1993 SC2 5 Speed A/C. Lots of new parts. $600. Silver Spring MD area. Pics are in my gallery. More available on request.
http://www.saturnfans.com/photos/sho...0&ppuser=13295 Had started as a project for a daily commuter but I've just got too many upcoming projects to continue. You may want to look at her as a parts car or as a project to finish. She looks great & finished but... The Good - Decent Teal Paint (aren't they all decent?) Good/Very Good beige interior A/C works All Glass Good Seatbelt 'mice' work Runs well - slight tick after sitting a while (days-weeks) All new Mounts - Saturn Parts - engine & tranny New Axles (remanufactured) New Hub Bearings New KYB Struts Front & Rear New KYB Strut Mounts (Front) New Front Lower Control Arms New Front Brakes & Rotors New Knock Sensor 4 new Dunlop Graspix DS2 Snow Tires on new Steel Wheels (<500 miles) Passed MD State inspection several months ago. Original teardrop Alloys with ok tires The Bad: Needs Front Cradle or someone who knows how to 'adjust' them. Car had bent front cradle. I obtained a fresh one from the junkyard, cleaned & painted it... turns out it's bent too...slight deformation on driver's side by lower arm mount. Priced new one @ $645 at dealer. Has 'clunk' when initially starting out - may be loose mount that I didn't tighten fully or ?? Have a clinking noise that --sometimes-- appears while driving, but not always. Is related to road speed. Varies by car speed, not by engine speed. Can hear while coasting in neutral... may be bad remanned CV joint?? Have original axles which made no noises. Have new - Temp Sensors, Thermostat & Speed Sensor Will be glad to answer any questions. Thanks, Jay |
Is it driveable with the cradle bent up?
EDIT: Whats the milage too? |
ARGH! left out the mileage.. 162k
Very drivable. Cradle isn't 'all bent up', just deformed enough that the best camber I could get is 1 degree positive... so it's just slightlty positive cambered on the drivers side but ok on the passengers side. Makes it a little bit sensitive at highway speeds but drives ok. Was good enough for MD inspection. Thanks, Jay |
Is the clutch in decent shape? Or is it needing to be replaced?
Im very interested in your car ![]() |
#5 |
Clutch appears to be in decent shape. Don't know it's history but it will easily hold car to stall (DOH!) and chirp tires on agressive take off.
Open to offer if you're really interested & can take her soon. Losing my garage space (neighbor selling house where I had use of garage) and need to move other hobby cars (3) to my house. |
The only issue being you are so far away.
Id have to spend like 100$ in gas alone ![]() |
#7 |
95 Saturn SC2 5sp 144k with a high idle? | fritcr | S-Series Tech | 35 | 01-22-2009 11:22 PM |
95 SC2 5sp with 142k on it. Will not start. | fritcr | S-Series Tech | 23 | 12-28-2008 01:45 PM |
what kind of trans fluid? 94 sc2 dohc 5sp | sc2dohc94 | S-Series Tech | 6 | 03-24-2008 04:55 PM |
1995 SL1 5sp Trans, 94 SC2 Parting Out | gsieg | Classifieds | 15 | 12-30-2005 02:01 AM |
97 SC2 Low idle hesitation on acceleration 5sp. | lazyman73 | S-Series General | 1 | 11-11-2004 12:32 AM |
