger + cloth method for getting the majority of it out, but its really hard going through the headlight hole.
How can I take off the clear shell on the front of the headlight? It looks to be melted on.
'13 VW CC 2.0T
'99 Volvo S70 AWD
Old 01-09-2006, 08:39 PM   #2
runerx
runerx is on a distinguished road
runerx's Avatar
2003 VUE 2.2L
Default Re: Clear Headlight Shell (Lens?)
Many lights are sealed together and if you heat them up, as in put them in the oven, you can soften the sealant enough to pry them apart. Usually you heat the lens pry back a few clips and pry the light apart. I believe I've heard of people doing this at the 150/warm setting. I'm sure others will chime in as to what temp to do this at.
People seperating glass lenses heat them at the lowest setting (150/warm on mine) for 45 min. this is with a GLASS assembly.
Good luck
Dave
runerx is offline   Reply With Quote
Old 01-09-2006, 09:26 PM   #3
Pilate
Pilate is on a distinguished road
Just did this to my Alero this weekend (plastic lens)...15 minutes at 170F. Then pryed em apart...pretty easy really. Be sure to clean out all the old silicon or glue and re-silicone them well when you're done to prevent moisture from entering.
Pilate is offline   Reply With Quote
Old 01-09-2006, 09:28 PM   #4
runerx
runerx's Avatar
2003 VUE 2.2L
I knew someone would have experience
Dave
Old 01-10-2006, 08:58 AM   #5
burnout
burnout's Avatar
Well it sucks that I'm going to be putting my headlights in the oven, but I have to do it.
Thank you!
'13 VW CC 2.0T
'99 Volvo S70 AWD
headlight lens billcannon791 S-Series General 7 11-10-2006 01:03 AM
FS: Clear corner lens for 2nd Gen SC Jason97SL2 Classifieds 8 10-28-2004 10:23 PM
Clear Corner lens installed digital919 General Saturn Discussion 0 07-13-2002 05:46 PM
clear lens, cheaper intakes, etc joeybagodonuts Mods and Performance 4 01-18-2001 11:06 PM
clear lens, cheaper intakes, etc joeybagodonuts General Saturn Discussion 5 01-15-2001 10:26 PM
