Old 11-22-2015, 05:04 AM   #1
KMW
KMW is on a distinguished road
Default 2000 sL2 starting problems
So about a week ago, my SL2 started having problems with starting up. When I went to turn it on, it would have diifficulty staying on, with the rpms flucuating below 1000 rpms before stalling out on me completely, but it would start back up immediately, still hesitating before staying at the usual rpm level that ive always seen it at, which is at about 1000-1200 rpms, flucuating whenever I was in idle. Well, a couple of days ago, I tried to turn my car on and the engine just started turning over and not starting . I'm still not able to get it to work. Does anybody have any idea as to what it is?
KMW is offline   Reply With Quote
Old 11-22-2015, 09:14 AM   #2
SL19302
SL19302's Avatar
2002 SL1
Default Re: 2000 sL2 starting problems
One good place to start is your coolant temp sensor, Was that ever replaced?
CHECK YOUR OIL!
Old 11-22-2015, 06:10 PM   #3
KMW
I'm actually not quote sure if it's been replaced or not. I just bought this car used from a dealership a couple of months ago. Don't know if the previous owner has changed it out
Old 11-22-2015, 07:46 PM   #4
KMW
Just read the code on it and I got a P0107 code
Old 11-22-2015, 08:02 PM   #5
P0107 - Map sensor low voltage.
Try wiggling & cleaning out the map sensor connector.
Attached diagnostic flow chart, wire diagram & FSM code description/operation.
One time I somehow managed to put the wrong ECTS to the PCM, starting would work fine once warmed up or when outside temp's were above ~50f but one cold snowy midnight after work the dang thing wouldn't start...pulled the connector off the ECTS and "vroom". Left it that way for the drive home, fixed it properly the next morning with the right ECTS...point is a bad ECTS could act the same way as the wrong one.
Old 12-13-2015, 09:05 PM   #6
KMW
Alright, I'm having another problem with it starting. I took it to an independent mechanic a week ago, which he switched out the spark plugs, which looked like they were the original spark plugs that came with the car, 149,000 miles ago. The car started up, and he also took it for a test drive and saw that the engine was getting way too much gas due to a bad fuel pressure regulator so he switched that out too with a new filter on it.
Now I've had it for a week and I've noticed something that happened only twice: the engine wouldn't start unless I gave it a little gas. I tried to go to work today and all of a sudden, it wouldn't start. Only cranks. I'm also getting a service engine soon light on with it.
Old 12-13-2015, 10:15 PM   #7
KMW
I also smelled gas when I tried to turn it on, so I'm not quite sure if it's the ECTS or engine flooding.
Old 12-14-2015, 12:05 AM   #8
KMW
And now it started just fine.
Old 12-14-2015, 01:27 AM   #9
You were given one of the best suggestions for S-series owners new to Saturnfans - examining and replacing the coolant sensor if its the original one. The original ones fail and tends to run the engine rich all the time and floods engines on occasions.
2000 LS2 Starting problems AngusAR L-Series Tech 11 08-10-2013 03:09 PM
Starting problems. 2000 saturn SL. Need help please thanks! nlange S-Series Tech 8 09-23-2009 11:56 AM
Starting problems. 2000 saturn SL. Need help please thanks! nlange Canadian Saturn Owners 4 09-21-2009 10:17 PM
Problems starting my 2000 SL2 cherubkiss S-Series Tech 10 03-12-2007 11:49 AM
Problems starting my 2000 SL2 cherubkiss L-Series Tech 3 03-09-2007 03:46 PM
