Old 02-14-2020, 01:28 PM   #1
Banksy
Banksy is on a distinguished road
Default Excessive oil consumption on my 01 SL2 after changing valve cover seal
Hello,
I have a 2001 SL2 with 185k
Changed the valve cover gasket a few months back and it's going though about 2.5 qts per 5k
Before this it was going though about one.
I checked around the gasket and there is nothing leaking out from what I can see. I don't notice oil anywhere on the engine either.
Any idea of what is going on here? I know SL2s burn oil I've had three now. However Im wondering if me changing the gasket had something to do with this.
Add to Banksy's Reputation
Rate the quality of this post and help Banksy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Banksy is offline   Reply With Quote
Old 02-14-2020, 01:57 PM   #2
onlinebiker
Default Re: Excessive oil consumption on my 01 SL2 after changing valve cover seal
That is not excessive.
GM would not replace an engine under warranty unless it used a quart in under 750 miles.
Over 1500 miles per quart is quite good.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
onlinebiker is online now   Reply With Quote
Old 02-22-2020, 12:23 PM   #3
1996SL11.9L
1996SL11.9L has a spectacular aura about1996SL11.9L has a spectacular aura about
1996SL11.9L's Avatar
2002 SL1
I would say the extra vacuum from sealing up the valve cover is pulling more oil vapor through the PCV.
Add to 1996SL11.9L's Reputation
Rate the quality of this post and help 1996SL11.9L reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1996SL11.9L is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Preferred way to seal valve cover Jonasan308 S-Series Tech 3 11-20-2017 09:50 AM
Valve cover gasket won't seal hit_n_run S-Series General 19 04-15-2013 10:25 AM
Twin cam valve cover re-seal help.. 1993 S-Series Tech 4 02-03-2012 01:02 AM
02 sl valve cover seal kevo420 S-Series Tech 9 11-14-2011 08:08 AM
re-seal the valve cover gasket? dragon370 S-Series Tech 9 04-09-2007 04:55 PM
