#1 | ||||
![]() Join Date: May 2008
![]() I have a 95 SL2 I am working on for a friend. She complained of a check engine light "and some other light" that she didn't remember, coming on intermittently.
Plugging the ALDL A&B pins together gives me code 11 on the check engine light, and code 23 on the coolant level/temp high light on the other side of the dash. Code 11 looks like a transmission code but I can't find what code 23 on the coolant level/temp high light means. Hopefully it tells me more about what transmission fault is being reported. Can anyone shed some light on this? Hopefully she does not have a major trans issue, I got rid of my 93 SL2 with less than 90k miles on it because after replacing the valve body twice I was never able to resolve harsh 1-2 part throttle upshifts. I thought the TAAT was supposed to be pretty durable! Her car has only 81k on it too Thanks Steve ... Rides: 2004 Ford Taurus SEL 2003 Mercury Marauder 1988 Chevy K1500 1976 Pontiac Firebird
#2 | ||||
![]() From our library here; http://www.saturnfans.com/forums/showthread.php?t=44420
And from another site with more info; http://www.differentracing.com/tech_...ttc_chart.html
#3 | ||||
![]() Thank you for that info. No 3rd gear, holy crap. That's not good. I have a spare reman valve body but I am sure as heck not going to change another TAAT valve body with an unsure probability of fixing anything.
The only things I can think of are to check the adjustment on the range selector, and to check to make sure the multi-pin plug that goes to the valve body, is not corroded or full of fluid. ... Rides: 2004 Ford Taurus SEL 2003 Mercury Marauder 1988 Chevy K1500 1976 Pontiac Firebird
Check engine light and Code P0221 | jgt157 | L-Series Tech | 5 | 06-04-2018 08:16 PM |
Check engine light on code p000a | HECTOR VAZQUEZ | Astra General | 7 | 02-13-2009 01:14 PM |
Check engine light on=O2 sensor code | Nocturnal One | S-Series General | 14 | 05-30-2007 10:47 AM |
check engine light.. no code??? | runerx | Vue Tech | 4 | 04-17-2006 01:17 AM |
check engine light, no code | diestrutionomeg | S-Series Tech | 7 | 08-03-2004 12:56 AM |
