Old 04-02-2006, 03:43 PM   #1
Social
Social is on a distinguished road
Social's Avatar
1995 SW2
1992 SL2
Question Knocking Noise
I just bought this 95 Saturn SW2 and ever since I got it it's been making this knocking noise coming from the passenger's side of the vehical. I ran my scaner on it and it came up with a code that said, "53 Soft Flag Electronic Spark Control Over Maximum Value." So far I've replaced the knock censor and EGR valve and I had my coils checked, the one was working fine but the other wasn't making a good connection and the voltage would jump around, but when you got a good connection it was fine. And I checked to make sure that my water pump or alternater wasn't making the sound just to be sure. But I seem to be at a lost as what to look at next and hoped you guy/gals could lend me a hand. Thanks!
Add to Social's Reputation
Rate the quality of this post and help Social reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Social is offline   Reply With Quote
Old 04-02-2006, 06:45 PM   #2
Phonespider
Phonespider is on a distinguished road
Phonespider's Avatar
1992 SL1
Default Re: Knocking Noise
Check the Serp. Belt tensioner with a flashlight when the engine is running. If that thing is boping around it needs to be replaced. Hopfully it's that and not the timing chain.
Add to Phonespider's Reputation
Rate the quality of this post and help Phonespider reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Phonespider is offline   Reply With Quote
Old 04-02-2006, 10:30 PM   #3
flyhop
flyhop is on a distinguished road
2000 SL2
Fast way to find out if the noise is coming from an accessory or the engine is to remove the serpentine belt altogether. Then, crank up the engine but just for a VERY short time frame as your water pump will not be moving. Run out, listen to see if the noise is still there, and then cut off the engine.
If noise is still there, it's something in the engine. If not, it's either an accessory or the belt tensioner. Try what Social said first though.
Add to flyhop's Reputation
Rate the quality of this post and help flyhop reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
flyhop is offline   Reply With Quote
Old 04-04-2006, 04:51 PM   #4
Social
Social's Avatar
1995 SW2
1992 SL2
Ok I took my belt off and ran it, but still the noise remained. I'm not that good with this stuff but I've been locking in to what the ESC does and what components it consist of and from what I've found I'd be lead to believe that possible my ignition module would be bad, though I haven't had a problem starting it, but as I see it I'm not getting a trouble code that a censor is bad I don't know what else it could be. Also I know the ESC has a long to do with advancing or retarding the engine so if it wasn't working I'd figure my timing could be off and causing the knocking sound. Anywho just wondering if any of you know anything about this. Thanks!
Old 04-04-2006, 06:52 PM   #5
blackeagle1
blackeagle1 is on a distinguished road
blackeagle1's Avatar
2000 SL2
I hate to say this but it is probably a piston rod knocking. You are looking at a major engine rebuild. You should stop driving it before it breaks and puts a hole through the block.
Add to blackeagle1's Reputation
Rate the quality of this post and help blackeagle1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blackeagle1 is offline   Reply With Quote
Old 04-05-2006, 06:43 AM   #6
android_advance
android_advance is on a distinguished road
I just had a similar problem. At first we thought that had something to do with the tensioner rod or timing chain, but then my car was really low on oil so we though it could be that I messed up a valve or had a bad piston; it indeed was something to do with the tensioner and camshaft. The mechanic said that the time was about to jump and its a good thing I got it in when I did. They had to replace a pin in the camshaft and replace gears that were either broke or missing. Now its good as new except there is a chance the pin won't hold (I really don't like that it isn't guaranteed) so now I gotta save up so I can replace the cam if need be.
Add to android_advance's Reputation
Rate the quality of this post and help android_advance reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
android_advance is offline   Reply With Quote
knocking noise from engine spareribs L-Series Tech 2 12-17-2009 09:49 PM
Knocking Noise imamacanac S-Series Tech 2 06-28-2009 04:00 PM
Loud Knocking Noise flannelenamel S-Series Tech 2 08-13-2006 08:41 PM
knocking noise - HELP mark_92SC2 S-Series General 1 06-27-2005 05:20 PM
Knocking Noise! JDub99SL2 S-Series Tech 8 12-19-2003 10:29 PM
