#1 |
![]() Join Date: Jun 2009
I give up! I can't find that sucker. I've looked all along the bottom of the radiator, but can't find the drain plug. Is it a screw plug, bolt plug or a petcock? And where is it? THANK YOU for any help, I'm really embarrassed I can't find it...
![]() This is a 2000 LS1, by the way. |
#2 |
should be the face of the radiator on the engine side on one of the end caps near the bottom. if not pull the hose.
Rob 2001 Turbo L200 1997 F150 XLT 1985 Range Rover Classic 1999 Yamaha Blaster YFS200 Do It Yourself |
#3 |
I was confused b the "LS1" designation as this doesn't seem to be a valid model. The '00 L200 is and the drain is as described with an additional 3/8in dia. hose to attach for draining into a container. Is this picture helpful?
VCX NANO |
#4 | |
![]() Quote:
![]() I think that picture helps. I think I remember seeing something like that on the passenger's side of the radiator, it looked to be a red cap where that picture describes the hose attaching. So I'm thinking you unscrew the cap, attach the hose, then turn the release with a slotted screwdriver... I think. I'll have to try that when I get home in a few hours, I'll let you know. |
#5 |
![]() Join Date: Mar 2006
2005 ION-2 Sedan
just pull the hose. those drain plugs are very prone to breaking....
#6 | |
![]() Quote:
Thanks for all the help! ![]() |
#7 | |
![]() Join Date: Jun 2015
2003 L-Series 2.2L Sedan
![]() Quote:
all LS1 is the "S" stands for "Sedan" ans L "W" 1 is "Wagon" hope this clarifies the confusion! ![]()
2003 Saturn L200; Stock 2.2L ECOTEC 4 spd. Automatic. 155, 877 miles. still runnin' strong! |
Bookmarks |
Tags |
drain, flush, plug, radiator |
Stuck radiator drain plug | ifried85 | S-Series Tech | 9 | 04-18-2009 01:50 PM |
Radiator drain plug | wishihadacamaro | S-Series Tech | 6 | 11-16-2008 12:27 AM |
Radiator drain plug leak | rreuben | S-Series Tech | 12 | 09-19-2007 01:07 PM |
radiator drain plug leak | wojtek_f | S-Series Tech | 0 | 08-11-2007 05:33 PM |
Dumb radiator drain plug | SLeepr | Miscellaneous Tech | 3 | 03-26-2003 12:34 AM |
