#21 |
Maybe check with the community college or university art department and see if they have glass blower?
Local artist or craftsperson might be willing to blow a clear glass lens for you. It's a longshot but I have always been curious how that would turn out.
I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles |
#22 |
The yellow egg yoke can be sanded out.
#23 |
![]() ![]() ![]() ![]() Join Date: Jun 2019
If you're referring to the amber "orb" corner lens in the 2000 headlight assembly, it looks to be glued in, but I haven't popped the lens off yet, so I can't say for sure
Or are you referring to the old 98 headlights? I know the discoloring can be sanded out, but that's not the issue at hand lol
98 SL2, 70k miles, kept in the family since new! Her name is Uranus :) |
#24 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2010
Absolutely amazing!
#25 |
![]() ![]() ![]() ![]() ![]() Join Date: Dec 2016
1998 SW1
2007 SKY Red Line
I happened to have found some on ebay last year and bought them immediately! I haven't seen any of them ever since. I swiftly installed 2.5" projectors. And yes this was for my 1998 SW1
#26 |
![]() ![]() ![]() Join Date: Sep 2019
I have also realized recently that my 98' SL2 has very weak lights. Sorry for hijacking the thread, but could anyone advise fog lights solution? I have holes in the front bumper for them. What would be the most elegant solution? I.e. where to put a switch and relay, etc. Maybe some links where to get bolt-on fog-lights? Thanks!
#27 | |
![]() Quote:
If you can find the same car as yours with fog lights in a junkyard then you should be good, you'd only need to take the wires, housing, and switch from the inside. It shouldn't take anyone more than an hour to get all of it in your own car.
'97 Saturn SL2 @ 146k (M. swapped) - In storage, awaiting an engine rebuild '99 Saturn SW2 @ 92k (M. swapped) - Daily Driver r/Saturn_Cars moderator |
#28 | ||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005
![]() Quote:
Another solution would be to change your headlight bulbs to HIR bulbs (9011/9012) or LED which both have more light output. Refurbishing your headlight lenses is also recommended if they are hazy.
1999 SL2 MT (287,130 km @ 10/2019) 2012 Ford Focus SEL HB MT 2011 Suburban LT Past Saturns 2001 SL1 MT (438,500 km 11y) 1993 SW2 AT (10y) 2001 LW200 MT (3.5y) 1992 SL2 MT (5y) :canada: Last edited by trottida; 10-22-2019 at 09:32 AM. |
#29 |
#30 |
You may have problems with the high beam bulb if your car is configured with DRLs. The DRL configuration is just a lower power supplied to the high beam bulb. With an LED the lower power will make them flicker or not work at all. I suppose you can disable DRL's using the bent pin method on the relay in the UHJB. I can't remember when DRL's were mandated in the US and which S Series would have them. In Canada we've always had them 91-02 S Series.
1999 SL2 MT (287,130 km @ 10/2019) 2012 Ford Focus SEL HB MT 2011 Suburban LT Past Saturns 2001 SL1 MT (438,500 km 11y) 1993 SW2 AT (10y) 2001 LW200 MT (3.5y) 1992 SL2 MT (5y) :canada: |
#31 |
To date, the USA federal regulations does not have mandatory daytime running lights.
#32 |
#33 |
So the DRL's are not enabled in S Series sold in the USA from 91 through 2002 then?
#34 |
![]() ![]() ![]() Join Date: Apr 2008
They are on, but it's not "mandated" by Gov't.
Proud Owner of an Invincible '98 SC2 Rare "Red Hot" 5-Speed. Castrol Edge EP + M1 Ext Perf. Oil Filter. Owned 4 other S-Series. |
#35 | |
![]() Quote:
GM thought adopting DRLs from European lighting would prompt US legislators to make it into law as a safety issue - headlights may get the attention of drivers but hasn't been proven. During this phase of adapting drls for the US market, GM decided to be creative and save money. Creative by not standardizing wiring from one model to the next (S, L, Aura, Ion, Outlook) and selecting low, high or turn signal lights. Saving money by not using HID lights or leds. Saving money meant using halogen lamps in series or parallel wiring (with a resistor) in drl mode. Halogen lamps remain bright in series or parallel with resistor during daytime running without dimming, lamp life is prolonged. Some models use high beams while others use low beams in drl mode. |
#36 | ||
![]() Quote:
The OP's best bet if he wants to run LED is to disable the DRL. There are good instructions with photos of one method here >> https://www.saturnspot.com/disabling...ng-t25662.html. I have copy/pasted it below should the site every disappear. Text will show but photos may be gone. Quote:
#37 |
DIYguy has a better solution (IMO) than bending the pin - small jumper wire, post 11 here
http://www.saturnfans.com/forums/sho...pass+DRL+relay You could also wire the jumper with a switch so you can have/disable DRL with a flick ![]()
#38 |
When I replaced my daytime running lights/high beam lights with LED lights, I did not have to do anything special other than reuse the original O-rings from the original incandescent bulbs. The O-rings that came with the LED lights were too thick. The only drawback with the LED lights is that they remain at the same intensity regardless of whether or not you activate the high beams.
#39 |
![]() ![]() Join Date: May 2004
I bought Clear-Lens headlamp assemblies for '97 Gen2 at CarID.
They were cheaper than the certified variety, and did not yellow. Not sure if the lenses were fluted... lost the car. |
#40 |
Bookmarks |
Clear Headlight Shell (Lens?) | burnout | Vue General | 4 | 01-10-2006 08:58 AM |
FS: Clear corner lens for 2nd Gen SC | Jason97SL2 | Classifieds | 8 | 10-28-2004 10:23 PM |
Clear Corner lens installed | digital919 | General Saturn Discussion | 0 | 07-13-2002 05:46 PM |
clear lens, cheaper intakes, etc | joeybagodonuts | Mods and Performance | 4 | 01-18-2001 11:06 PM |
clear lens, cheaper intakes, etc | joeybagodonuts | General Saturn Discussion | 5 | 01-15-2001 10:26 PM |
