Old 05-22-2015, 09:16 PM   #1
1993
1993 is on a distinguished road
Default Odometer going nuts HELP
I have a 1992 sc, twin cam, manual. The fuel gauge is crazy so i dont depend on it at all. I always use the odometer. Every time i fill up i re-set the trip, then when i get 300 miles, i fill up again. Well, i noticed yesterday that the trip meter and odometer start going waaaay faster than they should sometimes. The white 'tenths' counter goes about twice as fast as it should racking up the miles twice as fast! Every now and then it will go back to normal but will start going real fast again. I went 2 miles today and it clocked 5! I dont understand what is making it do this? The speedometer is normal, no problems with it..
The odometer was broke when i got the car so i bought that new replacement gear for it that guy sells that wont ever break again and installed it. That was 10 years ago and its been fine all these years till now. Any ideas what is making the odometer do this but the speedometer is normal?
Thanks
1993 is offline   Reply With Quote
Old 05-24-2015, 10:51 PM   #2
1993
Default Re: Odometer going nuts HELP
anyone?
Old 05-24-2015, 10:59 PM   #3
Think there's another plastic gear in there that can break. It's rare enough no one pre-makes a replacement. May have to get another cluster, test it to see if it works, and swap the gear(s) from that to your cluster.
Old 05-25-2015, 12:13 PM   #4
1993
But if there was another gear thats broken, wouldnt that just make it not work at all? It works all the time, just goes waay to fast sometimes! Like i said, it will rack up 3 miles for every true mile..
Old 05-25-2015, 12:15 PM   #5
SL19302
SL19302's Avatar
2002 SL1
The problem is either the odometer motor or a short on the printed circuit on the back of the cluster, My friends 93 had the same problem with it spinning way to fast while driving.
CHECK YOUR OIL!
Old 05-25-2015, 12:37 PM   #6
1993
ah crap..I have another cluster for parts but its from a 1994, mine is a 1992 and is different as mine has the oil pressure gauge so i cant use the printed circuit board part but could use the odometer motor but how do i know which is actually the problem?
Old 05-25-2015, 01:24 PM   #7
SL19302
SL19302's Avatar
2002 SL1
Most likely it's the printed circuit, That's what happened to ours, you will need to find a cluster with the oil pressure gauge and take the printed circuit off that.
CHECK YOUR OIL!
Old 05-25-2015, 02:49 PM   #8
2NDSOUT
2NDSOUT's Avatar
1999 SL
I still have the instrument cluster from my 1991 sport coupe which would be a complete fit for your vehicle. It has the circuit board as well as the oil pressure gauge on it as well. Everything was working in that car with exception to the odometer gear. If you are interested in it let me know and we can set something up.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Old 05-25-2015, 03:28 PM   #9
1993
well, what do you got to have for it? or, what would you take for the printed circuit board?
Old 05-26-2015, 11:50 AM   #10
2NDSOUT
2NDSOUT's Avatar
1999 SL
I sent you a PM.
Let's take this to email, as it will be easier to discuss Paypal, etc.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Old 06-02-2015, 07:58 PM   #11
1993
Bryan, ok, i got the cluster in. The odometer works fine, so thats good. The fuel gauge unfortunately floats around so much its hard to trust, varies a half tank..i dont know why this car is so resistant to a working fuel gauage..lol..the gauge on the original cluster went nuts, it jumped around so fast it looked like a drum stick doing a drumroll!!. anyways, one thing im worried about, my original cluster was 130 mph, this new one is 110 mph, so, is it not going to be correct anymore or..?
Old 06-02-2015, 09:09 PM   #12
2NDSOUT
2NDSOUT's Avatar
1999 SL
If memory serves me correctly, the 91 model year was rated for 110 mph and then there was a change over in 92 when the speedometers were rated for 130. I don't think it will change how the speed is rated for the car. If the gas gauge is still fluctuating, it could be an issue with the fuel pump itself or the float in the tank...just offering that as a suggestion. After the 92 model year as well, the oil pressure gauge was dropped because there were many complaints from consumers that the gauge was not providing a solid oil pressure reading.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Old 06-02-2015, 09:17 PM   #13
johnny95sl2
johnny95sl2 will become famous soon enough
johnny95sl2's Avatar
1997 SW2
The fuel gauge on my 92 has always bounced all over the place, learn to live with it.
1992 SC
1994 SW2
1997 SW2
others in my yard
johnny95sl2 is offline   Reply With Quote
Old 06-02-2015, 09:38 PM   #14
1993
ya i aint worried much about the fuel gauge, just wishful thinking that it would finally work right..lol..but was wondering about the speedometer being accurate being its different..
Old 06-02-2015, 10:08 PM   #15
It won't be accurate when you go faster than 110 MPH...
Old 06-02-2015, 10:22 PM   #16
1993
lol..i know but what about normal speeds? Will it be off being its supposed to have the 130 mph gauge or will it be corrected somehow?
Odometer/Trip Odometer trouble saturing S-Series Tech 14 09-23-2010 12:15 AM
Lug nuts and wheel nuts d16tr S-Series General 27 01-22-2009 08:33 AM
odometer and trip odometer issue 93sc2OHguy S-Series Tech 1 01-22-2008 11:17 AM
Going Nuts here. voo S-Series General 10 06-03-2006 12:07 AM
Lug nuts cincysaturn Miscellaneous Tech 7 10-22-2002 08:12 PM
