Old 01-23-2020, 02:34 PM   #1
KCK71
KCK71 is on a distinguished road
Default SL1 Oil Leak Question
First post on the forum. Have a 1995 SL1 (gold, of course) that has a 1997 engine. Car has 350K, engine was replaced at 200K but not sure how many miles it had at that point.
Anyway, the normal oil leakage has steadily increased to where I'm thinking the engine is now a 2-stroke engine, as it takes at least a quart per tank of gas or more. Still cheap to drive even running that much oil through it, but if I can solve the leak that would be good.
What would cause that much leakage but leave very little trace? It's not burning oil that I notice, nor does it puddle when parked. What are the usual suspects to check first, etc.?
Thanks for the help.
Add to KCK71's Reputation
Rate the quality of this post and help KCK71 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KCK71 is offline   Reply With Quote
Old 01-23-2020, 03:39 PM   #2
billr
Default Re: SL1 Oil Leak Question
They all can suffer from oil getting past the oil-control rings and "burning" with no apparent effects; no fouled plugs or visible smoke, will pass smog test fine.
Another possibility is a problem with the PCV system.
Add to billr's Reputation
Old 01-30-2020, 09:21 PM   #3
grandamgt2k
grandamgt2k is on a distinguished road
Try changing out the PCV valve, a quart of Lucas Oil and/or adding a bottle of AT-205 resealer to the engine oil.
Add to grandamgt2k's Reputation
Rate the quality of this post and help grandamgt2k reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
grandamgt2k is offline   Reply With Quote
Old 01-31-2020, 12:36 AM   #4
me.theuser
me.theuser is on a distinguished road
2002 SL1
2001 SL2
Stop leak products are never a good idea I doubt this one is any different..
Add to me.theuser's Reputation
Rate the quality of this post and help me.theuser reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
me.theuser is offline   Reply With Quote
Old 02-01-2020, 12:15 AM   #5
Car will also drive fine with both
the other usual suspects are worn valve stem seals and a warped plastic cam /valve cover at the driver side rear.
Old 02-15-2020, 02:39 AM   #6
TomM96
It should also be recognized that excessive oil consumption is a classic indication of immanent 'last days':
An engineer from Lotus had/has some text online explaining the connections between good honing, out-of-round cylinders, cylinder sealing, and expiration.
Compression and fuel consumption (mileage) are the two best overall indicators - like a Go/NoGo test for engines.
If the start readily, and get good mileage, they're RUNNERS !
Add to TomM96's Reputation
Old 02-15-2020, 04:07 AM   #7
NWSaturn247
NWSaturn247 will become famous soon enoughNWSaturn247 will become famous soon enough
NWSaturn247's Avatar
[QUOTE=me.theuser;2341118]Stop leak products are never a good idea I doubt this one is any different..[/QUOTE
YouTube automotive guru Scotty Kilmer has high regard for ATP AT-205. It is a good seal conditioner.
1999 SL2 A4 -87k miles
Currently sipping Mobil 1 & LiquiMoly mos2
TCW3 dosed fuel
https://www.ls1.com/forums/f48/been-testing-oil-91206/
1993 SL2 SOLD @189k
Add to NWSaturn247's Reputation
Rate the quality of this post and help NWSaturn247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NWSaturn247 is offline   Reply With Quote
Old 02-15-2020, 10:57 AM   #8
Waiex191
Waiex191's Avatar
I am no fan of stop leak of any sort.
When your car got the engine swap, did it end up with a plastic or aluminum cover? If it is aluminum it is unlikely that is leaking.
I would also check the PVC valve as it is pretty easy to do.
A rebuild is a sure-fire way to fix it. Worked for me. My '99 does not use oil anymore.
Edit: auto or manual? Could also be the main seal.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Oil leak question 97purplepest S-Series Tech 0 04-02-2015 09:12 PM
oil leak question trouttrooper S-Series General 9 03-20-2013 07:59 AM
question about radiator stop leak helping a leak from the plastic end caps tmoncrief S-Series General 6 09-04-2012 02:51 PM
A/C Leak Question DonP S-Series Tech 2 04-18-2010 10:02 AM
Oil leak question lolo S-Series General 7 09-25-2008 03:02 PM
