Old 06-17-2015, 04:24 PM   #1
mattwehrwein
mattwehrwein is on a distinguished road
Default 99 SL2 drove through high water wont crank
hey guys i drove my liltle 5 speed sl2 through a high puddle during a flash flood the engine stalled. towed it home and it will not start or crank. i drained oil and there was a lot of water in there and still no crank.
i took plugs out and i can see water in there holes how do i remove it? is it possible to get that water out and it cranking again? What about removing the belt and trying to turn her by hand?
thank you
mattwehrwein is offline   Reply With Quote
Old 06-17-2015, 04:33 PM   #2
billr
Default Re: 99 SL2 drove through high water wont crank
Somehow I lost the reply I posted. Jack up one front wheel and rotate it by hand with the trans in 5th gear, spark-plugs out. Put some oil in through the plug holes. Use plenty, too much may make an oily mess, but can't do any damage if the plugs are out. After enough rotating to get most of the oil out I would take compression. No need to take the belt off.
Ah, I see, I didn't lose my rely, this is a duplicate thread.
Old 06-17-2015, 04:45 PM   #3
billysvue
thank you
I hope the motor isn't hydraulic'd( motors break when they try to compress water in their cylinders because they wanted to be a submarine).
GEt a shop vac.
I assume if water got that high, it got into all your electronics/starter, anything electrical.
A little water in the plug holes is easy to fix- the rest isn't.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Old 06-17-2015, 05:39 PM   #4
54packman
54packman will become famous soon enough
1998 SW2
2000 SC2
Just pull all the plugs out, and then crank the engine, any excess water will blow out the plug holes, crank for 30 sec or so , as starter will have almost no load. Check plug conditions and replace if necessary, reinstall plugs and wires and try a restart.
54packman is offline   Reply With Quote
Old 06-18-2015, 08:03 AM   #5
mattwehrwein
I cant get the enging to turn the starter just clicks and engine will not turn by hand. I have the plugs out oil drained and valve cover off i even tried to pop the clutch car just stops. So if i throw the clutch in 5th gear jack the driver side up and turn the wheel it should turn the engine? how hard is taking a head off the engine?
Old 06-18-2015, 08:45 AM   #6
SL19302
SL19302's Avatar
2002 SL1
If the plugs are out and the engine is still locked up then most likely mechanical damage has occurred like a bent connecting rod, Most likely the engine will need to be replaced.
CHECK YOUR OIL!
Old 06-18-2015, 09:34 AM   #7
Signmaster
Ouch. It takes a decent bit of water to hydro lock and engine usually, but if you can't get it to turn by hand.....
Have you tried turning it over with the crank (pulley) bolt with the plugs out? It might also be worth checking for any locked up accessories. It's a long shot but I've heard people claim it's happened.
Old 06-18-2015, 10:12 AM   #8
mattwehrwein
I think im going to take the serpentine belt off and try cranking the crank shaft
Old 06-18-2015, 10:30 AM   #9
mattwehrwein
is reuildig these engines possible? ive done 350s before? Wheres a good rebuild kit at? and how far can i bore it out if needed?
Old 06-18-2015, 10:43 AM   #10
billr
Sure, they can be rebuilt. The problem is that a decent rebuild will cost about as much as the car is worth, even if you provide a lot of "free labor". If you like the car and intend to keep it I recommend a rebuild (even if you have to start with a used short-block), just don't expect to get your money back on a rebuild. Another consideration here is what other damage was done by soaking in water. I gotta ask... how high was this water? On earlier SL2s the air intake is 18-20" off the ground!
Old 06-18-2015, 01:12 PM   #11
mattwehrwein
the water was below my door when i got out.
Old 06-18-2015, 03:10 PM   #12
underthehood
underthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the rough
underthehood's Avatar
2004 VUE 2.2L
Sounds like your engine is history. If you hit the water fairly quick it gets easily in to the intake and kiss it bye bye
2006 Toyota Highlander (rare 4 cyl AWD)
2001 Toyota Highlander V6 AWD creampuff
Daughter got her own! 2005 Lexus ES330 Dream Ride
underthehood is offline   Reply With Quote
Old 06-18-2015, 03:57 PM   #13
mattwehrwein
would a sohc engine work for the car? I know i got the double overheads but i found a real good price on a single overhead.
Old 06-19-2015, 03:55 PM   #14
Steve44
Steve44 is just really niceSteve44 is just really niceSteve44 is just really niceSteve44 is just really nice
Steve44's Avatar
1999 SL1
It will work, but with what you'd have to do to get it to work it would be more trouble than it's worth. Look for a DOHC.
The SL1...The Lucky Car
The SL2..The awesome deal.
The #3 Silver SL2 FIVE SPEED!
World's biggest fan of doing it the easy way.
Old 06-19-2015, 09:53 PM   #15
CZECHLAGER
CZECHLAGER has a spectacular aura aboutCZECHLAGER has a spectacular aura about
2001 SL2
1995 SW1
Hello, Do you have a cold air intake like an AEM that has the filter down low ahead of the front left wheel. If so that is what happened. It hydro locked. Sorry for your trouble. Rick
CZECHLAGER is offline   Reply With Quote
99 sl2 drove through high water wont crank mattwehrwein S-Series Tech 1 06-17-2015 04:26 PM
99 sl2 drove through high water wont crank mattwehrwein S-Series Tech 1 06-17-2015 03:09 PM
97 sc dohc- getting gas & spark, wont crank without ether, wont stay cranked after??? P.Johnston85 S-Series Tech 37 06-07-2010 06:29 PM
wont crank Marbar6987 S-Series Tech 1 06-17-2009 02:19 AM
Drove satty through water 01SL1SATURN S-Series General 15 02-14-2008 10:02 PM
