Old 03-31-2007, 03:10 PM   #1
diablo2070
diablo2070 is on a distinguished road
diablo2070's Avatar
2008 Astra XR
Default EGR Valve cleaning
I remove my EGR Valve to clean it since it had probably never been done, and know I have a few questions:
1) I don't have "carb cleaner", can I use lighter gas instead? Will it do the same job?
2) On the little how to, it says to clean the little part with an arrow
The big hole above that on the picture, in my case, is full of carbon inside, it's like carbon catacombs Well there is enough space for the air to go through, but there is a carbon coating of about 2-3mm even inside the hole. Is it important to remove that for the egr valve to work well? Can I just put some lighter gas in and shake it or I'll break something?
Add to diablo2070's Reputation
Rate the quality of this post and help diablo2070 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
diablo2070 is offline   Reply With Quote
Old 03-31-2007, 03:39 PM   #2
diablo2070
diablo2070's Avatar
2008 Astra XR
Default Re: EGR Valve cleaning
Oh another question, if my gasket seems not that bad, is it bad if I keep it? I need to put my EGR back for tonight because I have to use my car.
Old 04-02-2007, 12:44 PM   #3
BarnOwl
BarnOwl's Avatar
It's a little late but, since no one answered, I'll try. You want to get the end of the pintle and the part the pintle seats in clean. Compressed air and dental picks will work. Scrubbing with a solvent will work. If by lighter gas, you mean butane, I don't think so. Naptha for Zippos might work. You can reuse the gasket, if it looks okay.
Add to BarnOwl's Reputation
Old 04-02-2007, 01:15 PM   #4
quiksc2
quiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura about
quiksc2's Avatar
2002 L-Series 3.0L Sedan
I would scrape the buildup out of the bigger hole, too. I just cleaned my EGR yesterday, hoping to fix my loss of power problem. I had carb cleaner laying around, I used tons of that and a screw driver to work the pintle and scrape around it.
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
Add to quiksc2's Reputation
Rate the quality of this post and help quiksc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quiksc2 is offline   Reply With Quote
Old 04-02-2007, 06:19 PM   #5
diablo2070
diablo2070's Avatar
2008 Astra XR
Ok thanks for your answers. By lighter gaz I was not talking of butane but gaz like in zippo. It's a blue bottle of the "IT" brand. I often use that to clean stuff, like glue, grease, fresh paint where I don't want the paint to be , etc. so I was thinking it could work.
From what you've said.. I will have to clean it again, I didn't have enough lighter fluid (only a bottom of bottle) so I only cleaned the pintle and the outline of the bigger hole, but not the "part the pintle seats in".
Old 04-02-2007, 08:11 PM   #6
Go buy some air intake cleaner.
Lighter fluid is just to flameable to use safely. The intake cleaner is designed more for dissolving carbon as well. Any parts house/Canadian tire will have some.
Add to ssicarman's Reputation
cleaning egr valve bdobraj S-Series General 11 04-07-2013 09:41 PM
EGR valve cleaning abinder S-Series Tech 9 10-22-2008 04:57 PM
EGR Valve Cleaning clickclickw00t S-Series Tech 1 05-30-2007 02:14 PM
EGR Valve Cleaning - HELP! LaraKimbo S-Series Tech 5 05-12-2007 11:13 AM
Cleaning EGR valve wolfehunter S-Series General 9 07-18-2006 10:03 PM
