Old 02-01-2020, 12:34 PM   #1
97SL2guy
97SL2guy is on a distinguished road
2006 ION-2 Sedan
Dizzy Power Window master switches NOT lit up!
I checked and checked this forum and all over Google but found nothing helpful, so I decided to post this.
My owners manual clearly states the power window switches are illuminated, but mine never worked. Since the car was so poorly maintained, I just figured it was a matter of the bulbs being burned out. So, since they symbols were worn off anyway, I found brand new ones on eBay for like $12!!! The cool thing is that the one I got on eBay is even nicer than the stock master control! BUT... it doesn't light up either!
Anyone else have this issue with their Ion? Do your master switches actually light up like most cars? Since replacing the master switch panel didn't light them up, I'm assuming it's a problem with some kind of connection. The nice thing is that at least all my windows work fine. It's just annoying to have to feel around at night for the correct switch. Would be nice it they were lit up like every car I've owned in the past.
Any ideas? Thanks.
Sold the 97 SL2 and bought a 06 Ion! SO MUCH NICER car! Problem is, I don't think there is a way to change my username, so I'm leaving my username alone until I figure out if/how it can be changed.
Add to 97SL2guy's Reputation
Rate the quality of this post and help 97SL2guy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
97SL2guy is offline   Reply With Quote
Old 02-02-2020, 03:55 AM   #2
imaddicted2u
imaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really nice
imaddicted2u's Avatar
2008 AURA XE
Default Re: Power Window master switches NOT lit up!
This is the circuit diagram for the switch.
On the right side, it clearly shows there is a LED for lighting the switch.
If you still have the old switch, You could try this test to see if the LED can light. Put +12V on Connector 1 Pin A and -12V on Connector 1 pin E using a couple of jumper wires.
If it lights, you likely have a broken GRY wire in the grommet between the door and body or somewhere along the way to where it connects to the illumination circuit. I believe that if the BLK (ground) wire was broken, none of the windows would work. You could clean up the ground connection under the driver seat. It's possible that a poor connection here could cause the LED not to light but the windows to operate but slower than they should.
Old 02-04-2020, 01:24 PM   #3
97SL2guy
2006 ION-2 Sedan
Thanks! I'll check that! I do still have the old master switch panel since it works, just worn symbols and it didn't light up. Yeah, I'll open it up. And I'll open the new one too if and make sure there is even a light inside it. After all, for less than $12 you never know what you're getting.
Old 02-04-2020, 02:18 PM   #4
imaddicted2u
2008 AURA XE
No need to open them up, put 12 volts on the pins I noted, even a 9 volt battery should light the LED. Just make sure you have the polarity right. When you do, I'm pretty sure it will light up.
Old 02-04-2020, 03:41 PM   #5
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
None of the switches on any of the doors are illuminated, and neither is the dimmer switch itself.
I wondered the same thing when I replaced my master power window switch last year. The old switch never lit up and the new one doesn't either. Strangely, the diagram I looked at also shows the LED, but no dedicated feed from the I/P lighting circuit for it.
I suppose a sedan could be different (I have a quad coupe), but not likely. I'm confident the wiring diagrams and owner's manual are inaccurate.
2007 Ion 2 Quad Coupe 5-speed manual 182K miles
2018 Chrysler Pacifica Touring L 46K miles
Add to ruley73's Reputation
Old 02-05-2020, 12:30 AM   #6
joethesmith
joethesmith is on a distinguished road
2006 ION-2 Quad Coupe
I agree that the diagrams are inaccurate. The buttons for the window up/down are just painted on (which is why they always rub off after a fairly short period of time) and it is just a solid black/grey/tan piece of plastic with no openings for light to pass through. Unlike the cruise control switches on the steering wheel that are made to have back lighting.
Add to joethesmith's Reputation
Rate the quality of this post and help joethesmith reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
joethesmith is offline   Reply With Quote
Old 02-05-2020, 01:55 PM   #7
97SL2guy
2006 ION-2 Sedan
Oh, GREAT! LOL! I kind of suspected something wasn't right when a brand new aftermarket master switch didn't light up either. But then why would the wiring diagram show a wire from the light circuit going to it? Odd.
Apparently the owners manual WAS wrong, unless that was some special option you had to pay extra for.
I wouldn't care if any of the other switches lit up, but it would certainly be nice if the master switches lit up. But I'm sure I'll survive.
Thanks everyone!
Old 02-05-2020, 01:59 PM   #8
97SL2guy
2006 ION-2 Sedan
Just got a crazy thought... I wonder if there IS an LED inside the master switch, if I could just tap power off the main power wire coming to the switch! Well, I know I can do it because I'm really good at 12v wiring stuff, but the question is rather should I waste my time trying. Going to open my old master switch and see if there IS any type of LED or light in it, then I'll know if I can sleep better.
Old 02-05-2020, 02:11 PM   #9
97SL2guy
2006 ION-2 Sedan
Apparently you can buy these master switches at Walmart, IF you're willing to pay $4500 MORE than you paid for the entire car! LOL! Just found this ad while google searching! Reminds me of the $35,000 sleeping bag I found on Walmart's website last year!https://www.walmart.com/ip/Master-Po...4398/139958653
Old 02-06-2020, 02:15 AM   #10
ruley73
ruley73's Avatar
I attempted to salvage/repair my switch before replacing it. I can confirm the PCB inside of the switch (at least the two window switch for the quad coupe) does not have an LED on it.
Old 02-11-2020, 12:30 PM   #11
97SL2guy
2006 ION-2 Sedan
Thanks. I'll skip the waste of time.
00-02 power window/mirror switches scalemechanic S-Series Tech 7 02-16-2013 11:32 AM
Power window switches rosett S-Series Tech 3 08-15-2007 12:04 PM
Need 2nd gen sl power window switches Coslow99sl2 Classifieds 2 04-30-2005 10:13 AM
Rear Door Power Window Switches Kev Vue General 12 09-06-2004 07:41 PM
Power Window Switches silverblueL200 Miscellaneous Tech 8 06-11-2003 11:25 PM
