Go Back   SaturnFans.com Forums > Models > Saturn Sky > Sky Tech
Old 07-11-2018, 10:39 PM   #1
KEP3
KEP3 is on a distinguished road
2007 AURA XE
Default Roof "flaps" won't open when closing top
The two "flaps" that are behind the seats are supposed to automatically flip open when the roof is being closed. On my 2008 Redline, most of the time they stay closed and I have to manually open them, which is a royal pain because they'' shut again if the roof moves too far. It looks like GM just ran down to JoAnn Fabrics and bought some elastic ribbons to move them. Any suggestions?
KEP3 is offline   Reply With Quote
Old 02-19-2019, 08:24 PM   #2
Mikey-Sky
Mikey-Sky is on a distinguished road
Default Re: Roof "flaps" won't open when closing top
Sounds like the tension springs on the outboard side have let go. Because this whole piece is part of the rear body tonneau cover you may have to replace the whole thing like I just did. If you hold the door open does it have any tension and seem like it wants to close up. If it does the spring is okay and it is possible the small cables have broke. The cover is on Ebay at a great price. Sure was a stupid way to design these small doors.
Mikey-Sky is offline   Reply With Quote
Old 02-20-2019, 11:29 PM   #3
KEP3
2007 AURA XE
There is some tension but apparently not enough to pop open. The cables keep slipping off the flaps. Why they even exist is a good example of stupid engineering in my opinion.
As we dig out of 4" of snow and slush I really don't think I'll be going for a run in the sun any time soon. How hard would it be to replace the tonneau?
Old 12-27-2020, 04:26 PM   #4
KEP3
2007 AURA XE
Okay. I haven't been able to get the flaps to work correctly. So, has anyone had a shop fix the cables and connections so they work right? How bad was the damage? Something to save towards for this spring.
Old 09-12-2021, 08:55 PM   #5
KEP3
2007 AURA XE
As I was raising the top I noticed there was a small hole in the one lift arm. It was where one end of the cable attached. I didn't get a good look as it was dark. Could this possibly be an Allen nut that can tighten the cable?
Turn signals silent when flashing, "dinger" not working when doors open, etc. rcote20 Ion General 3 06-12-2013 10:27 PM
"Exciting Times" Why dealerships closing melmar1999 General Saturn Discussion 17 03-20-2009 12:51 PM
Will unplugging O2 put "warm" obdII car in open loop?? tgferg67global S-Series Tech 1 06-24-2005 05:30 AM
"Trunk open" light keeps coming on sportster64 L-Series General 3 11-15-2004 07:08 PM
Open exaust causing engine "miss"????? Jon94SoLo2 S-Series Tech 4 05-21-2001 06:50 PM
