Old 02-10-2009, 12:19 PM   #1
2RINGS
2RINGS is on a distinguished road
2000 L-Series 3.0L Sedan
1997 SL1
Default tensioner pully noise
Hi all! I have a 2000 ls2. The tensioner is squeaking. I think its' a bearing. Can you replace just the bearing on this item. The belt has good tension so I know the spring is in good shape. I read you can replace the bearing on other saturns but this engine is different.
Add to 2RINGS's Reputation
Rate the quality of this post and help 2RINGS reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2RINGS is offline   Reply With Quote
Old 02-10-2009, 12:52 PM   #2
KLS1P
KLS1P is on a distinguished road
2004 L-Series 3.0L Sedan
Default Re: tensioner pully noise
You can replace just the pulley / bearing. I suggest you replace the whole tensioner / pulley assembly. The whole assembly costs more but the labor is about the same. My experience with belt tensioners shows the spring / pivot assembly becomes stiff or just locks up, causing little or no tension on the belt. Squeek and Slip. Try Rockauto.com.
Add to KLS1P's Reputation
Rate the quality of this post and help KLS1P reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KLS1P is offline   Reply With Quote
Old 02-15-2009, 03:04 PM   #3
jimschaechter
jimschaechter is on a distinguished road
I have a 2000 LS witrh the 3.0. Sounds to me like I have a tensioner bearing going. I think there are 2 pulleys. One is the tensioner and one that is just a non adjustable pulley. I will have to pull the belt to otest, but wonder what the norm is here. Is it pretty common for one or the other to go bad or both? These both dealer items? 140k on the car. Thanks, Jim
Add to jimschaechter's Reputation
Rate the quality of this post and help jimschaechter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jimschaechter is offline   Reply With Quote
Old 02-15-2009, 05:14 PM   #4
Ex-GMtech
Ex-GMtech has a spectacular aura aboutEx-GMtech has a spectacular aura aboutEx-GMtech has a spectacular aura about
2000 L-Series 3.0L Wagon
There is one tensioner and that is it. The only other pulley that is on the front is the water pump. It is under the front engine mount. If the water pump pulley wobbles, you need to replace the pump. While in there, replace the timing belt, tensioner and idler pulleys.
OMG this car is easy to work on!
2000 LW2
2016 Impala
1986 GLHS
Add to Ex-GMtech's Reputation
Rate the quality of this post and help Ex-GMtech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ex-GMtech is offline   Reply With Quote
Chirping Noise w/ AC on @ Idle Only- Is this my tensioner? Leadsled Coupe S-Series General 3 07-02-2007 06:26 PM
The Best Tensioner and Idler Pully choices ? SaturnSid S-Series General 9 05-14-2007 08:46 PM
SL2 Belt Tensioner Pully TXTABBY S-Series Tech 5 04-14-2006 11:29 AM
Belt tensioner makes noise and rattles Dingo Warrior S-Series General 4 10-20-2005 10:13 PM
Belt noise solution &Tips on changing tensioner auxmike Miscellaneous Tech 0 02-28-2003 04:44 PM
