Old 10-29-2008, 11:32 AM   #1
gmhill
gmhill is on a distinguished road
Default Odometer bulb replacement
How hard is it to replace the bulb that illuminates of odometer reading in a 2000 SL-1?? Can read only if use flashlite to illuminate from the dashboard side.
Add to gmhill's Reputation
Rate the quality of this post and help gmhill reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gmhill is offline   Reply With Quote
Old 10-29-2008, 11:42 AM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: Odometer bulb replacement
remove the dash cover:
http://www.saturnseries.net/DIY%20Gu...sh%20Cover.htm
You may be able to get at the bulb with the gauge cluster installed. Twist & remove. If you can't get at it, you'll have to take the cluster out, which is a little more involved, but not too bad.
http://www.saturnseries.net/DIY%20Gu...ugeCluster.htm
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 10-29-2008, 11:43 AM   #3
1994Saturn
1994Saturn's Avatar
1994 SL1
Happy Re: Odometer bulb replacement
Its no too hard, also its known that the light bulb blows.
Here is a How to
Current:
1998 SL2 Auto issues 112K
Past:
94 SL1 Sold @134K.
Add to 1994Saturn's Reputation
Rate the quality of this post and help 1994Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-29-2008, 12:08 PM   #4
gmhill
Thanks for the replys, this helps big time!!!! Thanks again.
Old 10-29-2008, 12:40 PM   #5
saturncrzy
saturncrzy will become famous soon enough
1992 SL2
this vid will help you.
http://www.youtube.com/watch?v=E6FbkhZakWg
Add to saturncrzy's Reputation
Rate the quality of this post and help saturncrzy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturncrzy is offline   Reply With Quote
Old 10-29-2008, 06:22 PM   #6
Hi Phi High
Hi Phi High is on a distinguished road
Hi Phi High's Avatar
This is an excellent thread at the right time. My odometer light
stopped working about 4 day ago!
Add to Hi Phi High's Reputation
Rate the quality of this post and help Hi Phi High reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hi Phi High is offline   Reply With Quote
Old 10-30-2008, 12:51 AM   #7
Kaervak
Kaervak will become famous soon enoughKaervak will become famous soon enough
Kaervak's Avatar
You'll have to pull the cluster to get the bulb. The odo bulb is recessed into the back of the cluster. It's not a hard job, just takes a bit of time is all. I recently replaced my odo bulb and it took about an hour from start to finish. Since you're going to be in there anyway, you might want to replace the DRL indicator bulb too since that usually has close to the same about of burn hours on it as the odo bulb. Just take your time, don't rush anything and it will be a cakewalk.
Add to Kaervak's Reputation
Rate the quality of this post and help Kaervak reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kaervak is offline   Reply With Quote
Old 10-30-2008, 01:46 AM   #8
1994Saturn
1994Saturn's Avatar
1994 SL1
If it were me, i would replace all of them LOL.
Current:
Past:
94 SL1 Sold @134K.
Old 11-16-2008, 10:45 PM   #9
iamdigitalman
iamdigitalman is on a distinguished road
iamdigitalman's Avatar
1998 SW1
Perfect timing!! My bulb went out tonight, after 45k. I was fretting it, but after watching the video, looks to be no sweat. I work on computers all the time, so this should not be too big of a shift.
oh, the video for the gen 2 vehicle is here: http://www.youtube.com/watch?v=6jXiwgm3bPg
looks like it could be done in less than half an hour. Now all I need to do is find a place that has the bulb for cheap, and do it myself. Does this require unhooking the battery, or should I leave it plugged in? I don't feel like getting shocked. been there, done that.
thanks.
1998 SW1 gold/charcoal bumper with 168,000 miles on it (grandmother's car). originally had 21,266 miles on it when I started driving it.
My baby: http://www.youtube.com/watch?v=fM0AYfRbgM8
Add to iamdigitalman's Reputation
Rate the quality of this post and help iamdigitalman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
iamdigitalman is offline   Reply With Quote
Old 11-16-2008, 11:35 PM   #10
Kaervak
Kaervak's Avatar
thanks.
You can get the bulb at NAPA for $0.99 each for the #73 bulb. I disconnected the battery simply because you're working near the airbag. The chances of it actually deploying are slim, but the less chance of an airbug upside the head is always a plus in my book.
Old 11-17-2008, 10:38 AM   #11
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
If you happen to have a 98-99 with the digital odometer the bulb for the odometer is located in the black shaded area in the picture below.
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-17-2008, 03:28 PM   #12
iamdigitalman
1998 SW1
thanks guys. I went to meijer, and they had a Phillips bulb terminal. It had 2 of them listed as just "instrument", a 74 and a 161. I might wait until some more burn out before I do the surgery.
I will also make sure to disconnect the battery. I think the airbag deployment is in the engine bay, not in the passenger's compartment.
