Old 12-01-2002, 01:16 AM   #1
johnsocal
johnsocal is on a distinguished road
johnsocal's Avatar
Default Will the Quad-coupe be faster then the Ion sedan?
Except for the super-charged QC that comes out next year, how will the normal Quad-coupe be faster then the sedan if the both have the same chassis, tranny, and engine.
A coupe that goes 0-60 over 10 seconds is really sad.
Add to johnsocal's Reputation
Rate the quality of this post and help johnsocal reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
johnsocal is offline
Old 12-01-2002, 03:11 AM   #2
L300Boy
L300Boy is on a distinguished road
L300Boy's Avatar
Default
Yes, it will be. By how much? Not sure.
The coupe will not feature the 5 speed auto, but only CVT and 5 speed manual. The last two are almost identical in acceleration performance...but GM's implementation in the VUE has shown that the CVT is about a second faster.
... and lets hope that they "gear" for performance with the CVT.
Add to L300Boy's Reputation
Rate the quality of this post and help L300Boy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
L300Boy is offline
Old 12-01-2002, 04:23 PM   #3
GR898SL2
GR898SL2 will become famous soon enoughGR898SL2 will become famous soon enough
GR898SL2's Avatar
Default
Yes, it will be, but how much more so remains to be seen. The stick should do 0-60 in 9.2-9.5, even with a weight and length disadvantage. The tuner should match the first-gen SC's levels of power.
Not only is a coupe doing 0-60 in ten seconds sad, chances are good it won't sell.
Add to GR898SL2's Reputation
Rate the quality of this post and help GR898SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GR898SL2 is offline
Old 12-01-2002, 07:19 PM   #4
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
Default
Hrm, I drove about 20 ION sedans today, with both manual and auto transmissions, and the 5 speed auto felt faster (if placed in I instead of D). Neaither of them felt as quick as an L series with the 2.2 and auto, and actually in an informal stoplight drag, an L200 with about 1800 miles on it (customer return) whooped me big, and I was in an ION-1, with small wheels which *should* have helped acceleration some.
~D.J.~
OhioVueBoy is offline
Old 12-01-2002, 11:44 PM   #5
Ecator
Ecator is on a distinguished road
Ecator's Avatar
Default
Ok, I keep looking at the ION engine and getting confused.
Some places say it has a 137hp/142ft-lb, other places have 140hp/145ft-lb, the second rated at 5800rpm/4400rpm respectively.
So was there something that changed or was it originally 137hp?
Add to Ecator's Reputation
Rate the quality of this post and help Ecator reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ecator is offline
Old 12-02-2002, 09:14 AM   #6
eRic 02sc2
eRic 02sc2's Avatar
Default Re: Will the Quad-coupe be faster then the Ion sedan?
depending on curb weight differences between the sedan and quad coupe they should be about the same with the 5-speed manual and same tires and wheels.
saturn's specs for the 2.2L ecotec in the ion are 140hp@5800rpm and 145ft-lbs@4400rpm. other sources may have incorrect info and/or confuse it with the numbers for the 2.2L ecotec in the l-series that are 135hp@5200rpm and 142ft-lbs@4400 rpm. sure it's the same engine but with different tuning. then there's the vue 2.2L ecotec with 143hp@5400rpm and 152ft-lbs@4000rpm. confused yet?
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 12-02-2002, 01:10 PM   #7
L300Boy
L300Boy's Avatar
Default
Saturn originally stated 137hp/142ft-lb .....
then there was a lot of outrage in the community since the numbers were under even what the 2.2L cavy was rated at...
The numbers were "bumped" to 140hp/145ft-lbs.
Whether or not the "community" had anything to do with that is up in the air. But it wouldnt be the first time that happened....
L300Boy is offline
Old 12-02-2002, 02:18 PM   #8
SCDYNE
SCDYNE is on a distinguished road
SCDYNE's Avatar
2007 SKY
Default
This makes me wonder if the real HP and TQ ratings are still 137/142, but Saturn hasn't been installing the correct PCM load.
This would also help to explain why the Twistec coupe showed such crappy stock dyno numbers.
Maybe Saturn Motorsports needs to put a few IONS on the dyon and make sure Saturn isn't screwing some people out of an advertised 3 HP and 3 TQ...
Oh wait even if it was it wouldn't matter, 3 is about the difference of another passanger..
Forget it all the ION has terrable power.
