Old 09-07-2015, 07:53 PM   #1
flyhop
flyhop is on a distinguished road
2000 SL2
Default Is "this" an OEM EGR Valve?
Would someone who knows more than I do look at this EGR valve and tell me if it's the bona fide real thing or an aftermarket? I'd be grateful.
http://www.amazon.com/ACDelco-210094...ords=egr+valve
flyhop is offline   Reply With Quote
Old 09-07-2015, 08:09 PM   #2
Default Re: Is "this" an OEM EGR Valve?
It is as close as you are going to get to GM/Saturn OEM.
Old 09-07-2015, 08:29 PM   #3
flyhop
2000 SL2
Even from saturnparts.net or local dealer?
Old 09-07-2015, 09:44 PM   #4
SL19302
SL19302's Avatar
2000 SW2
2002 SL1
That's the GM replacement, and as stated as close as you will get to the original Saturn valve.
CHECK YOUR OIL!
Sprayed plastic valve cover with acetone/toluene, instantly "rusted" help! Sol87 S-Series Tech 5 08-14-2014 10:51 PM
Possible Valve Issue, "Rattle" sound upon cold starts blackbeard S-Series Tech 21 07-06-2014 04:10 PM
97' SC2 DOHC valve cover gasket set "info needed" magreger S-Series Tech 15 03-05-2011 09:05 AM
Vin "7" Vin "8" Vin "9" brake pads/rotors universal? demoncamber S-Series Tech 4 09-09-2009 12:35 PM
advice needed on "when to replace valve body" bayfisher2day S-Series Tech 5 01-07-2007 10:08 AM