Old 12-16-2008, 12:21 AM   #13
iamdigitalman
1998 SW1
Well, it's the oddest thing. Last night as I was driving back home, the light came back on. Actually, I think it was working from the time I started it, I just never noticed it until I was on the freeway.
idk why it went out, or why it came back on. Maybe it was because she is overdue for an oil change (whoops. the light being out made that hard to notice), and she decided to remind me in her own special way, and it will go out again after I get it changed, just my luck
I will keep an eye on it. I have 2 weeks coming up for school break, so maybe once the oil is changed, I will have enough time to take it all apart. (I am out of town all next week and my mother insists on me driving her all wheel drive monster of an SUV while she takes Sadie for the week)
I am still trying to figure out where to pop up the dash cover. I got the one on the far left of the instrument cluster, but after that, I am lost.
happy holidays, all.
-digital
Old 12-16-2008, 12:36 AM   #14
Go here: http://www.differentracing.com/tech_...99cluster.html
Remove the 2 screws. Get a 2" plastic putty knife and work gently along the edge of the cover and you will find all of the clips. This way you will not break any.
Old 12-16-2008, 01:30 AM   #15
saturnsctwo
seeing you have to remove the dash top just to replace bulbs, i wonder if it's a good idea to convert the dashboard to led's some of the lights are already led's
Old 12-16-2008, 01:52 AM   #16
The 98 is all incandescent. Conversion is the way to go. Taking off the dash top is the easy part.
Old 08-03-2018, 08:55 PM   #17
Gordon-$
Gordon-$ is on a distinguished road
2002 L-Series 2.2L Wagon
OldNuc is spot on about getting the Dash out of the way as being the easiest part of converting even a single W-fil lamp's position to accommodate a light-emitting diode!
Forgive me for lighting up this ancient thread, but I have read a bunch of SatFans' posts discussing W-fil-lamp to LED conversions (including for headlamps) during which I saw no words discussing physical requirements neccessary to preserve semiconductor aspects of the LED. Here are some things to consider:
1) LEDs are polarized devices; while W-fil-lamps are not.
All IPCs whose PCBA is fitted with quarter-turn 'twist' connectors which were designed to function with W-fil-lamps mounted in twist-bases also have polarized electrical contacts. An initial problem arises here. It being that the conversion-mechanic has no a priori knowledge regarding which of those PCB contacts is more positive (when energized) than the other!
The conversion-mechanic then has the responsibility to learn each IPC-socket's polarity, then mark (+) and (-) next to the socket; and pay attention on each R&R of the LED to correctly align its terminals to the markings. The only alternative would be to fit each LED-asm with a suitable full-wave bridge rectifier IC. Ridiculous!
2) W-fil-lamps in the IPC are nominally rated as 12V lamps.
3) A single LED has a rated forward current, and a PIV (Peak Inverse Voltage) rating--not to exceed.
The IPC is designed to provide 12V to its stock lamps and to all RED/YEL SMD LEDs. The conversion-mechanic must do something to prevent forward LED current from thermally destroying the LED. All of those RED/YEL indicator LEDs on my ('02, L4, 2.2L, LW200) IPC-PCBA use 430-ohm series resistors to limit their current.
Add to Gordon-$'s Reputation
Rate the quality of this post and help Gordon-$ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gordon-$ is offline   Reply With Quote
Old 08-05-2018, 08:14 AM   #18
Saturn Night
You can have a flat tire, on a GM vehicle, and it will have been caused by an electrical system component failure. 99% of GM problems, are electrical.
I resurrected a PC, and it happens to be an old Compaq(Hewlitt-Packard), and it works great for being Windows XP SP3.
It made me think to myself: Hewlitt-Packard makes some great electronics. Delphi-Packard......err, not so much.....
Old 12-31-2018, 01:45 PM   #19
Fishfreq
Fishfreq is on a distinguished road
Default Re: Odometer backlight bulb replacement
Gordon, or anyone else around that's tackled this same problem, any feedback on good sources for LED's for our dash backlights? Also, I noticed that the LED's come in colors, so then the next question is: what color LED did you like best?
Here's a source I found, no clue if they're a good supplier or not, fair price I think?
LampTech miniature bulb source
This old thread is perfect for info on how to take apart the dash to change bulbs..
Add to Fishfreq's Reputation
Rate the quality of this post and help Fishfreq reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Fishfreq is offline   Reply With Quote
Old 12-31-2018, 07:05 PM   #20
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
For a gen 2 Saturn S Series, try here..
https://www.superbrightleds.com/more...panel-led/709/
Mobil 1 ESP 0W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Odometer bulb not available? kegs Vue Tech 4 04-09-2008 09:01 PM
Odometer bulb john95SW2 Vue Tech 1 03-15-2008 08:11 PM
Digital Odometer Bulb Part # TIMSPEED S-Series Tech 2 02-14-2008 12:06 AM
Replacing speedometer/odometer bulb chris75 S-Series Tech 9 08-18-2006 08:40 PM
Odometer Light Bulb JOHN RETTMER S-Series Tech 5 09-14-2003 03:42 PM
