Old 01-23-2010, 12:12 AM   #1
captsam
captsam is on a distinguished road
captsam's Avatar
1997 SW2
Default 1996 SL2 Dome light stays on or 'flickers'
My wife's SL2 started having weird issues with the dome light. In the "Door" position on the switch, the light is supposed to turn off when the key is turned to run. Right now it does turn off sometimes, but often stays on (even after the engine is started) It's as if it was in the "ON" position instead of the "Door" position. Don't quite get it. I'm going to take it out and see what I can do with it, but perhaps someone here on the forums has more insight or experience with this matter.
Thanks!
Sam
captsam is offline   Reply With Quote
Old 01-23-2010, 12:22 AM   #2
Default Re: 1996 SL2 Dome light stays on or 'flickers'
Its not the dome light that broke. Dome light will self destruct if you try to take it of the headliner.
One of your door switches is not playing well. The light is turned on in the door position by grounding the light through the door switch.
Play with the driver door switch. Any switch gets dirty enough and the light comes on. The postage stamp below is the schematic. Drag it off onto the desktop and load it into the photo viewer.
Old 02-04-2010, 07:38 AM   #3
captsam
captsam's Avatar
1997 SW2
^_^
Well, it didn't self-destruct coming out of the headliner. Putting it BACK was another story though. Should have taken your advice. I fixed it though. Initially, I tried to J-B Weld it... but the plastic was to brittle (the car is 14 years old). I guess So Cal heat does that to plastics. Oddly enough, the parts that had JB Weld held, but it would crack in another spot. I finally just resolved to zip-ties and that worked fine.
The photo hosting on saturnfans isn't working right now, so here's a link to what I did:
http://www.flickr.com/photos/2432516...16806/sizes/l/
Just in case anyone has this same thing happen.
The original problem has gone away somewhere along the way.
Old 02-04-2010, 11:13 AM   #4
Zip ties will work just fine. They are all brittle and hard as a rock.
Tags
dome light
ABS Light / Battery Light Stays ON + starter issues 97 SL1 IanDorety S-Series General 3 08-25-2009 11:08 PM
Oil Light Flickers While Idling rockermikey S-Series Tech 13 12-28-2008 08:33 PM
1995 saturn coolant light flickers idles up and down and hesitates reed88 S-Series General 33 08-27-2008 10:20 PM
Engine coolant light flickers rrharmon S-Series General 3 02-11-2004 01:09 PM
ABS Light stays on! devy525 S-Series General 15 10-10-2003 11:21 AM
