Old 02-14-2020, 05:30 PM   #1
prioris
prioris is a jewel in the roughprioris is a jewel in the roughprioris is a jewel in the rough
Default service light (wrench) CODES 1640 1641
I have narrowed down service light problem down to the cruise control
Just turned ignition key to ON to check these
LOW FUEL LIGHT OK
SERVICE LIGHT OK
LOW COOLANT LIGHT ... GAUGE IS OK
CRUISE CONTROL ... brake logic etc (through process of elimination)
It's possible it could be a short but if it is a component, what exact part would it be and where is it located ... 1999 Saturn SL1
I used a GM advanced scanner to get code. Mechanic scanned it for free.
Add to prioris's Reputation
Rate the quality of this post and help prioris reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
prioris is offline   Reply With Quote
Old 02-14-2020, 08:43 PM   #2
Zeebins
Zeebins's Avatar
Default Re: service light (wrench) CODES 1640 1641
P1640 and P1641 have almost nothing to do with cruise. I got the same codes after installing a remote starter. (As well as two that do actually have to do with cruise, but that's only because I forgot to plug the module back in.) P1640 and P1641 seem to be related to the ignition. Not sure why its called heater circuit, but they got tripped for me because I had swapped the accessory and the ignition wire when plugging them in to the starter module.
Maybe one of these possible causes is your problem? It does mention cruise as one of the "10 other reported fixes", but I'd look in to the other possible causes first.
97 SL2, auto, 117K miles
Powered by Plastic
Add to Zeebins's Reputation
Old 02-15-2020, 12:57 AM   #3
prioris
The codes are related specifically to the quad driver module. Here is the info from the internet.
http://ultraviolet.im/saturn/1998_Sa...psdsubkey=3108
CODES 1640 1641
Both of these codes are directly related and point to a fault with the quad driver module. A quad driver module (QDM) is an electronic switch which completes a ground circuit when switched On.
DTC P1640 and/or P1641 will set if:
There is an open, short to ground or short to voltage on any of the QDM output circuits.
SERVICE telltale lamp circuit
Low coolant/hot telltale lamp circuit
Cruise clutch circuit
If you look at the diagram in above link, I could see you getting the codes with installing a remote starter
Those attachment images you provided seem to be related to repair records. Many have other associated codes.
Appreciate you very much for taking the time to reply
Maybe I need to ask which specific part is related to
1999 saturn sl1 cruise clutch circuit
Old 02-15-2020, 01:42 AM   #4
prioris
i'll check my upshift arrow light too since i saw someone mention it
some time ago, i thought my cruise control kept releasing while driving.
i will check that again when spring comes.
service light (wrench) no codes prioris S-Series Tech 10 12-25-2019 09:48 PM
BIL's '02 SL1 Service Wrench Light & Has Codes P0128, P0133 & P0410. Pitcher S-Series General 9 03-14-2014 07:29 PM
Service Wrench Light On but showing no codes ? saladdin S-Series Tech 8 09-11-2010 03:59 PM
codes 1640 , 1641 , 1650 , 1651 postmortal1 S-Series Tech 5 03-11-2010 12:15 PM
How do I get the codes for the Service light (wrench) on my L300 lcluvinlife L-Series Tech 5 02-24-2010 05:46 PM