IT NEEDS BOOST!
-Adam Chant
2007 Saturn SKY - Supercharged
1997 Saturn SC2 - Stock Rebuild
Add to SCDYNE's Reputation
Rate the quality of this post and help SCDYNE reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SCDYNE is offline
Old 12-02-2002, 03:46 PM   #9
Jeff P
Jeff P is on a distinguished road
Jeff P's Avatar
Default
nah I think 137/140/145 hp or whatever it is is perfectly adequate for an economy car. Maybe not THIS economy car, but it'd be plenty for most others.
IT NEEDS BOOST!
For the sport model, absolutely. For the regular model, what this sucker needs is a diet! Sadly, there's simply no way this car can lose the 200-300 pounds it so desperately needs to. I'm afraid the ball has been dropped, and there won't be another chance to pick it up until the Ion replacement shows up in 5 or 10 years.
jeff
Add to Jeff P's Reputation
Rate the quality of this post and help Jeff P reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jeff P is offline
Old 12-02-2002, 04:40 PM   #10
FireMate
FireMate is on a distinguished road
FireMate's Avatar
Default
Well, maybe it's not too late... I mean, Saturn could start installing carbon fibre hoods, remove the battery altogether (we'll turn the sunroof into a solar panel for storing power), remove the trunk lid altogether (hmmm... may look weird, but since we're saving weight...)....
Product Specialist, fellow Saturn Employee and Enthusiast
Add to FireMate's Reputation
Rate the quality of this post and help FireMate reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FireMate is offline
Old 12-02-2002, 05:56 PM   #11
L300Boy
L300Boy's Avatar
Default
damn, no quad coupes for us in rainy washington state...
L300Boy is offline
Old 12-02-2002, 06:50 PM   #12
Tuanies
Tuanies is on a distinguished road
Default
Interesting, why not? I live in WA and was thinking of an ION QC when I graduate College in about 3-5 years.
Add to Tuanies's Reputation
Rate the quality of this post and help Tuanies reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tuanies is offline
Old 12-02-2002, 07:02 PM   #13
L300Boy
L300Boy's Avatar
Default
That was a joke! Of course the QC will be great for washington state.
We dont get any sun here, so obviously Firemate's QC concept wouldnt function very well here ... ha ha
L300Boy is offline
Old 12-02-2002, 07:27 PM   #14
GR898SL2
GR898SL2's Avatar
Default
The ION's Ecotec engine was rated at 137-hp/142 ft-lbs when first previewed in NYC, and GM included those figures in March 27th press releases.
Four days later, the Ecotec hp/tq ratings were upgraded, but by then, the automotive press took the first set of figures and basically ran with them, so nobody is really right or wrong when it comes to an additional 3-hp/3ft-lbs.
Rather than GM/Saturn go through an expensive and time-consuming overhall of their press kits, those who wanted to find out more were instead guided to Saturn's ION website for the most up-to-date information.
GR898SL2 is offline
Old 12-02-2002, 10:06 PM   #15
Ecator
Ecator's Avatar
Default
Freaky, its like that previous company that actually overstated numbers...eh...heh...
Ecator is offline
Old 12-03-2002, 12:17 PM   #16
benpatient
benpatient is on a distinguished road
benpatient's Avatar
Default
the simple answer to the original question is probably "no"
this is because the Coupe weighs more than the sedan, thanks to the quad door thing needing extra metal and parts and such.
so if two cars with the same manual 5 spd tranny and the same engine tuned to the same power level built on the same platform with essentially the same body were to race, and one weighed more than the other, which would win, provided the drivers were both capable? the lighter one. in this case, the ION sedan.
unless they are re-tuning the coupe, it will have to be slower, technically speaking.
Add to benpatient's Reputation
Rate the quality of this post and help benpatient reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
benpatient is offline
Should Saturn Graft the Front of the Quad Coupe onto the ION Sedan? Charlie Polls and Questions 44 10-31-2005 10:47 PM
05 Ion Quad Coupe stinkpeas Ion General 2 02-02-2005 11:23 PM
ION Sedan vs. Quad Coupe KrgION03 Ion General 9 05-16-2003 01:23 PM
Ion Quad-Coupe KoolVue Ion General 4 02-06-2003 01:12 PM
~*~ION Quad Coupe~*~ zoe1982 Ion General 2 10-17-2002 02:05 PM
