Old 09-17-2003, 08:21 AM   #81
1993SC2
1993SC2 is on a distinguished road
1993SC2's Avatar
1993 SC2
Default
[QUOTE]Originally posted by Ron77
[B]95sc2, one quart every 14 days, yikes! 117K miles.
1993 SC2m open filter element (aka "cold air" intake), glasspack.
When I'm hard on it: a quart a week, big-a## oil smoke if ya get on it when it's cold (not good), and still some when it's at op temp. 1 qt a week.
When I'm easy on it: Not much of either that I notice.
Then: 1993SC2m
Now: 1996 Jeep XJ, 2007 Kawasaki Ninja 650
Add to 1993SC2's Reputation
Rate the quality of this post and help 1993SC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1993SC2 is offline
Old 09-18-2003, 02:00 PM   #82
sean002
sean002 is on a distinguished road
sean002's Avatar
Default
95 sl uses approx 1qt every 1000 miles and has since it was bought.
Add to sean002's Reputation
Rate the quality of this post and help sean002 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sean002 is offline
Old 09-28-2003, 03:14 AM   #83
ttreibel
ttreibel is on a distinguished road
ttreibel's Avatar
2006 ION-2 Quad Coupe
2002 SL1
Default
My recently purchased 95 SLone is using a quart every 400 miles with mostly highway driving. I will try the MMO or B-12 trick next week and hope that losens the rings up. Last tank got 37 mpg pretty good up 5mpg from the previous tank all that new stuff and cleaning the EGR valve did help
1995 SL1 oil burner school commuter looks nice...1997 SL1 Gold 5-speed with new junk yard wheels and tires just got 40.4 MPG....2002 SL1 sometimes 45 MPG on a spring highway drive
Add to ttreibel's Reputation
Rate the quality of this post and help ttreibel reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ttreibel is offline
Old 09-30-2003, 01:40 AM   #84
ttreibel
ttreibel's Avatar
2002 SL1
Default
In case any of you are interested I posted a video of starting the 1995 SLone after an all night piston soak of MMO I did the B-12 earlier that day it is way stronger than MMO.
http://homepage.mac.com/ttreibel/iMovieTheater16.html
Modem users it's 11+MB
ttreibel is offline
Old 09-30-2003, 07:55 AM   #85
auxmike
auxmike is on a distinguished road
auxmike's Avatar
Default
Very cool video!Smoke,baby smoke!
Add to auxmike's Reputation
Rate the quality of this post and help auxmike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
auxmike is offline
Old 10-01-2003, 06:00 PM   #86
Hodado
Hodado is on a distinguished road
Default
97sw2 Consumed oil when I got it with 123K 1 qt every 500 miles replaced engine with verified low milage salvage yard motor at 136K now this one uses a quart every 1000k have tried everything listed on this site to correct problem to no avail.
Add to Hodado's Reputation
Rate the quality of this post and help Hodado reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hodado is offline
Old 10-01-2003, 08:05 PM   #87
1993SC2
1993SC2's Avatar
1993 SC2
Default
I used Lucas Oil Stabilizer and it worked fine for me... Just dump some in the crankcase. WHat's B-12?
Then: 1993SC2m
1993SC2 is offline
Old 10-02-2003, 05:46 AM   #88
DarkJedi
DarkJedi is on a distinguished road
Post Oil Consumption
On my 1999 SL w/ 50K on it, I haven't noticed any oil burning yet. But I am keeping an eye on it when I refuel just because of these forumns. Last thing I want is engine damage due to low oil.
My $0.02
Add to DarkJedi's Reputation
Rate the quality of this post and help DarkJedi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DarkJedi is offline
Old 10-02-2003, 01:27 PM   #89
ttreibel
ttreibel's Avatar
2002 SL1
Default
Berryman B-12 comes in a 16 oz can at auto part stores. It's stronger than MMO and a really old product/company like MMO I think the can says since 1908?.
B-12 is for serverly neglected engines mine was needing a quart at each fuel stop.
So far consumption seems way down but with only 225 miles to early to tell yet.
ttreibel is offline
Old 10-02-2003, 11:46 PM   #90
plum_sc2
plum_sc2 is on a distinguished road
1993 SC2
Default
before adding a can of restore, i'd go thru 1qt per 1000 miles...........now it's 1qt per 2000
1993 SC2 - 168,000 miles
2003 Vue - 104,000 miles
Add to plum_sc2's Reputation
Rate the quality of this post and help plum_sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
plum_sc2 is offline
Old 10-03-2003, 01:36 AM   #91
ttreibel
ttreibel's Avatar
2002 SL1
Default
I just flushed the engine and changed the oil....I am trying Mobil 1 0w-40w at 4.77 a quart I hope I don't use much at all in th 95 SL-1
The 2002 SL-1 I use the Mobil 1 5w-30w and it doesn't use a drop between changes.
