Old 04-10-2012, 07:56 PM   #21
jonbarker
jonbarker is on a distinguished road
Location: A place in Florida where old people come to die
Default Re: Exhaust cam shaft timing gear
Originally Posted by OldNuc View Post
What are those?^^^^ To check holes use a small screw driver and see if the bottom is RTV/loctite/foreign material free. A fiber brush and a drill works well but finding a fiber brush is an undertaking.
OLS was supposed to OLD bolts. bad typing error
Add to jonbarker's Reputation
Rate the quality of this post and help jonbarker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jonbarker is offline   Reply With Quote
Old 04-12-2012, 02:20 PM   #22
jonbarker
Good afternoon Old Nuc !!!! On the DOHC. Is there a small rectangle shaped hole that releases oil on to the chain. It`s located just underneath the cylinder head bolt that's behind part of the exhaust cam sprocket. Thanks
Old 04-12-2012, 04:11 PM   #23
Old bolts that you are gong to re-use must be clean also.
Old 04-12-2012, 04:16 PM   #24
Look at this picture, are you talking about the rectangular port that is just above the head/block joint and just to the right of the head bolt?
Old 04-12-2012, 04:33 PM   #25
jonbarker
yeah, it`s just below and a tad to the right of the head bolt. is oil supposed to come out of there ? I do not see a picture link
Old 04-12-2012, 05:06 PM   #26
That is because I forgot it..
https://picasaweb.google.com/1159762...08923974669346
Old 04-12-2012, 05:26 PM   #27
jonbarker
Now that's what I call a hot ass DOHC engine rebuild !!!!!!!!!!!
Old 04-12-2012, 05:28 PM   #28
jonbarker
yeah it`s the rectangle port just to the right and underneath the bolt head on the exhaust side.
Old 04-12-2012, 09:19 PM   #29
That is one of the oil drains that happens to return into the chain area.
Old 04-13-2012, 09:50 AM   #30
jonbarker
OK, Cool that's what I thought. Just wanted to make sure I did not have a leak. are there any other port holes for oil to run through besides the two round oil seals ? I figure it would be a good idea to make sure nothing is clogged before I wrap this beast up.
Old 04-13-2012, 09:56 AM   #31
Unless you put the head gasket on upside down they are open. The rest of them are the round bulges on the block that run from the lower flange to the deck. They do not plug up so it is not a concern.
Old 04-13-2012, 10:27 AM   #32
jonbarker
Thanks, I`m replacing the o-rings for all the fuel injectors. The old ones are very dirty and greasy. I`m having trouble figuring out how to disconnect the electrical connectors. I feel like the retaining wires on the connector is going to bend or break.
Old 04-13-2012, 10:36 AM   #33
jonbarker
Got em off. No.'s 1,2 and 3 appear to have some type of oil in both ends of the electrical connectors.
Old 04-13-2012, 11:00 AM   #34
jonbarker
Almost forgot to ask. Is it OK to put some dialectic grease on fuel injector connectors ?
Old 04-13-2012, 02:19 PM   #35
No, The only part you can grease is the finned rubber seals so they are easier to insert. Do not grease so heavily you can see it either.
Old 04-13-2012, 04:18 PM   #36
jonbarker
Ok, The 8 seals are lightly oiled and secured back to the fuel rail. I did them one by one so I would not mix 'em up. These look like the Delphi brand I see on rock Auto. I also cleaned the connectors with electrical cleaner spray. so no dialectic on the wire connecters ? OK, Well there is another completed Saturn S-Series project in the book. Thanks man !!!!
Old 04-13-2012, 08:05 PM   #37
Have fun now!
Old 04-13-2012, 09:15 PM   #38
jonbarker
Yeah, This is awesome. i,m doing stuff I never have thought i could do. Thank god for the net, Haynes, Old Nuc, Richpin06, Razorback and of coarse the Saturn S-Series.
BTW, The packaging on my Genuine OEM parts states it`s shipped from Springhill, Tenn. I thought they shut down. You ever need any part numbers just let me know. I have everything, including bolts and push pins, lol
Old 04-13-2012, 09:48 PM   #39
I think they are still emptying a warehouse there.
Old 04-14-2012, 07:50 AM   #40
jonbarker
I see. I have another question before I put the timing kit and cover back on. How do i tell the year of the s-series. I think my exhaust cam might be just a tad little bent. I saw a DOHC s-series cam at the junk yard and it looks like it sets better on the lifters. Are all the DOHC cams the same ?
2007 2.2L broken bolt on timing gear firedog59 Ion Tech 2 04-14-2012 05:34 AM
Wiggle in Output Shaft Gear firestorm1284 S-Series Tech 2 08-26-2011 11:16 AM
2.2 balance shaft timing proceedure martin21044 L-Series Tech 4 04-25-2011 06:26 PM
Cam Shaft Timing Sensor ceh1354 2008 Vue 31 04-29-2008 02:04 PM
crank timing gear retention tool mdfrench Miscellaneous Tech 4 01-05-2005 12:33 AM
