Old 09-15-2019, 07:51 PM   #1
tc1310
tc1310 is on a distinguished road
Default Random Clutch Pressure Problem
I have a 2000 Saturn SL1 that we drive occasionally. On 2 different occasions, we have driven it somewhere without issue. This issue has happened twice now out of 50 trips. (The other 48 trips did nt have any issues.) When we returned to the car, the clutch had no pressure, the car would start but would not go into gear. Eventually, it would start, the clutch would have pressure and run fine. The fluid is full. Any ideas?
Add to tc1310's Reputation
Rate the quality of this post and help tc1310 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tc1310 is offline   Reply With Quote
Old 09-15-2019, 08:25 PM   #2
billr
Default Re: Random Clutch Pressure Problem
No resistance to pushing in the clutch pedal, correct? That is almost certainly a bad master cylinder.
Add to billr's Reputation
Old 09-15-2019, 09:50 PM   #3
tc1310
Correct. It has only happened twice. I was afraid it might be the master cylinder. Sounds like that replacement is labor intensive. Thanks for the information.
Old 09-15-2019, 11:08 PM   #4
SlayZombi
SlayZombi is a jewel in the roughSlayZombi is a jewel in the roughSlayZombi is a jewel in the roughSlayZombi is a jewel in the rough
2001 SL
It actually isn't too bad. If you are even somewhat mechanically inclined I suggest doing it yourself. Just buy the master and slave cylinder ASSEMBLY for ~$100 (much easier to install the whole thing and also gets the possibility of the slave going out down the road). The only things you need to get out of the way is the airbox, battery tray, and the PCM. Literally maybe like 10 bolts you have to undo. I did it myself just last week and it took maybe an hour for the install.
Add to SlayZombi's Reputation
Rate the quality of this post and help SlayZombi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SlayZombi is offline   Reply With Quote
Old 09-16-2019, 06:32 AM   #5
Waiex191
Waiex191's Avatar
Or, buy a new sealed assembly for $30.
http://www.saturnfans.com/forums/sho...d.php?t=233551
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 09-16-2019, 08:26 AM   #6
Keep in mind this system can become permanently air bound right out of the box. They require special handling or you will have an uncorrectable failure.
Old 09-16-2019, 09:56 AM   #7
tc1310
Thank you all for the advice. It sounds like a task I may try to tackle on my own now. Our Saturn is an extra vehicle for us. It's always nice to have a dependable backup car around. Hope you all have a great week!
Old 09-17-2019, 12:46 PM   #8
That explains why this post was on that thread, looks like hholbein followed the link and post his response to this thread on that one by accident
Originally Posted by hholbein View Post
Here's a Richpin video on the removal/replacement steps:
https://www.youtube.com/watch?v=Hz9wQDofkaU
Old 09-17-2019, 04:28 PM   #9
hholbein
1997 SW2
Duh!!!
Add to hholbein's Reputation
2004 Vue AWD automatic Random flashing / blinking of low pressure light vikasevan Vue Tech 7 06-13-2017 09:56 PM
2001 sc2 new clutch master cylinder now no pressure on clutch rotolo64 S-Series Tech 6 10-21-2015 09:10 PM
Random Electrical Problem Ruzlok S-Series Tech 9 09-26-2009 12:52 AM
Manual trans grinding, clutch throw, other random questions eyexmeetsxeye S-Series Tech 5 10-04-2008 10:29 AM
2000 SL2... random rough starting problem zulaya S-Series Tech 6 06-08-2006 02:24 PM
