Old 01-22-2018, 01:30 PM   #1
Johnsonjf
Johnsonjf is on a distinguished road
Default Code P0420
I have a 2008 Saturn Vue Redline with 193K miles. Iím getting code P0420, Iíve replaced the O2 sensor and still have the same code. Is there any thing else I can do to fix this or is replacing the catalytic converts the only option?
Thank you,
Jeff
Add to Johnsonjf's Reputation
Rate the quality of this post and help Johnsonjf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Johnsonjf is offline   Reply With Quote
Old 01-22-2018, 06:24 PM   #2
guyg
guyg will become famous soon enough
1997 SW2
2007 VUE 3.5L
Default Re: Code P0420
Carefully check for small exhaust leaks between the front and rear O2 sensors, especially the flex hose. A shop vac can supply air to pressurize the exhaust, use a soap and water solution to check for any bubbles. Any slight leak may set a code.
Add to guyg's Reputation
Rate the quality of this post and help guyg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
guyg is offline   Reply With Quote
Code p0420 rockrtboy S-Series Mods 0 08-20-2016 12:07 AM
P0420 Code Help havok Vue Green Line 8 07-16-2015 11:49 AM
code P0420 Need help brianolda S-Series Tech 6 11-10-2011 12:39 AM
98 SL2 Code P0420 Snipew4 S-Series Tech 20 06-07-2008 09:14 PM
Another P0420 code alleninpa S-Series General 7 09-02-2007 03:03 AM
