Old 04-15-2009, 06:14 PM   #1
kaph
kaph is on a distinguished road
Default help with brake line replacement
I need to remove the front driver's side brake line to replace it. Can anyone tell me what tool works to remove it from the master cylinder? It seems as though there is not enough room to get a wrench in there to loosen it. Also, is there any other warnings/advice when doing this job. I would just be replacing the brake hose, but I can't get it to separate from the brake line. It won't budge no matter what I seem to do and the nut is rounding off despite my getting the proper wrenches for the job. Thanks.
Add to kaph's Reputation
Rate the quality of this post and help kaph reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kaph is offline   Reply With Quote
Old 04-15-2009, 06:45 PM   #2
kaph
Default Re: help with brake line replacement
I forgot to include that it is a 2001 Saturn SL1
Old 04-15-2009, 08:36 PM   #3
rc1488
rc1488's Avatar
You need these:https://realcashsavings.com/pimages/L11225202.jpg
Anything else will round the bolts.
You need a 14 or 12mm for the master cylinder side. Yes it will fit but its a slow process bc there is not alot of room.
I forget the size of the wheel end. However, the wheel end should break free. PB Blaster is your friend.
Add to rc1488's Reputation
Old 04-16-2009, 02:17 AM   #4
Since a pic won't help with a search, what you need is (use these phrases) a "line wrench" or "flare nut wrench".
Add to madpogue's Reputation
Old 04-16-2009, 06:34 AM   #5
stu
stu is on a distinguished road
1997 SW2
Once you have decided to trash the line, look at cutting it off as close to the fitting as possible with a hack saw blade.
Then you can slide a socket or deep socket over the fitting. There is usually room to get a breaker bar into the socket, if not the ratchet.
Add to stu's Reputation
Rate the quality of this post and help stu reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
stu is offline   Reply With Quote
Old 04-16-2009, 09:24 PM   #6
Bruce Rock
2000 SL2
2006 VUE 2.2L
I use a vice grips OVER the wrench (to prevent the flare nut wrench from opening up) and even with my cheap Harbor Freight set I don't round the edges of the flare nut.
Add to Bruce Rock's Reputation
Rate the quality of this post and help Bruce Rock reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brake line gone wojtek_f S-Series Tech 10 04-02-2008 01:20 PM
plugging brake line green S-Series Tech 3 11-03-2007 12:29 PM
Brake line replacement...all or none??? mile2885 S-Series Tech 2 09-13-2007 09:50 PM
Fuel Line Replacement. EclecticGuy S-Series General 1 07-08-2007 01:16 AM
Brake line Gottofried S-Series General 4 06-14-2005 01:56 PM
