Old 07-20-2017, 01:59 PM   #1
roberto92
roberto92 is on a distinguished road
Default 97 SL2 brake line replacement
Hello all, the rear right brake line on my car burst right under the driver side door. For some strange reason, the line looks good except for about a 3' stretch that is absolutely rusted to heck.
Thoughts on just replacing the line from the master cylinder to the closest stretch of good condition line vs. replacing the whole thing?
Also, I'm having a hard time finding a definitive answer on the fitting size into the MC, is it not the 3/8 24 thread?
thank you all!
Add to roberto92's Reputation
Rate the quality of this post and help roberto92 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
roberto92 is offline   Reply With Quote
Old 07-20-2017, 02:19 PM   #2
saturnsctwo
Default Re: 97 SL2 brake line replacement
thank you all!
my brake line burst over the rear cross member like many others did & a garage just spliced in a good line in that area. you could probably do the same thing, just splice in a good section to replace the rusted area.
Old 07-20-2017, 03:05 PM   #3
Waiex191
Waiex191's Avatar
Hi,
Welcome to the forum. I documented my brake line replacement on page 7 of my thread:
http://www.saturnfans.com/forums/sho...=230898&page=7
The flare nuts are metric, not SAE. You could either replace it all or make a splice, but you will need a bubble flare for the rubber hose connection.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 07-20-2017, 03:10 PM   #4
RobertGary1
Where are you located. I assume this is a rust belt thing.
-Robert
RobertGary1 is online now   Reply With Quote
Old 07-20-2017, 03:31 PM   #5
roberto92
My only concern with splicing would be the difficulty of doing the flairs upside down under the car. Tips on that?
If I were to splice it, the fittings wouldn't matter, as long as the ones I put on the existing line match the ones on the new line, correct? (I would get the pre-flared line)
I'm in Ohio, so it is 100% a rust belt issue unfortunately. The car is holding up fairly well considering.
Old 07-20-2017, 04:13 PM   #6
RobertGary1
My oldest is at OSU. I tell him he doesn't need a car since he lives basically across the street from the Union.
-Robert
Old 07-20-2017, 11:34 PM   #7
Pipes are round...I can't see upside down mattering in any fashion
As long as the flares match the connector's flare and match the MC you'll be fine. I believe factory use's bubble flares which is usually approximated good enough by not quite finishing a double flare. "good enough" because the full double-flare kit is under $50 and the right bubble flare kits start at $100 (last I checked, price's could have changed).
I'm not sure of nut-size's at the master cylinder but I believe ABS units use different nuts than non-ABS unit.
Old 07-21-2017, 05:07 AM   #8
Waiex191
Waiex191's Avatar
A pre-flared line would work and you could use a normal flare union to join the parts. You can loosen the clips holding up the line to drop it, that would allow you to get to it easier to flare. Only danger there is the spot welded studs may be rusty too, and they can fail.
Bryan Cotton
Old 07-21-2017, 08:41 PM   #9
roberto92
I graduated from OSU a few years ago. Great place.
I decided to try to splice some line in, as i thought it would be easier. Rented a flaring tool that didnt really work (3/16 hole was too worn to hold the line tight enough). I'll be going to a different store to try another rental in the morning.
Old 07-22-2017, 12:10 AM   #10
jhonky
jhonky is on a distinguished road
I think the brake line i got from the jy cost like 6.95
98 SL2
5th gear swap- .643 gear
245,000 miles
215/45 17"
I burn about a quart about every 1500 miles.
If it ain't broke, fix it some more.
Add to jhonky's Reputation
Rate the quality of this post and help jhonky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jhonky is offline   Reply With Quote
Old 07-22-2017, 04:18 PM   #11
roberto92
Got the line on there! New problem, when attempting to bleed (using a hand held vacuum pump) I was unable to get any fluid out of the drum with the replaced line. (Rear left, not right as I initially thought) I successfully bled the other three corners, but could not get anything out of this one. Any thoughts?
Also, a big thank you to everyone on this site. Two years ago I knew nothing about cars, and I have learned so much from the wealth of knowledge this signet has.
Old 07-22-2017, 04:52 PM   #12
Given the "high" cost of new brake line...I can't see the point of buying used brake line...lol
If you can get the bleeder screw entirely out, check for debris and clean it out. If that's clear and you still aren't getting fluid, take the new line back off the cylinder and see if there's any sign of fluid there. Other than some knuckle head putting a nail in the line (was why my 3/4ton truck had no rear brakes) at the MC I can't think of a non-ABS related reason why there'd be fluid at 1 rear wheel and not the other.
Possibly the vacuum gun isn't making a good seal on the bleeder screw, they're fairly cheap to replace (under $5) but if you have a zip-tie handy that should fix it for even cheaper.
Old 07-22-2017, 05:09 PM   #13
roberto92
I'll take the bleeder screw out tomorrow, after some wd40, I had no problem loosening it. If that doesn't help, do you mean unscrew the line at the soft hose that goes into the drum? I only replaced about 40" so I didn't touch the master cylinder.
Possibly of note, the master cylinder did get almost empty, as it was a pretty bad line burst. Not sure how much that matters as I had no issues bleeding except for this corner.
As for the vacuum pump, with some finagling I was able to get it secure enough on the bleeder screw to hold what was more than enough to bleed the others (about 15inHg)
Old 07-22-2017, 06:04 PM   #14
Dsaturn
Dsaturn is a jewel in the roughDsaturn is a jewel in the roughDsaturn is a jewel in the roughDsaturn is a jewel in the rough
2001 L-Series 2.2L Sedan
It could be that the rubber line collapsed internally causing a blockage. Take that line off the wheel cylinder and brake line and see if you can blow through it both directions with an air compressor if you have one.
Add to Dsaturn's Reputation
Rate the quality of this post and help Dsaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dsaturn is online now   Reply With Quote
Brake line replacement cromwell362 L-Series Tech 1 05-25-2014 07:55 AM
Complete brake line replacement. Help.. CaptainMouse64 S-Series Tech 23 05-31-2013 10:55 AM
Brake Line Replacement - simple, right?? ShelfLife S-Series Tech 3 05-11-2010 09:03 AM
help with brake line replacement kaph S-Series Tech 5 04-16-2009 09:24 PM
Brake line replacement...all or none??? mile2885 S-Series Tech 2 09-13-2007 09:50 PM
