Old 06-24-2015, 02:44 AM   #1
Rochester
Rochester is a name known to allRochester is a name known to allRochester is a name known to allRochester is a name known to allRochester is a name known to allRochester is a name known to all
Default Metallic noises from rear of car
This week, I have noticed some strange noises coming from the rear of my Saturn. It sounds like it's in the rear right area, but my hearing is not the best so I'm not certain.
I would describe the noises as dull, metallic bangs and creaks/clunks, and some intermittent light metallic rattles. They started suddenly two days ago, and they are worst in the first 30 or so seconds after I start the car after it has been sitting awhile. I also hear them while braking and when the car hits a bump, very rarely at other times.
I have done only a cursory examination so far - looked under the car before I left work earlier, and saw that the muffler is not loose, no obvious damage to the springs or anything else under the car. None of the junk in the trunk appeared to be making the noise, either. I intend to take the rear wheels off and inspect the rear brakes tomorrow before work.
My hunch is that something in one of the rear brakes broke, on the grounds that (1) the noise happened for the first time when I set the parking brake on Sunday afternoon, (2) I haven't worked on the brakes, front or rear, for a long time - they've been almost freakishly long lasting, (3) there might be a connection between a cold, broken or damaged part getting hot and the noises easing up after the first few seconds, and (4) I can't imagine anything else that could make the noise, except the suspension - can't rule that out! - but the struts are only a couple years old.
On the other hand, I have noticed no continuous scraping or grinding noises, nor has there been any noticeable change in the performance of the car or the brakes.
I'll know more when I take the rear wheels off, but does anyone have any ideas on what to look for, or what the next thing to check should be if I find nothing wrong with the brakes?
Thanks
Rochester is offline   Reply With Quote
Old 06-24-2015, 06:40 AM   #2
billysvue
Default Re: Metallic noises from rear of car
maybe suspension issues with the stabilizer bar and links. Get it stable on jackstands/front wheels blocked and try to move stuff by hand to duplicate sound.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Old 06-24-2015, 07:49 AM   #3
johnny95sl2
johnny95sl2 will become famous soon enough
johnny95sl2's Avatar
1997 SW2
Look at the exhaust heat shields
1992 SC
1994 SW2
1997 SW2
others in my yard
johnny95sl2 is offline   Reply With Quote
Old 06-24-2015, 09:58 AM   #4
2NDSOUT
2NDSOUT's Avatar
1999 SL
^ This.... ^
The Heat Shields have a tendency to come loose over time; and when they do, it sounds like you are dragging a pile of aluminum cans behind the car...
You can try to re-attach them, or discard them.
I was going to say Rear Sway Bar Links, but seeing that you have an SL1, you most likely don't have them on the car.
Check the Rear Drums as well (FUN )...there may be something in there that along with the Parking Brake that is getting ready to rear its ugly head.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Old 06-24-2015, 05:35 PM   #5
^^^^^ Loose heat shield/s and/or loose muffler would be high on my suspect list.
Old 06-26-2015, 12:53 AM   #6
saturnsctwo
check the rear exhaust pipe where it goes over the crossmember. the space there is very tight from the beginning, & when my rear muffler strap let loose the pipe started to rattle against the rear crossmember & made an exact noise like you described. i didn't know the rear strap was rusted through & broke because it let go on top of the muffler where you could'nt see it & the bottom of it looked pretty good & tight, but it was severed on top where you could'nt see it causing the muffler to hang lower that it's supposed to...
my muffler seemed tight also even with the broke strap, so check this out good, don't take it for granted that the strap is ok just from the bottom view....
Old 06-26-2015, 10:25 PM   #7
xXPhasemanXx
xXPhasemanXx is on a distinguished road
xXPhasemanXx's Avatar
1999 SL
As others have said I would definitely check the heat shield. My car was making the EXACT same noise as you described and that what it was. I fixed it with a 1/2" self-tapping screw and some washers to support the broken chunk that fell off because it ripped where the rivet was. Mine was broken right below my gear shifter but yours could be broken anywhere from the rear to where I described.
xXPhasemanXx is offline   Reply With Quote
Old 06-27-2015, 05:30 PM   #8
Rochester
Thanks everyone. I think I've got it narrowed down to the right rear brake. I went to take the thing apart. Both sides so that I could compare them. I had to use a pry bar and a hammer to remove the drums, but I had to beat on it 20 or more times on the right side, and only 3-4 times on the left side. I think the right one was sticking. I tried taking it apart and putting it back together, dialing the adjuster down a few turns. I'm going to go for a short drive now, and see if there's any improvement.
I'm going to have to do a brake job in the not-too-distant future, I think. I noticed the brake shoes seem to have worn irregularly, with the bottom of each rearward shoe being thicker than the top, but the difference was more noticeable on the right side, and on both sides was more obvious on the rearward shoe than the frontward shoe. I also notice that the lowest and thickest part of the rearward shoes, and therefore presumably the parts with the least wear, were discolored compared to the rest of the shoes. Not sure why, unless it has to do with their getting less friction than the rest. The difference is more obvious on the right side.
At least now that I've taken it apart and reassembled it, I know I'll be able to do it again when I replace the shoes.
Fingers crossed that this worked!
Old 06-27-2015, 06:05 PM   #9
Rochester
Aargh! No, it didn't work. I'm still getting the noises, and if anything they've gotten worse as the week progresses. I accomplished nothing except making my brakes softer. Guess I'm going to have to take the wheels off again and tighten those adjusters back to where they were.
The muffler and the heat shields don't appear to be loose, nor are they touching the rear cross bar.
I noticed over the last couple days the metallic clunking is now almost a bang, worst when I back out of my driveway, and I can feel the vibration through the brake pedal if I happen to be using it when it happens.
Old 06-27-2015, 06:29 PM   #10
Rochester
HOLY COW I AM AN IDIOT. While tinkering with the thing this time, I noticed that there is a metal bar, longitudinal to the car, that runs from the rear wheel to the frame in front of the wheel well. It's broken clean off right above the wheel. Don't know what it's called. I was so interested in how the brakes worked that I never noticed it the first time.
I guess I'm not doing any more driving until I fix it. Hope I haven't done any permanent damage by driving this past week
Maybe I should replace the one on the other side, too.
Old 06-27-2015, 09:30 PM   #11
SL19302
SL19302's Avatar
2002 SL1
Track Bar Snapped, They usually rott right in that area, Replace with a junkyard unit as GM no longer has stock, If the other side appears ok leave it alone for now. Replacing parts that are still working is a waist and not cost effective.
CHECK YOUR OIL!
Old 06-28-2015, 07:44 AM   #12
johnny95sl2
1997 SW2
Trailing arm. I think you can buy new of rock auto
https://www.rockauto.com/catalog/raframecatalog.php?ck[ID]=0&ck[idlist]=0&ck[viewcurrency]=USD&ck[PHP_SESSION_ID]=sh0blf1fdpjc05ujmag434fkv3
1992 SC
1994 SW2
1997 SW2
others in my yard
SL2 making metallic noises from rear left hobbes25 S-Series General 7 02-21-2010 11:20 AM
Metallic Noise Coming From the Rear End The Critic S-Series Tech 3 07-27-2008 07:55 PM
Metallic rattling, right rear CM400T S-Series General 3 06-06-2008 05:13 AM
rear suspension noises 97sc2racer S-Series General 1 07-27-2006 03:14 AM
Hello & what's that metallic ting rear 2000ls1 JoeB L-Series Tech 8 07-14-2005 02:41 AM
