Old 01-18-2018, 01:57 AM   #1
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Default Power steering return line...
All,
Trying to get the gunk out of my power steering reservoir...
I have used a turkey baster several times, the gunk returns...
So I am installing a filter in the return line, remove the hose from the reservoir, run to filter, then run back to reservoir...
What size is the return line running to the reservoir?
Many Thanks...
Filter bases to choose from, probably using a single left in 3/8 or 1/2...
https://derale.com/products/filtrati...-filter-mounts
Pennzoil Maximum Power 0W-30, Champion COS3600...
NGK BKR6E-11 spark plugs
Old 01-18-2018, 02:25 PM   #2
jambra1
jambra1 is just really nicejambra1 is just really nicejambra1 is just really nicejambra1 is just really nice
Default Re: Power steering return line...
Having just replaced a power steering pump, I believe that return line at the pump inlet is 3/8" I.D. If you can get some actual hydraulic line, that would assure the integrity of the hose for the long haul.
Retired July 2018
1999 SC2 - 435,023 miles
1999 SL2 - 196,163 miles
Previous
1996 SC2 and 1999 SL2
Add to jambra1's Reputation
Rate the quality of this post and help jambra1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jambra1 is offline   Reply With Quote
Power Steering leak..need new return hose? and other pulley issues? EvanVanVan S-Series Tech 3 01-09-2017 09:49 PM
Power Steering Return Hose Leak t2fastspin L-Series Tech 5 03-21-2015 09:18 AM
Power steering pump return hose - type of hose Upstate Saturn S-Series Tech 7 12-12-2014 12:17 AM
pressure lina and return line which goes where on the steering rack Roccero S-Series General 1 04-20-2014 12:58 PM
Power Steering Pressure and Return Hoses ROCCERO4 L-Series General 1 04-26-2013 01:46 PM
