Old 11-15-2016, 04:13 PM   #1
Ionizen
Ionizen is on a distinguished road
Default Supply/Return Flow for Sl1 Transmission Cooling Line
2001 SL1 auto Trans: I'm trying to find out if the Transmission cooling line on the upper drivers side is a supply or return line. Thanks in advance for the help.
Add to Ionizen's Reputation
Rate the quality of this post and help Ionizen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ionizen is offline   Reply With Quote
Old 11-15-2016, 04:32 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Supply/Return Flow for Sl1 Transmission Cooling Line
The hot fluid leaving the transmission would be the upper pipe.
Just like the engine coolant hot is at the top, and after flowing through, gets cooled.
This is semantics. Hot fluid hits higher on the radiator, gets cooled somewhat and exits the radiator (oil cooer portion) via the lower pipe.
It really is a moot point. You already only see a slight film on the existing filter magnet, so who cares which pipe you put an extra filter on? You probably won't get much debris, unless something is going very bad inside the tranny.
Old 11-15-2016, 04:37 PM   #3
Ionizen
Thank you.
What size is transmission cooling line? Difficilus Vue General 3 12-11-2015 03:59 PM
Transmission cooling line connector torque nash22 S-Series Tech 2 12-02-2015 09:00 PM
Transmission cooler return line Mark121 S-Series Tech 2 02-22-2015 04:17 PM
Fuel supply line -- description? DurhamBull S-Series General 13 09-08-2010 12:54 PM
