Old 06-07-2015, 08:26 AM   #1
sdowney717
sdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of light
Default Slam shifting, so pulled valve body
I found no sludge inside except a tiny amount on top where it settled out.
One solenoid, has an ohm of 2.2, so replacing that one.
other than that, nothing I can notice. I did not take the valves out of the valve body, they all seem to move smoothly.
Sometimes it slam shifts all gears, sometimes the shifts feel like a giant spring getting unwound and wound, sometimes it is fine.
Ordered 2 valve body spacer gaskets from Amazon prime.
ACDelco 21003530 GM Original Equipment Automatic Transmission Control Valve Body Spacer Plate Gasket
And here in Norfolk, one 21003344 solenoid valve, I used this site and found one local to me in Norfolk for $46 including taxes.
http://oemcats.com/oem-parts/21003344.html
The other idea is that input shaft nut under the side cover, what is the likelyhood it is loose?
How much trans fluid goes back in after a drain?
valve body
trans gears
I plan to reattach the gasket pieces using some sealer.
sdowney717 is offline   Reply With Quote
Old 06-07-2015, 09:17 AM   #2
Default Re: Slam shifting, so pulled valve body
Put back as much as you drained out. A loose nut is not that uncommon and all the solenoids in the world and/or nut tightening will not fix worn out clutches.
Old 06-07-2015, 09:53 AM   #3
Nice pictures! Post one showing the other side of the larger VB piece and maybe we can tell if this VB already has the Sonnax sleeve for the Pressure Regulator section. There is a little retaining clip installed with that upgrade/repair that shows down in the oil passage.
Old 06-07-2015, 11:06 AM   #4
sdowney717
Sure, I doubt anyone has done any work to this.
Worn clutches I dont think they are, it does not slip at all.
Do you mean inside a solenoid passage? I dont notice anything,
Old 06-07-2015, 11:36 AM   #5
The clutches do not slip until failed, this shows up as uncorrectable slam shifting.
Old 06-07-2015, 11:42 AM   #6
sdowney717
Well, I suppose will do what I can. I have rebuilt 5 AT over the years.
Last one I did was 4L60E.
If I have to, which I dont think so, is there any odd specialty tool needed or giant 800 pound spring like in the 42RE Jeep overdrive?
Old 06-07-2015, 11:55 AM   #7
Try contacting Special Forces. He answers private messages and seems to be the best xmission expert for Saturns, sharing info unlike others.
Old 06-07-2015, 12:03 PM   #8
SL19302
SL19302's Avatar
2000 SW2
2002 SL1
The Solenoid that has an ohm reading of 2.2 needs to get tossed, As far as the looks of the valve body that tells you nothing, The problem that occurs is excessive clearances inside the pressure regulator and boost valve bore causing low line pressure when the trans is hot and the fluid gets thin causing reverse to slam, The more slamming that occurs the input shaft nut comes loose causing more aggravation. Replace the failed solenoid and hope for the best. If shifting problems persist replace the valve body.
CHECK YOUR OIL!
Old 06-07-2015, 01:00 PM   #9
sdowney717
Thanks, I will be getting these parts midweek, will take some days to post back what happened. Everything looks very clean to me, hope their is no significant valve wear. Old fluid came out clear and red.
The poor shifting happened just sudden, one day, before it was perfect. Been bad for about a week. I see people buying a new input shaft nut, why not tighten the old with maybe locktight?
Did you grind a socket to fit? what size is that nut?
Old 06-07-2015, 01:46 PM   #10
satlite440
satlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud of
2001 SL2
cluches don't slip unless there is a gross hydroilc leak in the cluch circuit causeing the piston to be unable to apply enough pressure to keep the cluch pack applied....
the only difficult part I had rebuilding mine was piston installation..a lip wizard tool is invaluable..i read you have done these before so I am wondering if you used a press to install the plate and compress the return spring too...my snap press was not strong enough to do it...the only tool I think I will find&buy for next time will be the holder for the input shaft nut
shure you can trust the government,just ask us indians all about it...
heavy line the final protective fire line of the dealership
satlite440 is offline   Reply With Quote
Old 06-07-2015, 02:19 PM   #11
Oops, my bad. At least two members with experience in auto xmission diagnosing and repairs........
Old 06-07-2015, 03:01 PM   #12
Chazberry
Chazberry's Avatar
1995 SW2
This is what gets done with the Sonnax updates . . .
https://s3.amazonaws.com/sonnax-dev/...SC-TAAT-IN.pdf
This just happened with my '95 SW2. A new LP Solenoid has it shifting like a champ again. If you have no issues with Reverse or your 2nd gear shift, the Nut is probably OK.
Old 06-07-2015, 03:19 PM   #13
Sorry, I gave you bum info. The first pictures of the VB parts are the correct side to see that Sonnax retaining clip, but you have to be looking at just the right angle, it's kind of buried in there.
Old 06-07-2015, 03:58 PM   #14
You can not DIY the auto trans rebuild as there are TC shaft seals that must be formed after install and a socket will not catch it. The cost of a decent rebuild kit exceeds the cost of a good used transmission.
Old 06-07-2015, 04:00 PM   #15
It will not hold torque is why you have to replace it.
You can not tell ATF viscosity or viscosity stability by looking at the color, clarity and smell. Thin fluid causes slam shifting.
