Go Back   SaturnFans.com Forums > Models > Saturn Relay > Relay General
Old 07-02-2018, 12:52 PM   #1
Ftadx
Ftadx is on a distinguished road
Default Lift gate release
Hey whatís going on guys!
I have a 2006 relay and currently doesnít run or turn on or anything, what I need help with is to get the lift gate open. I donít see a key hole in the back and I donít see a cable up from to pull to release it and in the far back I donít see an emergency release thing either. Any suggestions on what I could do to get it open?
Add to Ftadx's Reputation
Rate the quality of this post and help Ftadx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ftadx is offline   Reply With Quote
Old 07-04-2018, 12:44 PM   #2
Default Re: Lift gate release
Welcome to SaturnFans, Ftadx!
I'm not familiar with the Relay, but I'll take a stab at this. Check the link below. Scroll down until you see item #24 listed. That's the handle from which you should be able to open the liftgate from the outside. My wife's Acura MDX has a similar set up which also has no key access at the liftgate either.
https://www.wholesalegmpartsonline.c...category=19392
The liftgate is wired just as the doors are to be locked or unlocked electrically. If you have no electrical power whatsoever - as your message appears to suggest - and the liftgate latch was in the lock position when last activated then the door may not open. Once electrical power is restored then using either your Relay's interior door lock switch, or the Remote Keyless Entry (RKE) fob the liftgate latch should release and be possible to open. If the liftgate cannot be opened after power has been restored then there may be a wiring problem. Be sure to look through any and all related fuses, pulling them out to positively verify their condition.
293,000 miles-it keeps on rolling!
Add to pierrot's Reputation
lift gate bill1960 S-Series General 1 03-16-2017 09:09 PM
Lift gate struts txaginid Vue Tech 5 01-30-2015 08:12 AM
Stuck lift gate temley S-Series General 2 05-20-2014 04:57 PM
lift gate stuck temley Support Forum for Canadian Saturn Owners 0 05-19-2014 10:43 PM
lift gate struts jslw300 L-Series Tech 6 02-15-2005 09:37 PM