After changing both engines oil it seems they both needed an extra 1/4 of a quart to top it off. So I either was shorted a bit from Mobil or you need more than 4 qts. at change with filter.
ttreibel is offline
Old 10-06-2003, 01:15 PM   #92
1993SC2
1993SC2's Avatar
1993 SC2
Default
neato... wish old computers were as good and useful.
Then: 1993SC2m
1993SC2 is offline
Old 10-08-2003, 11:35 AM   #93
vertigo
vertigo is on a distinguished road
vertigo's Avatar
Default
2000 SC2, 114K mi, burns 1 qt every 2500 miles. Just switched to Mobil 1. If that doesn't make a difference I'm going to try an MMO soak.
Add to vertigo's Reputation
Rate the quality of this post and help vertigo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vertigo is offline
Old 10-09-2003, 08:32 PM   #94
plum_sc2
1993 SC2
Default
..................oil burn is directly related to how much you beat on it, too............. mine only burps out a cloud near the redline
plum_sc2 is offline
Old 10-09-2003, 11:34 PM   #95
ttreibel
ttreibel's Avatar
2002 SL1
Default
1 quart in 2500 is not all that bad try a little MMO in the Gas and crankcase oil I bet the Mobil 1 will make a difference if nothing else your mileage will go up and your Saturn will run better when it's cold.
ttreibel is offline
Old 10-10-2003, 09:34 AM   #96
vertigo
vertigo's Avatar
Default
No, 1 qt per 2500 isn't bad at all. I'm not terribly worried about it. Now that I think about it, a soak is likely to be a waste of time since my rings are probably articulating just fine.
vertigo is offline
Old 12-23-2003, 08:50 AM   #97
t8sgolf
t8sgolf is on a distinguished road
Default
95 sc2 1 qt in 2000 mi 97 sc2 still full at 3000 01 L300 full at 3000
Add to t8sgolf's Reputation
Rate the quality of this post and help t8sgolf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
t8sgolf is offline
Old 12-23-2003, 10:04 AM   #98
SaturnL2Racin42
SaturnL2Racin42 is on a distinguished road
SaturnL2Racin42's Avatar
Default 7500 b4 my oil lite came on
b4 i totalled my 2001 sl 1 i had over 7500 miles after my last change and the oil lite stilll hadnt come on.... used fully synthetic 2 changes before that and i drove it like it was hot alll the time... put fully synthetic in it ... does wonder for ur oil life and the lil motr that can
Add to SaturnL2Racin42's Reputation
Rate the quality of this post and help SaturnL2Racin42 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnL2Racin42 is offline
Old 12-23-2003, 10:48 AM   #99
white95SL1
white95SL1 is on a distinguished road
white95SL1's Avatar
1992 SC
2004 VUE Red Line
Default
1995 SL1- 1qt. per 2000 miles.
friend's 1996 SL1- 1qt. per 500 miles or so (car smokes)
Brandon
'92 Saturn SCm- Red & Silver (rebuild in progress)
'04 Saturn VUE Red Line- Black Onyx
Add to white95SL1's Reputation
Rate the quality of this post and help white95SL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
white95SL1 is offline
Old 12-23-2003, 12:48 PM   #100
99SC1-R
99SC1-R is on a distinguished road
99SC1-R's Avatar
2008 Astra XR
Default
0 oil consumption is what I have observed so far with my car.
It used to go thru a quart every 100 kilometers but....its cause the "licensed mechanic" at Crappy tire 1) replaced oil drain plug with wrong one and 2) overtightened/stripped bolt as well without telling me.
Promblem is now fixed and it consumes so little oil its not worth mentioning.
Add to 99SC1-R's Reputation
Rate the quality of this post and help 99SC1-R reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
99SC1-R is offline
Saturn blues. OIL CONSUMPTION NOW woonyboi02895 S-Series General 11 03-10-2008 01:34 PM
Oil consumption in Saturn Engines 1.9 craftyone S-Series Tech 1 05-21-2007 01:06 PM
Has anyone ever held Saturn accountable for oil consumption DeMAN S-Series General 14 08-02-2005 03:13 AM
Fuel Consumption (survey) EnglishSL2 General Saturn Discussion 14 03-02-2004 11:21 AM
Saturn oil consumption survey ferdypooh Ion General 0 06-11-2002 12:20 AM
