Go Back   SaturnFans.com Forums > Models > Saturn Relay > Relay General
Old 12-10-2017, 11:14 PM   #1
jcdr621
jcdr621 is on a distinguished road
Default engine overheating
coolant pushing out overflow, temp goes hot in 4 minutes, compression cyl.2-185psi cyl.4 135psi - cyl. 6,1,3,5 - 200psi
took off intake manifold and front ports for coolant are clogged
I am at an inpass if I should look into cylinder heads with this compression
not blowing any white smoke
oil is not milky
125000 miles
already changed radiator, thermostat, water-pump
Add to jcdr621's Reputation
Rate the quality of this post and help jcdr621 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jcdr621 is offline   Reply With Quote
Old 12-16-2017, 02:01 PM   #2
Default Re: engine overheating
A belated welcome to SaturnFans, jcdr621!
How about providing some basic information on this vehicle. Year? Engine size? Maintenance history?
It is possible to have a defective newly replaced thermostat along with the clogged intake manifold cooling system ports. You may need to test for exhaust gases in the cooling system. Here's a sample of a tool designed for this diagnosis - http://www.blocktester.com/
With one cylinder having significantly lower compression than the others, it might be best to seek out a professional opinion on this matter. In the end, you may have no other choice than to remove the cylinder head and have it tested. Nevertheless, this is conjecture on my behalf. I cannot know with certainty. You may also try looking into online forums - if they exist - for the other GM "cousin" models to the Relay: Chevy Uplander, Buick Terraza, and Pontiac Montana.
304,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 12-17-2017, 11:09 PM   #3
jcdr621
thank you pierrot
2005 Relay front wheel drive 3.5L
tune up done 30000 miles ago
oil change done every 6000 miles mobile 1 syn.
I pulled off the intake manifold and found the front ports clogged -- I am going to try to clean out the intake manifold and heater core
Old 02-13-2019, 02:49 PM   #4
Packard
Packard is a jewel in the roughPackard is a jewel in the roughPackard is a jewel in the rough
1995
check the oil for milky fluid.
Do radiator cap pressure test with this device . also with below tool .
Do coolant pressure test. Maintain 15psi of pressure while looking for leaks . . Leaks will cause overheating. Most parts stores allow u to rent them.
I dont know vehicle history . A stuck closed thermostat can cause this behavior too.A thermostat needs to open at a certain temp allow the engine to heat up to temp to get into closed loop state.
Add to Packard's Reputation
Rate the quality of this post and help Packard reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Packard is offline   Reply With Quote
Old 02-13-2019, 02:59 PM   #5
Packard
1995
How often are you having to refill the radiator? Do you have white smoke?
White smoke if u see this check the oil on the dipstick for milky oil. If so possible blown head gasket.
Engine Overheating pobserver S-Series General 8 03-17-2014 06:25 PM
Overheating Engine - 94 Jenn07 S-Series Tech 3 09-03-2007 05:15 PM
Engine overheating boatboy678 S-Series Tech 2 02-03-2007 10:07 PM
Engine Overheating Causes dlczrx S-Series General 9 07-05-2006 10:55 PM
help! engine overheating J.Simons S-Series Tech 6 06-08-2005 09:41 AM
