#1 | ||||
![]() Join Date: Jun 2008
![]() my oil cap will un-screw fine but will not pop off. Anyone know how I can fix this???
#2 | ||||
![]() Join Date: Sep 2009
![]() pull hard..mine does the same thing..thinking about taking some sandpaper and sanding the cap a bit. May have swelled up over the years with all the oil and heat
#3 | ||||
![]() Turn it all the way till it stops, then turn it back a little bit.
... The proper way to fix a S-Series automatic is to replace it with a 5spd O:)
#4 | ||||
![]() I recently had the same problem, used a towel to cover it while I turned to help get a getter grip. Then I used a green scotch pad to clean it. When done I sprayed it with silicon spray and it's fine now.
... 7 Saturn Car Family with + 900,000 miles. 2002 SL2, 2000 SL1, 1997 SC2, 1997 SC1, 1996 SC1, 1994 SC2, and now a 93 SC2 project car.
Stuck Oil Filler Cap | kmdevo | S-Series General | 14 | 11-03-2014 04:13 PM |
Oil filler cap stuck | wishihadacamaro | S-Series Tech | 7 | 01-29-2008 01:11 AM |
Stuck Gas Cap? | TexcinTC | S-Series Tech | 2 | 12-10-2005 09:10 PM |
coolant reservoir cap stuck | kailuamike | S-Series Tech | 4 | 06-10-2005 07:05 PM |
High pressure Coolant Reservoir cap /w matching oil cap | treekiller | Ion General | 1 | 11-30-2004 12:10 PM |
