Old 05-07-2016, 08:08 PM   #1
carvinbassplyr
carvinbassplyr is on a distinguished road
2005 VUE Red Line
Default Rear Sprayer Coming On Instead Of Front Sprayer
Like the title states I recently I pulled the lever to spray the windshield and clean it off, but the rear sprayer turned on instead of the front. The wipers still come on, it's just spraying out the back nozel instead of 2 front ones. Anyone had this happen b4? Do I just need to replace the stalk?
Add to carvinbassplyr's Reputation
Rate the quality of this post and help carvinbassplyr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
carvinbassplyr is offline   Reply With Quote
Old 05-07-2016, 08:11 PM   #2
billysvue
Default Re: Rear Sprayer Coming On Instead Of Front Sprayer
Try turning off the rear wiper, first.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 05-07-2016, 08:23 PM   #3
carvinbassplyr
2005 VUE Red Line
It is off. I even tried fiddling with the rear wiper switch to see if I could get it to release back to the front.
Old 05-08-2016, 12:13 AM   #4
billysvue
DIsconnect hoses from front sprayers and try again- maybe fronts are clogged.
'17 Suby Forester
Old 05-11-2016, 07:53 PM   #5
carvinbassplyr
2005 VUE Red Line
Well, I put another new pump in there (was just replaced a few weeks ago) and ordered a replacement switch assembly for the steering wheel. Neither fixed the problem. So either I beat the odds and got another switch assembly with the exact same issue or there is something happening with the switching at the plug end of the harness (two leads, 1 for front and 1 for rear. My guess is a polarity switching circuit like a rear view mirror switch). Anyone else have any advice?
Old 05-11-2016, 08:39 PM   #6
billysvue
If the tubing to the front sprayers is clogged, anything else you throw at it will have no effect.
Prove they aren't before throwing more parts at it.
'17 Suby Forester
Old 05-13-2016, 12:18 AM   #7
carvinbassplyr
2005 VUE Red Line
I disconnected the hose right from the pump with the tank pulled out and up unto the engine bay so I could see it. Pulled the switch and out came fluid from the back sprayer still.
Old 05-13-2016, 07:51 AM   #8
billysvue
New pump and switch and still same symptom leaves the harness.
Until it's figured it out, swap the tubing to get water to the front sprayers.
'17 Suby Forester
Old 05-15-2016, 12:18 PM   #9
far2grumpy
far2grumpy's Avatar
I might have missed info - but do you get fluid to windshield when rear washer switch is active?
If yes - the pump is wired reverse of conventional scheme.
Keep in mind the pump is powered by reversible DC motor - apply +12 and ground in one polarity to spray windshield and reverse motor polarity to spray rear window.
You mentioned having pump changed. Many aftermarket pumps aren't compatible with GM two pin connector which usually requires cutting and splicing of Red and Dark Green wires for new pump.
Old 05-15-2016, 02:21 PM   #10
billysvue
Originally Posted by far2grumpy View Post
I might have missed info - but do you get fluid to windshield when rear washer switch is active?..
Never yet.
'17 Suby Forester
Old 05-15-2016, 02:25 PM   #11
billysvue
If not a ferkakta, aftermarket pump, then, maybe a relay that controls the reversing you describe?
'17 Suby Forester
Old 05-15-2016, 04:19 PM   #12
far2grumpy
far2grumpy's Avatar
Front and rear washer functions are controlled by two mechanical switches built into the wiper stalk. The wiring is a direct path between stalk and washer motor and one of the two switches determine which way pump motor runs.
When either washer switch is activated it also provides a signal to BCM which activates the appropriate wiper motor for three swipes.
Old 05-21-2016, 07:25 PM   #13
carvinbassplyr
2005 VUE Red Line
When I replaced the motor the first time because nothing was spraying at all, it worked just fine at first. Then one day it just permanently changed to only activating the rear no matter which switch I used.
Old 05-22-2016, 08:19 PM   #14
99WhiteC5Coupe
99WhiteC5Coupe will become famous soon enough99WhiteC5Coupe will become famous soon enough
Have you used a genuine ACDelco pump - or an aftermarket pump? If aftermarket, buy an ACDelco pump.
Add to 99WhiteC5Coupe's Reputation
Rate the quality of this post and help 99WhiteC5Coupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
99WhiteC5Coupe is offline   Reply With Quote
Old 02-01-2020, 08:35 PM   #15
Gotrims
Gotrims is on a distinguished road
Gotrims's Avatar
Any updates on this post? I have the same problem myself and can't figure out what is wrong
Add to Gotrims's Reputation
Rate the quality of this post and help Gotrims reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gotrims is offline   Reply With Quote
Windshield Sprayer texaspride28 Vue Tech 3 10-14-2015 06:35 AM
Windsheild washer sprayer cake L-Series Tech 3 02-25-2011 02:57 AM
Clogged Windshield Sprayer doser S-Series Tech 6 10-16-2009 10:51 PM
Broken Rear Wiper sprayer on SW2 Gambit S-Series General 0 11-07-2008 07:33 PM
Rear washer fluid sprayer for SW2 ScottSaturn83 S-Series General 3 02-09-2005 01:58 AM
