Old 11-21-2004, 03:20 PM   #1
SimPlyxTriPPiN
SimPlyxTriPPiN is on a distinguished road
SimPlyxTriPPiN's Avatar
1995 SC1
Dizzy cleaning iac valve
i've seen from many of the thread that cleaning the iac kinda helps the performance of the car. so my problem is this.... i have no idea that the iac valve is. i've erad that it's really easy to do. can somebody please tell me how to
Add to SimPlyxTriPPiN's Reputation
Rate the quality of this post and help SimPlyxTriPPiN reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SimPlyxTriPPiN is offline
Old 11-21-2004, 06:55 PM   #2
Default Re: cleaning iac valve
Cleaning it does not improve performance of anything except the perhaps the idle. The IAC is the idle air control valve. It allows a controlled amount of air to by pass the throttle plates to maintain a steady idle. If the [assages or the valve get gummed up the idle quality can suffer. Depends on the year and model where the passage is. On multiport injected engines (Saturn S-series) it is in the throttle body bottom just before the throttle plate.
Add to ssicarman's Reputation
ssicarman is offline
Old 11-21-2004, 08:38 PM   #3
SimPlyxTriPPiN
1995 SC1
i wasn't talking about the speed performance. i was talking about how my car should perform.
Old 11-21-2004, 09:56 PM   #4
sierrap615
sierrap615's Avatar
most S-series have this design throttle body
http://www.saturnfans.com/photos/sho...p/photo/15887/
remove intake tubing
spray with sensor safe carb and choke cleaner
work throttle plate by hand
spray some more
start engine
thats basicly it.
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline
Old 11-21-2004, 11:54 PM   #5
SimPlyxTriPPiN
1995 SC1
sounds really easy. but where do i spray. sry, i really had no idea before.
Old 11-22-2004, 02:38 AM   #6
sierrap615
sierrap615's Avatar
inside the bore of the throttle body, trust me you'll see carbon in there,about 1/2 of a inch in front of the throttle body there is a hole/passage with the diameter just smaller then a pencil IIRC, the IAC is in the bottom of that hole, so spray there too.
Old 11-29-2004, 12:38 AM   #7
Henry_02SC1
Henry_02SC1 is on a distinguished road
Henry_02SC1's Avatar
2006 ION-2 Sedan
A few months ago, I had to have the IAC valve replaced. This was in the 2002 SC1. What happened was that, at times, my engine would be idling higher than it should. It was an intermittent problem for a long time, and the dealer could not replicate it. Finally, after a service visit, it finally replicated and I was able to drive it back to the dealer to show them. It did go back to normal several times, but it went back to doing it when I got there.
The first thing they did was try to lower the idle speed by hooking up my car to some little machine (have no idea what it is called) but to no avail. The took my car in and found that the burrs were worn on the IAC valve and they replaced it. Thankfully, it was reported way before the warranty expired. Even though my car was out of warranty by the time the cause was found, they still had to cover it. Yay!!
Henry
Owner of a 2006 ION 2 Sedan (Silver Nickel)
Previous Saturns:
-2004 ION 3 Quad Coupe (Silver Nickel)
-2002 SC1 (Blue)
Add to Henry_02SC1's Reputation
Rate the quality of this post and help Henry_02SC1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Henry_02SC1 is offline
Old 11-29-2004, 11:23 PM   #8
sierrap615
sierrap615's Avatar
they were using a special GM/Saturn scantool called the Tech2, with it you can manually control the signal to the IAC
Old 11-30-2004, 11:38 AM   #9
Qlara
Qlara's Avatar
SO guess the IAC is one of the warranty items.
The high-idle surge problem is one of the infamous thread for later S-series here. IAC is the culprit looks like.
Add to Qlara's Reputation
Qlara is offline
Cleaning the IAC/TB peterseb S-Series General 1 11-09-2005 03:53 PM
Iac Valve Cleaning?? sp33doe L-Series Tech 20 09-29-2003 02:16 PM
cleaning TB, IAC Zigmund555 Miscellaneous Tech 5 07-01-2003 06:32 PM
Cleaning throttle body/IAC advice please auxmike S-Series Tech 6 01-26-2003 09:46 AM
Cleaning the Idle Air Control (IAC) valve Heartbeat - '95 SL2 Miscellaneous Tech 5 05-29-2001 04:29 AM
