Old 11-19-2015, 12:15 PM   #1
Tseguin
Tseguin is on a distinguished road
2007 ION-3 Sedan
Default 07 ion 2 4dr sedan driver power window
Hello!
My 2007 ions driver side window will not go up! It goes down but cannot go any higher. This problem has been going on for a few years, before if I pressed on it on an angle, it would go up. Later it wouldn't go up unless I turned the car on and held the button at the same time.
It's the only window that does this, the passenger windows all work perfectly. A
Side note is that the lock button on the driver side doesn't work either and neither does the power window when switched to the driver side.
I'm just wondering if it's the regulator or the switch.
Tseguin is offline   Reply With Quote
Old 11-19-2015, 01:49 PM   #2
Cougarstang
Cougarstang is a jewel in the roughCougarstang is a jewel in the roughCougarstang is a jewel in the roughCougarstang is a jewel in the rough
2006 ION-2 Sedan
Default Re: 07 ion 2 4dr sedan driver power window
Originally Posted by Tseguin View Post
Hello!
Try wiggling the rubber boot that runs through the fender area into the door. This is where all of the wires run though and sometimes they fray. You may just have to fix a wire there.
My ride: 2002 Ford Mustang GT, 4.6L v8, 5-speed manual
Wife's ride: 2006 Saturn ION 2, 5 speed manual
Gone but not forgotten: 2000 Saturn SL1, auto
Cougarstang is offline   Reply With Quote
Tags
2007 ion, power window problems
Driver power window Tyler12189 S-Series General 6 03-02-2015 03:55 PM
'96 Sl2 Driver's power window does nothing dddaaa S-Series Tech 5 08-30-2011 01:15 PM
driver power window green S-Series Tech 6 08-17-2008 08:46 PM
Driver's side power window pooped out again 99SC2; other window/sunroof fine. Help? Jens99SC2 S-Series Tech 4 11-09-2005 07:40 AM
FS: 91-94 sedan/wagon power window switch pod ArghIGiveUp Classifieds 9 03-02-2005 05:53 PM
