Old 02-01-2020, 05:54 PM   #1
magician22773
magician22773 will become famous soon enough
1997 SL
Default 2001 SL 1 Coolant Leak
Does anyone have a coolant system diagram for a 2001 (3rd Gen) SOHC?
I have developed a pretty nasty leak from the back side of the engine, and wanted to see what was back there before I tear into it. Appears to be somewhere center or driver side, and only occurs under full pressure.
Hoping for a relatively easy fix, as the Satty is my winter car, and I don't think the Camaro is going to happy if I have to drive it in February. :-)
1994 SC2 Retired
1996 SL "FrankenSaturn"
1998 SL2 FrankenSaturn's Body Donor
2004 Vue "What was I thinking?"
2001 SL1 100k Mile Baby Blue Beauty
1999 SL2 Thank You Tiger!
Add to magician22773's Reputation
Rate the quality of this post and help magician22773 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
magician22773 is offline   Reply With Quote
Old 02-01-2020, 11:26 PM   #2
454cid
Default Re: 2001 SL 1 Coolant Leak
You've got heater core lines and the line that connects to the intake manifold. The fitting on the intake is known to break, I've read.... thankfully mine has not.
I think the metal (aluminum?) pipe that connects to the surge tank runs back there too.
1999 Chevy K3500
Add to 454cid's Reputation
Old 02-08-2020, 07:47 PM   #3
+1
Diagram is generally the same for all years. For 3rd gens, back of engine, check to see where the line from the driver side of the black plastic intake attaches (follow the de-aeration line that runs along the top of the firewall).
The "nipple" in the plastic intake breaks; has to be cut off and replaced
https://www.youtube.com/watch?v=blgRq_BXv8s
Old 02-08-2020, 10:51 PM   #4
454cid
Hmm, I just noticed you specified the SOHC engine.... I don't know if the SOHC has the same intake flaw, of the nipple breaking off.
1999 Chevy K3500
Old 02-10-2020, 10:57 PM   #5
TomM96
@Magician
One of innumerable observations made by OldNuc:
If one fills the cooling system (waterjacket) with a 50:50 mixture of antifreeze and (purified) water ... the system will Not really pressurize, because the mixture does not boil at the operating temperature. This really saves on seal wear, etc.
Add to TomM96's Reputation
Old 02-12-2020, 09:01 PM   #6
hholbein
The finance weenies at GM seem to only have applied value engineering/plastic intake manifold to the DOHC and left the SOHC cooling system alone.
Add to hholbein's Reputation
2001 SL2 Coolant Leak enviroko S-Series General 5 09-16-2014 08:12 PM
2001 sl2 coolant leak.... skylarfurr S-Series Tech 2 05-27-2014 05:32 AM
2001 SL1 Coolant Leak konakani S-Series Tech 29 02-04-2014 03:45 PM
Coolant leak - 2001 SL1 ShawnV S-Series Tech 10 01-27-2014 10:50 PM
2001 DOHC Coolant Leak richamer1 S-Series General 2 01-27-2014 06:37 PM
