Old 02-10-2020, 02:25 PM   #1
Aspenglade
Aspenglade is on a distinguished road
Default 2001 SL1 - Smoke Test
I would like to perform the smoke test and verify any leaks in the vacuum system.
Where or from what hose can I introduce the smoke?
Add to Aspenglade's Reputation
Rate the quality of this post and help Aspenglade reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Aspenglade is offline   Reply With Quote
Old 02-15-2020, 01:38 AM   #2
TomM96
Default Re: 2001 SL1 - Smoke Test
I suspect the cause of the zet response...
is the fact that it would be difficult to ascertain if exterior smoke were
disappearing, particularly since it would likely to disappear into a space which itself is, normally smokey (and inaccessible).
One possible test for vacuum leaks involves installing a vacuum gage, and assessing the degree of vacuum in the system.
A good scanner might give an indication.
Manifold vacuum affects EGR, and some other items (including fuel pressure via regulator in Gen2 Satturn S).
Old rubber vacuum hoses tend to deteriorate, but Saturn mostly uses Nylon plastic lines. Be careful if handle the plastic lines, as they embrittle and can break.
Prudence suggests checking connections at the FuelEvaporationCannister & associated articles, as valves.
Add to TomM96's Reputation
test drove a 2001 SW2 SLfun S-Series General 15 10-02-2014 06:30 AM
how can i smoke test my evap scw2 S-Series Tech 5 08-30-2014 11:49 PM
Blue Smoke or White Smoke...some defintions 2NDSOUT S-Series Tech 0 07-08-2009 10:16 AM
2001 Saturn SC2 failed emissions test. irish80ca S-Series General 7 10-21-2008 08:07 AM
TPS test on 2001 saturn SL1 jcm22 S-Series Tech 5 08-01-2007 08:59 PM
