Old 03-07-2007, 08:38 PM   #1
Azrael_02
Azrael_02 is on a distinguished road
Azrael_02's Avatar
2009 VUE Red Line
2004 ION Red Line
Default Bulb Replacement
Does anyone know what kind of bulb fit/replaces the rear directional light?
Add to Azrael_02's Reputation
Rate the quality of this post and help Azrael_02 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Azrael_02 is offline   Reply With Quote
Old 03-07-2007, 09:01 PM   #2
e2helper
e2helper is on a distinguished road
2007 AURA XR
Default Re: Bulb Replacement
Owner manual says #3156
Add to e2helper's Reputation
Rate the quality of this post and help e2helper reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
e2helper is offline   Reply With Quote
Old 03-08-2007, 12:08 AM   #3
Azrael_02
Azrael_02's Avatar
2009 VUE Red Line
2004 ION Red Line
Thanks. Anyone know if its a red or white bulb?
Old 03-08-2007, 02:29 AM   #4
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
The lens is red and there is no suffix (i.e. 3157 = white, 3157A = amber) to the previously mentioned part number (3156); which was sourced from the owners manual so it's safe to say with 100% certainty that they are white.
2007 Ion 2 Quad Coupe 5-speed manual 180K miles
2007 Chevy Equinox LT 191K miles
2018 Chrysler Pacifica Touring L 27K miles
Add to ruley73's Reputation
Old 03-08-2007, 07:37 PM   #5
Azrael_02
Azrael_02's Avatar
2009 VUE Red Line
2004 ION Red Line
Most the rear tailamp lights are LED with the exception of the turn signal and reverse light . I'am thinking about changing the turn signal bulbs to LED ones. Any concerns or consideration before I try this?
Old 03-09-2007, 10:39 AM   #6
FeeD_BaK
FeeD_BaK is on a distinguished road
FeeD_BaK's Avatar
2007 AURA XE
I suspect you mean the ones from Walmart or something similar that convert the bulb to LED?
I heard these are not that bright.
FeeD_BaK
2007 Silver Aura XE
Add to FeeD_BaK's Reputation
Rate the quality of this post and help FeeD_BaK reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FeeD_BaK is offline   Reply With Quote
Old 03-09-2007, 03:33 PM   #7
spencerb
spencerb will become famous soon enoughspencerb will become famous soon enough
spencerb's Avatar
2008 Astra XR
LEDs have much lower resistance than normal bulbs, and the car will think the bulb has blown. Most cars let you know by causing the turn signals to flash rapidly.
There is a modification around this by adding a resistor to the circuit. I think there is a web site that sells LED retrofit bulbs.
2008 BMW 328i
2013 Subaru Outback 2.5i Limited
Past Saturns: 97 SL2, 01 SC2, 04 VUE, 08 Astra, 02 L200.
Add to spencerb's Reputation
Rate the quality of this post and help spencerb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spencerb is offline   Reply With Quote
Old 03-09-2007, 05:23 PM   #8
Azrael_02
Azrael_02's Avatar
2009 VUE Red Line
2004 ION Red Line
Once I get the bulbs, I'll test them out, and if I don't like the outcome, I'll keep the stock ones in. I'll let you all know what happens.
headlight bulb replacement paulff3 Astra Tech 73 02-01-2014 01:27 PM
taillight bulb replacement crkeehn Relay Tech 1 05-01-2009 05:51 AM
Bulb Replacement Steve91364 Aura General 3 01-18-2007 03:01 PM
Bulb Replacement fortnerw L-Series General 4 07-19-2006 11:05 PM
Foglight bulb replacement Twin_Cam Miscellaneous Tech 4 11-26-2003 01:55 AM
