Old 04-13-2006, 05:33 PM   #1
TXTABBY
TXTABBY is on a distinguished road
TXTABBY's Avatar
Question SL2 Belt Tensioner Pully
I was looking for a rattle at acceleration (from a stop, AC on) and saw the bolt on my belt tensioner pully doing a dance, up and down. It wasn't turning/loosening and the pully itself looked rock-solid as it was turning. Take it in and have the pully tightened/replaced?
I read up on how to change the tensioner...I don't have any jackstands yet to get underneath and fix it otherwise I would...thanks.
Usetahave 1994 SL2 105,000 mi. avg. 29-30 mpg
Austin, TX
Add to TXTABBY's Reputation
Rate the quality of this post and help TXTABBY reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TXTABBY is offline   Reply With Quote
Old 04-13-2006, 06:35 PM   #2
katarn444
katarn444 is on a distinguished road
Default Re: SL2 Belt Tensioner Pully
You should be able to tighten it from the top. Both the idler and tensioner pulleys can be pulled from the top.
K
Add to katarn444's Reputation
Rate the quality of this post and help katarn444 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
katarn444 is offline   Reply With Quote
Old 04-14-2006, 12:24 AM   #3
Assuming that you mean the pulley bolt and not the tensioner hold down bolts. The tension (pulley) will normally have some movement up and down with the engine running. If the spring is weak though it can dance enough to cause a noise.
Engine running CAREFULLY take a long screwdriver or pry bar and place the end of it on the pulley bolt. Push down and see if the noise changes or goes away with the dampening pressure of the bar on the pulley.
Don't get mutilated doing this.
Add to ssicarman's Reputation
Old 04-14-2006, 06:35 AM   #4
TXTABBY
TXTABBY's Avatar
NO KIDDING! I'll try it, but am almost positive it's the pulley bolt. As I said above, the pulley itself is "rock-solid" as its turning, meaning it's not doing the "dance", but the bolt itself is jumping up and down some. Sears has a sale so I'm going to pick up a set of metric ratcheting box-end wrenches and some jack stands today.
Gotta start doing more of the routine maintenance myself...
Austin, TX
Old 04-14-2006, 09:45 AM   #5
Luke
Luke's Avatar
As I'm sure that the following is well known, but just to remind, the bolt holding down the pulley component of the tensioner unit, tightens by turning it counter-clockwise.
With this in mind, usually the accessory belt riding on the pulley itself, thus, usually results in the bolt not working itself loose.
BTW, not that it needs it, but I can confirm S Siscarman's commentary regards:
, for I did that very procedure just last weekend.
Add to Luke's Reputation
Luke is offline   Reply With Quote
Old 04-14-2006, 11:29 AM   #6
TXTABBY
TXTABBY's Avatar
Just took another look at it...and I'll still see if it needs tightening, but yea, kinda hard to understand how something that's running in the same direction to tighten it can loosen up. I did the above procedure and no change. Now, off to Sears...
Austin, TX
Tensioner rattle is back -- even with new AC Delco tensioner and belt! 2003MercMaraude S-Series Tech 18 10-15-2010 07:23 PM
tensioner pully noise 2RINGS L-Series Tech 3 02-15-2009 05:14 PM
OEM belt tensioner for SL2 mabu_888 S-Series Tech 21 10-20-2007 07:26 PM
The Best Tensioner and Idler Pully choices ? SaturnSid S-Series General 9 05-14-2007 08:46 PM
Serpentine Belt Idler Pully Question Reno Miscellaneous Tech 9 12-02-2002 08:12 PM
