Closed Thread
Old 09-22-2000, 03:40 PM   #1
Brianmc
Brianmc is on a distinguished road
Default What is a pinch nut?
Here's a good one for all of you-- I'm changing the badges on my Saturn- actually, I have to replace all of them because of vandalism (they were ripped right off, and gone forever). Now, I bought black ones from SPS, and in the instructions, it says to just use the pinch nut but obviously I haven't got any. My question is: Can you just buy these at Home Depot, and if not, should my local Saturn retailer have them? What should I ask for, because when I went to one Saturn dealer, they told me that, "Glue is how they stick on. That's the way they do it at the factory."
Thanks,
Brianmc
93 SL2
Add to Brianmc's Reputation
Rate the quality of this post and help Brianmc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Brianmc is offline
Old 09-22-2000, 05:38 PM   #2
Eddie
Eddie is on a distinguished road
Default
Pinch nut? ... hmmmm ... when I had to replace mine, I got the new emblem from the Saturn retailer and also got the "speed nut" from them too. Looks like a regular nut, just stamped from a piece of sheet metal ... you can get these from the hardware store. Perhaps the pinch nut is along the same lines ... however, it may be the rectangular piece of sheet metal that has a slight bow to and a hole in the middle ... once pressed on, if you try to pull it back, the two fingers in the middle will pinch together on the plastic stud. The retailer told me NOT to use glue.
Eddie
Add to Eddie's Reputation
Rate the quality of this post and help Eddie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Eddie is offline
Old 09-22-2000, 08:27 PM   #3
Diggs
Diggs is on a distinguished road
Diggs's Avatar
Default
OK. Envision this - Tight (no, I mean REALLY tight) leather pants. You've had them for 15 years. You've been getting just a bit wider in the back end. Squeeze into those pants and voila - Pinchnuts.
As said by someone else on the board - Sorry, TDMMDI.
Diggs
Add to Diggs's Reputation
Rate the quality of this post and help Diggs reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Diggs is offline
Closed Thread
bent smashed pinch welds saturnsctwo S-Series General 5 06-25-2008 12:52 AM
Failing Pinch Weld? e.e Zero_DgZ S-Series General 3 08-21-2006 04:52 AM