Old 06-07-2015, 05:46 PM   #16
satlite440
2001 SL2
not true old nuc..I got my masteroverhaul kit fron transtar for 199.included pistons/fibers&steels..the hard parts were another 160..while you are a very valuable asset to the bord I think auto trans is not your strong point. and after adding a new converter I was under 600 for a new rebuilt trans for my oldest daughter...now do I have resources available to me the average bord member does not yes...im a gm master cirted auto trans&ase auto trans tech...with acces to the Saturn j-tool box...however there are ways to size scarf square cut seals on the input shaft if you haven't got the sizeing tools...the hardest part of the rebuild I found chalangeing was the changing of the pistons in the 1st,2nd,3rd&4th cluch pac's as my snap press was not strong enough to compress the return springs.so I has to use a press..the only other issues were finding/sourceing the plastic cage support bearings under the 3rd&4th and 2nd cluches and a pair of torington bearings that went between the 3rd cluch &gear...the hardest thing will be to find internal hard parts as this trans is discontinued and gm vintage parts has few parts left.requrieing searching trans recyclers to source good used hard parts and there are no aftermarket sources....this is why most tranny shops will not rebuild them
and no I did not use dex3...I used dex 6 from the start soaking my fibers..so no compatabilty issues
Old 06-07-2015, 06:41 PM   #17
You spent ~600 at dealer cost for parts. The average person will not get those prices. A very low mileage auto can be had for 250 or so all day long if you look. That looks like about 350 in savings off of prices you can not get if you are not a shop or dealer. Actually complete rebuild kits are very hard to find at any price for either transmission.
You also have no clue as to what I do or do not know about auto transmissions and if you want to start making unfounded accusations then have at it. Got anything else to add?
I am quite aware of the complete lack for short service life parts for both the auto and manual transmissions. I am also aware of the various parts suppliers attitude of screwing the individual buyer of these parts blue. For example the shift fork pads for the manual selectors quoted at $5.12 ea recently plus an obnoxiously high shipping charge.
Old 06-07-2015, 10:15 PM   #18
SL19302
SL19302's Avatar
2000 SW2
2002 SL1
If the Solenoid with 2.2 ohms happened to be the line pressure solenoid that's most likely where the sudden slamming occurred, I have not read back to see if that's the one that has out of spec resistance, Look at the bus plate and the valve body plug for burnt terminals as this will cause your new solenoid to fail shortly after replacement. Just an FYI Saturn called those 5 units inside the valve body actuators.
CHECK YOUR OIL!
Old 06-08-2015, 12:37 AM   #19
satlite440
2001 SL2
again not true.my dealer does not have a resale account with transtar nor with any of the other recyclers or suppliers I worked with..as the dealer will only use gm parts.so i was an over the counter customer..did they give me a break i don't know for sure.they might have as i knew the lingo had the proper name and call out numbers of both the gm and natpro and transtar illustration numbers along with the gm part numbers..dealing with trans part places is defanatly not like going to napa..so they might have i didn't ask nor care i needed these parts and would have paid what ever they wanted as i was behind the 8ball and under a deadline to have a working reliable car for my daughters birthday..and i made it btw..
as to what I do or do not know about you.this might be true as i do not know you personaly however as to red oil..well I think i would prefer to follow my own diagnostic's and leave it at that.otherwise i beleave you seem to have a solid foundation as far as what i have seen and are an asset to the forum..it was not a personal attack just a statement of fact that i experienced in my reagon of the country as to cost and priceing .so in my case that a new rebuilt trans would be cheaper or a used unit with a warrenty would have been cheaper was not the case. forum members should explore all options according to their skill level..the fact you are an old hand and your word carries a lot of weight could lead a member to just go your route and spend more by failure to get a warrenty with the used unit or fail to explore other options.again we don't know nor have the ablity to judge the skill set of a person posting on a fourm.however it is my belief that more options are better than less or 1..i always let people whose cars/trucks i work on know ALL the options open to them and the drawbacks of each one so the can make an informed choice.thats what i would want how bout you?
as to your priceing.well you must be some place im not.in the seattle area and northwest area on car part .com a used sl1 or sl2 auto trans starts at 650 and up all with over 120k plus miles i don't consider that a bargin personaly i would rather pack my own parachute...
Old 06-09-2015, 03:53 PM   #20
Special Forces
Special Forces has a spectacular aura aboutSpecial Forces has a spectacular aura aboutSpecial Forces has a spectacular aura about
Special Forces's Avatar
2006 ION Red Line
You probably could have gotten away with opening up the top pan, the top cover of the valve body and replacing that solenoid and be back on the road slam free. But, it is an experience and adventure I suppose.
Make sure you put the 3 check balls back where they belong in the valve body. Also I'm not sure which gasket set you bought on Amazon but the ones I procure have 2 sets (4 paper gaskets for one on each side of the separator plate) so you may have wound up with 4 sets of gaskets.
/// Need rebuilt valve bodies? PM Me. \\\
//// Why bother with ebay when I'm right here? \\\\\
Valve bodies built to order
Please PM me about valve bodies, do not post a visitor message.
Special Forces is offline   Reply With Quote
Replaced Valve Body- Reverse Slam GONE ! scottybk S-Series Tech 8 04-15-2015 09:29 PM
Reverse slam w new Valve Body scottybk S-Series Tech 4 12-28-2014 11:14 AM
reverse slam, slam into 2nd, p0732, now no reverse...new valve body? nd99sl2 S-Series Tech 12 09-28-2010 10:07 PM
Reverse SLAM!! Valve body tkcsman S-Series General 9 09-07-2010 08:30 PM
Will reverse slam or new valve body fix this? chevy57 S-Series Tech 0 12-26-2007 11:18 AM
