Old 10-20-2018, 10:41 PM   #1
velocast
velocast has a spectacular aura aboutvelocast has a spectacular aura aboutvelocast has a spectacular aura about
Default Astra ECM or ECU Replacement
Astra ECM or ECU Replacement GM 55564092
The Engine Control Module ECM or Engine Control Unit ECU is the brains of the engine management system. ECM failure is very common problem of all 1.8 Astras with the same engine system type. The failure is caused by the ECM design and location, because it cannot dissipate heat naturally combined with corrosion, engine vibration, and extreme temperature differentials.
Europe’s experienced shops, articles will say the fault usually displays warning lights all over the place with a huge range of faulty codes blaming the electronic throttle body, air temperature sensors, etc. Yes, they will always confirm: It is a major Astra well-known problem.
We have 2 options:
1) Get your own one repaired or rebuild with refreshed software (no programming or coding needed). Send to the UK and get back ready to install plug and play, save money!
2) Get a new ECM fitted and programmed by the dealership. Expensive! Does not guarantee back to the original state, due to the lack of tech support.
I usually commute with my Astra full year-round from cold winters to hot summers (0 F - 100 F). I will wash my engine at least 3 times in a year. After 10 years may the ECM seals become worn out? So, moisture may corroded the ECM? Or, probably due to the upgraded sound system, steering wheel stalk, hid headlights, hid fogs, faulty relays, fuses, bad connectors, etc the loaded software may become corrupted and unstable?
When I was working in my fogs, I had to turn on the engine. Little after that my engine start to run very unstable: The amber engine light come on, the recharging red battery light was flashing, the idle needle indicator was near 2000 rpm unstable, etc. A complete mess! Right there it was pointing to an electronic failure. It was about to happen anytime, anywhere! So, I had to tow back to the dealership. In few days will be ready.
My suggestion to you is to be aware of the ECM failure.
Add to velocast's Reputation
Rate the quality of this post and help velocast reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
velocast is offline   Reply With Quote
Old 10-21-2018, 03:33 PM   #2
AstraFasta
Default Re: Astra ECM or ECU Replacement
Maybe not fully related. But alternative issue. . .
Moisture seems to migrate into the black fuse box which is located under the hood, near the windscreen. Happened to me probably twice. The typical codes I have seen include "throttle position sensor" but there have been others. Drying the box and components resolved all codes.
Not sure where the moisture comes from. Vibration seems to loosen the two plastic clips a few times so I am always checking to make sure that box is securely closed. Also someone changing a battery or disconnecting the battery etc. might inadvertently dislodge the black cover.
The black 0-ring gasket is rather suspect. I make sure that is seated correctly. A similar 0-ring was poorly aligned on the cabin air intake at the firewall of my Astra and killed a few resistor packs & fans. I fixed that by realigning the 0-ring and adding a bunch of silicone. It was a rather painful effort but only took a few hours.
There is also the possibility water migrates from below into the box.
There are some posts here showing a few easy steps to disassemble and dry the box and components out. They have worked for me.
A more permanent fix might be to add a thin bead of silicone to help the 0-ring and add a few zip-ties to make sure the box is closed. I have not done either so don't have an opinion either way.
Add to AstraFasta's Reputation
Rate the quality of this post and help AstraFasta reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-23-2018, 11:51 PM   #3
FreedomSoftware
FreedomSoftware will become famous soon enough
2008 Astra XR
This could be the issue with my codes. For the last 3 winters (well just colder weather in general, 50F or below) my check engine light always comes on and gives me throttle position sensor and MAF. Weird as the lights go away when it starts to warm up. Also I have replaced my TPS 2 times now (second time under warranty). Usually ends up giving no response until about 50% or more. Ill check mine out tomorrow as I just washed the motor of my car a few days ago.
'08 Saturn Astra
-Debadge
-Vauxhall Grille
-Thule Roof Rack (and wind fairing)
-1.25" Lowered
-Windows Tint all around
-JVC Head unit
-Dual 12" Subs
Add to FreedomSoftware's Reputation
Rate the quality of this post and help FreedomSoftware reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FreedomSoftware is offline   Reply With Quote
Old 10-24-2018, 02:15 PM   #4
AstraFasta
This simple guide with lots of photos helped me
https://www.vauxhallownersnetwork.co...fira-b.371985/
Also see posts #17 & 18 below
http://www.saturnfans.com/forums/sho...d.php?t=208132
Finally, for fun you also can clean the MAF carefully, but use ONLY MAF spray as other chemicals will kill the delicate wires. While you are at it, you might replace your air filter and clean the throttlebody. Make sure to tighten the pipes and airbox well. These may be unrelated to your current issues but are popular Astra issues so worth the time once you get the UEC sorted.
Old 10-25-2018, 08:50 PM   #5
velocast
I just got back my Astra running strong full power like always does – sometimes intimidating. Of course, without any issues!
Here is what the dealership did:
-Diagnostic Codes P2119, P2100 for throttle body failure
-Checked throttle body’s wiring and connectors
-Checked ECM’s wiring and connectors
-Replaced ECM and programmed
-Original throttle body reset still Codes coming
-New ECM throwing transmission related Codes
-Replaced with new throttle body and reset Codes
-Found 20-amp ignition fuse missing
-Replaced fuse: idle reset OK; reinstalled original ECM and re-programmed OK; Road test OK; No DTCS RESET OK
Shocking, the dealership ADDED A FUSE ON LOCATION 19. Our owner’s manual does NOT show all the fuses and relays for the XR and XE versions (see page 9-35). It is bit misleading!
Opel Astra H variant 1 shows fuse on location 19 is for the transmission electronics (30-amp). That is maybe the reason why my transmission is little bit smooth and responsive. Anyway, is running like always does! Good for me!
Just in case I will replace the new 20-amp fuse for a 30-amp.
Old 08-24-2019, 12:04 AM   #6
velocast
Default Re: Astra ECM or ECU Programmed
Solved: New ACDELCO 55564082 Electronic Computer Monitor (ECM) Programmed
When you are working with electrical related parts always disconnect the battery! I remember my ECM got crashed because I did not disconnect the battery when I replaced my Throttle Body, Headlight Switch, and Headlamps all at the same time (my stupidity). The dealership had hard time but got reprogramed using the same old ECM. Back then, they could not program the new one ACDELCO 55564082.
You can find the ACDELCO 55564082 at rockauto.com
That ECM can be programmed by the dealership. If they tell you “can’t do it,” you tell them, yes it can be done with the GM Service Bulletin No 16-NA-165. Here is the link to print out so you can give to them
https://static.oemdtc.com/TSB/SB-10108636-9340.pdf
Date May, 2016
Old 08-25-2019, 08:28 PM   #7
Astra08
Astra08 is on a distinguished road
Astra08's Avatar
2008 Astra XR
Good info to have on hand, thanks.
Dealerships view the Astra as a UFO these days. Any info you have at hand is useful.
Add to Astra08's Reputation
Rate the quality of this post and help Astra08 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Astra08 is offline   Reply With Quote
Astra starter replacement. Forrestusarmy Astra Tech 0 05-13-2018 04:12 PM
Astra XR stereo replacement hanson18 Astra General 6 04-23-2016 01:44 AM
astra ah engine replacement. qastra Astra Tech 2 01-31-2014 04:55 PM
Help me choose a worthy Astra replacement? Suns_PSD Astra General 43 09-18-2010 05:11 PM
And the best match for GM replacement to the Astra is... oilburner Astra General 22 05-06-2010 11:05 PM
