#1 | ||||
![]() Join Date: Jul 2003
2008 Astra XR
2002 L-Series 2.2L Sedan
![]() My car has one.
![]() ![]() ![]() To display... 1. The radio must be ON (turn the volume all the way down so you can hear) 2. Hit MAIN so you're on the main page. 3. Hold down SETTINGS for about 5-6 seconds, until you hear a beep. 4. Press BC. You'll initially come up with the regular board computer screen. Continue hitting BC to step through the test mode screens (there's about 7 screens). I don't have the slightest idea what most of the other indications on the other pages are for. edit... It looks like "display" is the temp displayed on the screen (22C = 71.6F). Looking at the UK site, I guess the sensor temp is temperature without error correction from engine heat. To get out of test mode, repeat steps 2 and 3 (you must be on the main screen when you hold down SETTINGS, or it won't work). Found the basic instructions here. They took some tweaking before I got it to work on my car. ... The family: 1993 SL2: 051,000 mi (!) 1996 SL2: 260,000 mi (sold) 2001 SL2: 98,000 mi 2002 L200: 215,000 mi 2006 VUE: 50,000 mi (sold) 2007 Ranger: 40,000 mi 2008 Astra: 161,000 mi Last edited by L200Pilot; 04-14-2008 at 01:04 AM..
#2 | ||||
![]() Test mode? I'm going to have to play with this in the morning, nice find.
... I used to beat up cars, then I got a Saturn. -Bitz
#3 | |||||
2008 Astra XR
![]() Quote:
![]() ... The family: 1993 SL2: 051,000 mi (!) 1996 SL2: 260,000 mi (sold) 2001 SL2: 98,000 mi 2002 L200: 215,000 mi 2006 VUE: 50,000 mi (sold) 2007 Ranger: 40,000 mi 2008 Astra: 161,000 mi
#4 | ||||
![]() Join Date: Jan 2008
![]() They are not. If you fiddle with the throttle, brakes and steering you can see alot of other values too, traction control etc...
... 2007 OPEL Astra Diesel
#5 | ||||
![]() ![]() ![]() ![]() Join Date: Aug 2001
2007 AURA XR
2008 Astra XE
![]() Should'nt have to fiddle with 7 screens & myriad of menu options to find out what coolant temp is.
![]() You should be able to glance over @ something next to the gas gauge. ... 93 SW2 96 SL2 01 SL2 02 L200 08 Astra Xe 07 Aura XR Complacency leads to mediocrity. Mediocrity leads to our demise.
#6 | ||||
![]() It's called "slipstreaming driver sensor inputs".
![]() Another word for it is "penny pinching". ... 2007 OPEL Astra Diesel
#7 | |||||
2007 AURA XR
2008 Astra XE
![]() Quote:
![]() Gauges should be easy to read and readily available to the driver without having to distract them. Information should be right there, not having to jump thru hoops and take your eyes off the road. Its bad enough manufacturers have removed voltage & oil pressure gauges & replaced them with idiot lights. ![]() What 's next: a gas guage that can be only read by checking your latest e-mail from On-Star? ![]() If it's penny pinching, then why did they give us "tire pressure monitors" instead? ... 93 SW2 96 SL2 01 SL2 02 L200 08 Astra Xe 07 Aura XR Complacency leads to mediocrity. Mediocrity leads to our demise.
#8 | ||||
![]() Join Date: Dec 2007
![]() Given the amount of electronics in this car, coolant temp should be a simple digital read out on the main gauge panel. If it can display what gear the transaxle is in, the coolant temp should be a piece of cake, since the system knows what the temp. is anyway. It would not take up much real estate on the instrument dash panel. Since this is such a driver's car, it is not penny pinching, it's bad engineering/design. Wonder if they were trying to copy BMW's iDrive?
... What's in your garage?
#9 | ||||
![]() Join Date: Mar 2008
2008 SKY
![]() Thanks!! Good find. I'll have to play with this.
A software change is all that would be required for critical parameters to be displayed on the main page (oil pressure, coolant temp, Tire pressure, etc.....) and would save money since no additional hardware would be required (i.e. gauges). Obviously the computer is already processing the data, its just a matter of displaying it. ... 2008 Sky 5-speed triple black 2008 Astra 5-speed 3 door star silver, Leather, 18" wheels http://s282.photobucket.com/albums/kk266/BlackStar_1961/Astra/
#10 | ||||
![]() Tire pressure monitoring system will be a requirement in all new vehicles in the US starting in 2009, so most manufacturers have already put them on their cars and then brag about the "new feature."
... ..... 2008 Twilight Blue Saturn Astra XE, 5-sp manual, a/c, and loads of fun
#11 | |||||
2007 AURA XR
2008 Astra XE
![]() Quote:
Is GM is so cheap they can't put a $3 guage in? ... 93 SW2 96 SL2 01 SL2 02 L200 08 Astra Xe 07 Aura XR Complacency leads to mediocrity. Mediocrity leads to our demise.
#12 | ||||
![]() Join Date: Apr 2004
2008 Astra XR
![]() This is all fine and good if you have the advanced audio system. Mine has the standard audio and doesn't have those other screens. Suggestions anyone?
... Rex 2008 Astra XR 5 dr, 5 spd, sport package Black Sapphire If you're going to wave, use all your fingers.
#13 | ||||
2008 Astra XR
![]() Hit the link in the original post. Is that the same one as yours?
#14 | |||||
![]() Quote:
i think that the dash is fine as is, i like it nice and cleen no clutter, simple.... i kinda wish that the tach was on the right than on the left. because when i was doing my test drive in it i kept looking at the tach when i wanted to see how fast i was going
#15 | ||||
![]() Join Date: Dec 2005
![]() This is a cool find, not to hard to get it either.
Does anyone know what the different screens are and the values displayed?
#16 | |||||
![]() Quote:
Unless they changed something of course... ... 2007 OPEL Astra Diesel
#17 | ||||
![]() Quite a few cars don't have temp gauges anymore.
... "That government is best which governs not at all; and when men are prepared for it, that will be the kind of government which they will have" - H.D. Thoreau
#18 | ||||
2008 Astra XR
![]() No it isn't. I don't have a "main" screen. Mine is the "opera 30" system.
#19 | |||||
![]() Quote:
I just did it from the default screen. I assume that is what the "main" screen is. It worked fine for me and I have the Opera 30 system as well. My displays like this one ![]() ... 2008 Saturn Astra XR 3 Door - Saphire Black 1999 Chevrolet Cavalier Z24 - White
#20 | ||||
2008
![]() anyone wanna post/find out what each screen is for....
... 2008 Astra XR5 Twilight Blue ---I hate being a mod-inclined person w/o the money/time to do any of it---
Changed coolant, temp gauge reads warmer | mr18436572 | S-Series Tech | 10 | 11-25-2009 09:58 AM |
Coolant Temp Gauge | kevinthenerd | Ion Tech | 5 | 05-09-2007 08:01 PM |
Flashing warning light above coolant temp gauge | SLoneDC | S-Series Tech | 15 | 04-06-2007 07:32 PM |
Does Temp Gauge Read Right When Low on Coolant? | spencerb | S-Series Tech | 11 | 12-09-2004 12:48 PM |
Coolant Temp Sensor - Fan or Gauge? | petemcs | Miscellaneous Tech | 3 | 01-05-2004 11:37 AM |
