Old 09-23-2012, 08:08 PM   #1
raven_nevermore
raven_nevermore is on a distinguished road
Default Fuel Pump Help
I need to change my fuel pump. I know I can do it by cutting through the floor. I saw a post where someone did it on a L-Series. Does anyone know if the sending unit on the S-Series is located in the same spot i.e under the rear driver side seat.
Also, some one on here helped me last month with an ETCS problem; I can't find the post but just wanted to say thanks
Add to raven_nevermore's Reputation
Rate the quality of this post and help raven_nevermore reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
raven_nevermore is offline   Reply With Quote
Old 09-23-2012, 08:14 PM   #2
raven_nevermore
Default Re: Fuel Pump Help
Sorry, I just noticed that on the L-Series it was actually in the middle of the rear seat pan. Same question though, is the S-series in the same location?
Old 09-23-2012, 09:33 PM   #3
off-track
off-track has a spectacular aura aboutoff-track has a spectacular aura about
off-track's Avatar
This is the correct way to do it. I've done it twice now and it's really not that difficult at all.
http://www.saturnfans.com/forums/sho...d.php?t=142900
1997 - SL2, barebones, 161k, Auto - Rebuild complete and.. burnt a valve 20k later Arrgh!
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Rate the quality of this post and help off-track reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
off-track is offline   Reply With Quote
Old 09-23-2012, 10:25 PM   #4
macbox
macbox is on a distinguished road
macbox's Avatar
1998 SW2
Just make sure you get the car up high enough, otherwise it is a huge pain to remove the tank.
#4, 1995 SC2m, 163K, 400 Miles per quart, black leather interior, Factory Moonroof that works.
#5, 1998 SW2m, rebuilt at 126K, running nicely after 10K miles.
Add to macbox's Reputation
Rate the quality of this post and help macbox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
macbox is offline   Reply With Quote
Old 09-24-2012, 08:45 AM   #5
alordofchaos is a jewel in the roughalordofchaos is a jewel in the roughalordofchaos is a jewel in the rough
1997 SC2
Easiest way to find one of your threads... click on your username at the left. You will get a drop-down menu; select "find more posts by <your user name>
In the upper right corner, you can also select advanced search, and look for threads started by <your user name>
...Wait, what, I actually won that eBay auction?
Guess I now (12/2008) own a 1998 SL2, silver 5 spd :p
And now (7/2010), a Craigslist 1997 SC2 5 spd
Old 09-24-2012, 07:02 PM   #6
raven_nevermore
Thanks for the How-to..
However, while at autozone to get my fuel pump the guy informed me that it might not be the fuel pump that's wrong.
Here's the situation:
I have a 1998 SC2 137k miles Automatic.
Last Tuesday well driving in the a very bad rain storm the car died. i had been on back roads and got on the freeway and after going a little over 5 miles at about 40MPH the car died.
I though it was the fuel pump based on no fuel at the Schrader valve. However I just learned today that the key needs to be in the "run" position for there to be fuel at the schrader valve. When I put the key in the "run" position I get fuel at the schrader valve. So I'm guessing its not the fuel pump.
The car cranks but thats all.
Any ideas would be great.
Thanks
Old 09-24-2012, 07:18 PM   #7
ssicarman
ssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to all
ssicarman's Avatar
Have checked for spark? If there is no spark thern start with the crank position sensor.
Add to ssicarman's Reputation
Old 09-25-2012, 07:29 AM   #8
1997 SC2
^ ^ ^ typical failure mode of the cps is that it does not work when the engine is warm but works fine when cooler (no spark, but you have to check immediately when engine is still hot - need one person to crank while the other checks)
Old 09-25-2012, 09:38 AM   #9
raven_nevermore
I disconnected the 4 and 1 wire and there was no spark. I'm having autozone ship a CPS to my local store. Should be here by noon today.
Old 09-25-2012, 03:23 PM   #10
raven_nevermore
Just replaced CPS and still have no spark. any ideas where to go from here?
Old 09-25-2012, 04:02 PM   #11
Checked all fuses again? The second most failure prone item after the cps with no spark is the ignition control module (where the two ignition coils plug into). Junk yard ignition parts, icm and coils, are cheaper than new and work just as well.
Be sure the cps is fully seated. Any gap from not seating it into its hole can cause the same no spark issue.
Old 09-26-2012, 03:51 PM   #12
raven_nevermore
replaced ICM and it started right up.
Fuel cap loose code after changing fuel pump Rebarts L-Series Tech 3 06-19-2012 12:20 PM
I don't have a fuel pressure gauge, is there a way to check problem fuel pump without dddaaa S-Series Tech 6 08-06-2011 02:09 PM
Fuel Pump 2011: PT3 - Bosch Fuel Sending Unit Part Number? x-angel S-Series Tech 4 03-23-2011 11:34 AM
Help! Changed fuel pump, Now my fuel gauge is stuck on full! jimbo1490 S-Series General 5 06-14-2009 04:59 PM
FUEL PUMP or FUEL SENDING UNIT?.. saturn94v S-Series Tech 6 07-27-2008 09:40 AM
